Lab 2: Work with SNAT, Profiles, and Monitors
In this lab you will gain experience using SNAT Auto Map for inbound requests as well as outbound requests from internal users. You’ll also use an HTTP and stream profile to make global modifications to text within a web site. Finally you’ll see how using health monitors ensures that the BIG-IP knows which web servers are available for client requests. SNATs, or Secure Network Address Translation, provide a mapping between nodes, often internal devices and a SNAT address. SNATs can be configured many different ways including one-to-one mappings, many-to-one mappings, or all to one mappings. In all cases a SNAT must be enabled on the VLAN where the node's traffic arrives on the BIG-IP system. In this lab we will focus on the SNAT Automap feature which automatically maps the source address of an allowed host to an address from a defined group. Often times this is a Self-IP address on the BIG-IP.
Task 1 – Use SNAT Auto Map
A virtual server configured on a BIG-IP system typically translates the destination IP address of an incoming packet to load balance requests. By default the source IP address remains unchanged.
  1. In the Configuration Utility, open the Pool List page.
  2. For this lab we will use the existing LAMP pool which contains the below members. Make sure load balancing method is Round Robin.
    Form field Value
    Name LAMP
    LAMP_Server1 Address: 10.1.20.11 Service Port: 80
    LAMP_Server2 Address: 10.1.20.12 Service Port: 80
    LAMP_Server3 Address: 10.1.20.13 Service Port: 80
    LAMP_Server4 Address: 10.1.20.14 Service Port: 80
  3. Open the Virtual Server List page and click on the LAMP virtual server
  4. Change the Source Address Translation setting from Auto Map to None.
  5. Click Update to update the Virtual Server configuration.
  6. From the Windows Jump Host open putty, and then connect to BIGIP01 10.1.1.4 and log in as root / admin.F5demo.com.
  7. At the CLI type (or copy and paste):
    tcpdump -ni external port 80
  8. Open a second putty session and connect to BIGIP01 10.1.1.4 and log in as root / admin.F5demo.com.
  9. At the CLI type (or copy and paste):
    tcpdump -ni internal port 80
  10. Use a new tab to access http://10.1.10.200, and then close the tab.
    The page displays as expected.
  11. Examine the tcpdump in the PuTTy windows.
    On the external VLAN the communication is between the client IP address (10.1.10.190) and the virtual server (10.1.10.200).
    On the internal VLAN the communication is between the client IP address (10.1.10.190) and a back-end web server (10.1.20.x).
  12. In both tcpdump sessions press the Enter key several times to move the log entries to the top of the window.
  13. On the internal VLAN the requests are from the client IP address to a back-end web server, however there are no responses from the web server. You should see repeating SYN requests or Flags [S].
  14. Press the Enter key several times to move the log entries to the top of the window.
  15. In the Configuration Utility you should be in the LAMP virtual server configuration.
  16. From the Source Address Translation list select Auto Map. Notice there are several options to include SNAT, Auto Map, and None.
  17. Use an incognito window to access http://10.1.10.200, and then close the window.
    SNAT Auto Map ensures that responses to server request are always sent back to the BIG-IP system.
  18. Examine the tcpdump window.
    On the external VLAN the communication is still between the client IP address (10.1.10.190) and the virtual server (10.1.10.200).
    On the internal VLAN the communication is now between the BIG-IP internal self IP address (10.1.20.245) and a back-end web server (10.1.20.x).
Task 2 – Use Profiles with a Virtual Server
Profiles are a powerful configuration tool providing an easy way to define traffic policies and apply those policies across virtual servers. Through a profile you can also change a setting for traffic across many different applications.
Profiles provide
  • A centralized place to define specific traffic behavior such as compression, SSL, and authentication that can be applied to multiple virtual servers.
  • A centralized place to change any setting and have them applied to all applications using an existing profile. A profile tells a virtual server how to process packets it receives through the BIG-IP system.
  1. From the Jump Host use a new tab to access http://10.1.10.200, and then select the Stream Profile Example link toward the bottom of the page and examine the text.
