Taking a Capture from the F5
Let's take the information we have gathered so far and take a packet capture from the F5.
  1. Start Putty and launch the bigip01 SSH session.
  2. Login as root user. Password is 'admin.F5demo.com'.
  3. List the destination address of the virtual on the F5 using the following command:
  4. tmsh list ltm virtual all
    note there is a virtual server named LAMP with a destination ip address of 10.1.10.200
  5. Now take the destination IP address and compose a tcpdump command to track the traffic coming to this virtual server:
    tcpdump -nni 0.0:nnn -s0 -w /var/tmp/lamp.pcap host 10.1.10.200
  6. After starting the capture, start Chrome and access http://10.1.10.200 and refresh the screen a few times.
  7. Stop the capture in the putty session by using 'Ctrl+c'.
  8. Open WinSCP on the Windows jumpbox Desktop. Login to the BIG-IP and download the lamp.pcap file to the local box.
  9. Now open Wireshark and open the lamp.pcap file you just copied from the F5.
