Lab 1: Explore the F5 BIG-IP network configuration
It is assumed that you have already licensed each of the BIG-IP devices. In this lab you will explore network settings on the BIG-IP. You will also configure a default route, internal and external vlans, and finally you will configure Self-IP Addresses and map them to individual VLANs.
Task 1 – Connect to the Windows 10 Jumphost via Remote Desktop Protocol RDP Select the ACCESS drop down menu under Windows 10 and choose the RDP with an appropriate resolution option. Select a resolution that is smaller than your desktop resolution.
The Windows 10 Jumphost Remote RDP User ID and Password is located within the Details section of the Windows 10 Jumphost. If you are using MAC or non Windows system you may need to download the Microsoft Remote Desktop App from the Mac App Store.
  1. From the Windows 10 Jumphost using a web browser (Chrome), log into BIG-IP01 (https://10.1.1.4) system with the below credentials.
    U: admin P: admin.F5demo.com
  2. While logged into the BIG-IP01 gui click on the Network menu object, then click on the Interfaces object. Note that there are three interfaces labeled 1.1, 1.2, and 1.3.
    The Network menu is where you configure elements for routing and switching.
  3. Network interface 1.1 is assigned to the external network while interface 1.2 is assigned to the internal network
  4. Now we will create VLANs on these interfaces.
  5. From within the Network menu click on the VLANs object then click on the Create.
  6. Enter the name external. Select interface 1.1, click the Tagging drop down menu and ensure the interface is set to Untagged then click on the Add button.
    Note: The BIG-IP will assign VLAN tags automatically starting from 4094 and decreasing if a tag is not provided.
  7. Follow the same process for creating a VLAN named internal while ensuring interface 1.2 is selected as Untagged.
  8. Now we will configure two Self-IP Addresses.
  9. From within the Network menu click on Self IPs object and click Create.
  10. Name the first Self IP object external_selfip.
  11. Assign the 10.1.10.245 IP Address, with a Netmask of 255.255.255.0
  12. Ensure the VLAN/Tunnel is set to External, while the Port Lockdown should be configured for Allow None.
  13. Follow the same process for internal_selfip using Internal VLAN with the following IP Address and Netmask.
    10.1.20.245/255.255.255.0
  14. Click Finished after configuring each of the Self IP Addresses
  15. The next task is to configure a Network Default Route.
  16. Under the Network menu click on the Routes object and click the Add button.
  17. Name the Network Default Route object default_route
  18. The Destination and Netmask should be 0.0.0.0/0 and 0.0.0.0/0
  19. Ensure Use Gateway is selected and Gateway Address is set to IP Address.
  20. Enter the address 10.1.10.1 and click Finished
Task 2 – Create a Pool BIG-IP object and a Virtual Server
We will be configuring a Pool with four member objects. A pool is a group of pool members. With few exceptions, all the members of a given pool host the same content. Pools are named, and like most objects on BIG-IP systems, their names can begin with a letter or underscore as well as numbers but should not contain spaces. Pools also have thier own load balancing method, monitors, and other features defined when a pool is created or modified. When a new connection is initiated to a virtual server that is mapped to a pool, various criteria, including the pools load balancing method may be used to determine which member to use for that request.
  1. Open the Local Traffic > Pools > Pool List page and click Create.
  2. Use the following information for the new pool named LAMP. For fields that are not specified, leave them set to the default settings.
    Form field Value
    Pool Name LAMP
    New Members
    Node Name LAMP_Server1
    Address 10.1.20.11
    Service Port 80 (Click Add)
    Node Name LAMP_Server2
    Address 10.1.20.12
    Node Name LAMP_Server3
    Address 10.1.20.13
    Node Name LAMP_Server4
    Address 10.1.20.14
  3. Click Finished.
  4. Open the Local Traffic > Virtual Servers > Virtual Server List page and click Create.
  5. Use the following information for the new virtual server, and then click Finished.
    Form field Value
    Name LAMP
    Destination Address/ Mask 10.1.10.200
    Service Port 80
    Source Address Translation Auto Map
    Resources > Default Pool LAMP
  6. Use a new tab to access http://10.1.10.200.
  7. Use Ctrl + F5 to reload the page several times.
    You should notice the LAMP Pool displaying the respective page elements from all members. If you're not seeing elements displaying from each Node you may need to open Developer Tools and enable the Disable Cache option. To open Developer Tools in Chrome click the 3 dots at the top right -> More Tools -> Developer Tools. That’s all it takes to create a basic web application on the BIG-IP system.
  8. Close the tab.
  9. In the Configuration Utility, open the Local Traffic > Pools > Statistics page.
  10. Expand the LAMP pool by clicking on the + icon.
    You use the Statistics page to identify the amount of traffic sent to the pool members. Notice that the requests are evenly distributed across all three web servers.