    Instead of updating all the web site code we’ll use profiles on the BIG-IP system to update the web site.
  2. Close the tab.
  3. In the Configuration Utility, open the Local Traffic > Profiles > Other > Stream page and click Create.
  4. Use the following information for the profile, and then click Finished.
    Form field Value
    Name name_change
    Source Lorax Bank
    Target Seuss Bank
  5. Open the Virtual Server List page and click LAMP.
  6. From the Configuration list select Advanced.
  7. From the HTTP Profile (Client) list select http.
  8. From the Stream Profile list select name_change.
  9. In the Acceleration section, from the HTTP Compression Profile list select httpcompression.
  10. From the Web Acceleration Profile list select optimized-caching, and then click Update.
  11. Use an incognito window to access http://10.1.10.200, and then select the Stream Profile Example link toward the bottom of the page and examine the text.
    Although the logo need to be updated, all the text on the page now references Seuss Bank.
  12. Remove the Stream Profile, Web Acceleration Profile, and Acceleration profile from the LAMP Virtual Server and update.
Task 3 – Work with Monitors
During this section of the lab we will review many of the available monitors and how to customize them. The BIG-IP system includes a set of pre-defined monitor templates for address, service, content, and interactive checks.
  1. From the Windows Jump host open a new tab in a browser and enter the following URL http://10.1.10.200/HealthCheck.html
    We’re going to use this web page to identify if the web server is up or down.
  2. Close the health check page.
  3. In the Configuration Utility, open the Local Traffic > Monitors page and click Create.
  4. Use the following information for the monitor, and then click Finished.
    Form field Value
    Name LAMP_monitor
    Type http
    Interval 4
    Timeout 13
    Send String GET /HealthCheck.html\r\n
    Receive String SERVER_UP
    Receive Disable String SERVER_DOWN
  5. Open the Pool List page and click LAMP.
  6. Identify the current Availability status of the pool.
    Unknown identifies when a pool or node doesn’t have a configured monitor.
  7. Add LAMP_monitor to the Active list and click Update.
    The Availability of the pool changes to Available (Enabled).
  8. Open the Local Traffic > Nodes > Node List page.
    Notice that all the nodes currently display unknown.
  9. Open the Local Traffic > Nodes > Default Monitor page.
  10. Add gateway_icmp to the Active list and click Update.
  11. Return to the Nodes > Node List page.
    All nodes now display. This means that they are all sending icmp responses.
  12. Open the Local Traffic > Network Map page and view the status for LAMP.
    The virtual server, pool, and all pool members display available.
  13. Use your mouse to hover over the pool members.
    All pool members display available.
Task 4 – Take Lamp_Server1 Offline
  1. From the Windows Jump Host while logged into BIG-IP01 click on Pools, then click on LAMP pool, click the Members tab then click on the LAMP_Server1 then click on the Disabled radio button.
  2. In the Configuration Utility under Local Traffic open the Network Map.
    The first pool member is offline, while the other pool members are available.
Task 5 – Disable all pool members
  1. From the Windows Jump Host while logged into BIG-IP01 click on Pools, click on LAMP pool, click the Members tab, click the check box to select all members and then click on the Disable radio button.
  3. Notice that the virtual server and pool display unavailable.
Task 6 – Bring all pool members back online
  1. From the Windows Jump Host while logged into BIG-IP01 click on Pools, click on LAMP pool, click the Members tab, click the check box to select all members and then click on the Enable radio button.
  2. Use an incognito window to access http://10.1.10.200.
This concludes Lab 2 and a basic overview of Secure Network Address Translation (SNAT), Profiles, and Monitors. Please begin Lab 3.
Optional Extra Credit: Access Ubuntu_LAMP web console and modify /var/www/server/3/HealthCheck.html to change status from UP to DOWN.
sed -i "s/UP/DOWN/g" /var/www/server/3/HealthCheck.html
Check or Refresh the Network Map again and see that pool member LAMP_Server3 is now down/disabled. Set it back to UP.
sed -i "s/DOWN/UP/g" /var/www/server/3/HealthCheck.html