  11. Select the checkbox next to LAMP, and then click Reset.
Task 3 – Create an IP Forwarding Virtual Server
An IP forwarding virtual server accepts traffic that matches the virtual server address and forwards it to the destination IP address that is specified in the request rather than load balancing the traffic to a pool. Address translation is disabled when you create an IP forwarding virtual server, leaving the destination address in the packet unchanged. When creating an IP forwarding virtual server, as with all virtual servers, you can create either a host IP forwarding virtual server, which forwards traffic for a single host address, or a network IP forwarding virtual server, which forwards traffic for a subnet.
  1. From the Windows 10 Jump Host use a new tab to attempt direct access to an internal web server at http://10.1.20.15.
    Currently you are unable to access resources on the internal network from the external Windows workstation.
  2. Open the Start menu and type cmd, then right-click cmd.exe and select Run as administrator, and then click Yes.
  3. At the command prompt, type (or copy and paste):
    route add 10.1.20.0 mask 255.255.255.0 10.1.10.245
    This adds a route to the 10.1.20.0 network through the external self IP address (10.1.10.245) of the BIG-IP system.
  4. Reload the page directed at http://10.1.20.15.
    The request fails again, as the BIG-IP system does not have a listener to forward this request to the internal network.
  5. In the Configuration Utility, open the Local Traffic > Virtual Servers > Virtual Server List page and click Create.
  6. Use the following information for the new virtual server, and then click Finished.
    Form field Value
    Name forward_virtual
    Type Forwarding (IP)
    Source Address/ Mask 0.0.0.0/0
    Destination Address/ Mask 10.1.20.0/24
    Service Port * All Ports
    Protocol * All Protocols
    Source Address Translation | Auto Map
    This virtual server provides access to the 10.1.20.0/24 network on all ports and all protocols.
  7. Reload the page directed at http://10.1.20.15.
    The request is successful. The BIG-IP system doesn’t act as a full proxy, it simply forwards requests to the internal network.
You now have access to all ports and all protocols on the 10.1.20.0 network.
Task 4 – Create a Reject Virtual Server
A Reject virtual server rejects any traffic destined for the virtual server IP address.
  1. From the Windows 10 Jump Host use a new tab to attempt direct access to the LAMP server at http://10.1.20.252.
    Access is allowed through the previously created Forwarding Virtual Server
  2. In the Configuration Utility, on the Virtual Server List page click Create.
  3. Use the following information for the new virtual server, and then click Finished.
    Form field Value
    Name reject_server
    Type Reject
    Destination Address/ Mask 10.1.20.252
  4. Reload the page directed at http://10.1.20.252.
  5. Although you still have access to the 10.1.20.0 network, you no longer have access to 10.1.20.252 (LAMP Server).
  6. Close the Browser Tab.
  7. In the command prompt type the following, and then close the command prompt.
    route DELETE 10.1.20.0
  8. In the Configuration Utility, select the forward_virtual and reject_server checkboxes and then click Delete and Delete again.
Task 5 – Use Different Pool Options
  1. Open the Local Traffic > Pools > Pool List page and click LAMP pool, and then open the Members page.
    Currently the pool is using the default load balancing method: Round Robin.
  2. From the Load Balancing Method list select Ratio (member), and then click Update.
  3. Examine the Current Members section.
    Currently all members of the LAMP pool member have a ratio of (1).
  4. Given that there are four members of the LAMP pool we can modify the ratio of connections to each pool member. As an example let's go ahead and change ratio value for LAMP_Server1 to 4, assign a ratio value of 3 to pool member LAMP_Server2, a ratio value of 2 to pool member LAMP_server3, and a ratio value of 1 to pool member LAMP_Server4.
    The effect this would have is that connection requests would be distributed to members of the LAMP pool in following manner 4, 3, 2, 1. LAMP_Server1 will receive 4 requests for every 1 request LAMP_Server4 receives. Send some requests and verify using pool statistics.
  5. The BIG-IP system provides several Ratio load balancing methods for load balancing traffic to pool members including the following:
    Form field Value
    Ratio (member) Ratio member is recommended when the server capacity of pool members is different
    Ratio (Node) Ratio Node method can be used when the server capacity of pool members is different and user specified weights are applied to all pools which each nodes is a member.
    Ratio (session) Ratio session method can be used for message based load balancing protocols such as RADIUS, DIAMETER, or other protocols
    Ratio Least Connections (member) Use this method when you want the BIG-IP to weight connections to each pool member
    Ratio Least Connections Us this method allows the BIG-IP to assign ratio weights applies to all pools of which each node is a member
    Dynamic Ratio Dymanic Ratio load balancing actively polls pool members and assigns a weight value to each member.
  6. Change the load balancing method for the LAMP pool back to round robin.
This concludes Lab 1 and a basic introduction into networking concepts, Virtual Servers, Pools, and Load Balancing methods. Please begin Lab 2.
