Expose the modern API application on F5XC
In this lab, we will use a modern application based on API first. You can find more details about this app, on Github : https://github.com/f5devcentral/sentence-demo-app
In a nutshell, this application is composed of multiple technology frameworks.
This app will generate a sentence :)
../../../_images/sentence-demo-app.png
App Documentation
Every WORD pod delivers a list of WORDS. Then, the GENERATOR select one WORD per POD, and generates a SENTENCE in a JSON format
../../../_images/topology.png
    "adjectives": "proud",
    "animals": "lion",
    "colors": "blue",
    "locations": "park"
Then, the frontend web application will display all the words in a sentence. If one micro-service is not deployed, the word is not displayed.
In term of micro-services, this is how there are used by the Webapp frontend.
../../../_images/webapp-containers.png
Expose the application on your F5 Distributed Cloud Namespace
The tenant URL for this lab is : https://f5-emea-workshop.console.ves.volterra.io/
For this lab, we will use the following configuration
  1. Create the Origin Pool targeting Sentence public app
  1. Web App & API Protection -> Load Balancers -> Origin Pool -> Add Origin Pool -> Fill the bellow data
    Object Value
    Name sentence-public-endpoint
    Port 80
    TLS Disable
  2. In the same screen -> Origin Servers -> Add Item -> Fill the bellow data -> Apply -> Save and exit
    Object Value
    DNS name sentence.emea.f5se.com
  1. Create the HTTP LB
  1. Web App & API Protection -> Load Balancers -> HTTP Load Balancer -> Add HTTP Load Balancer -> Fill the bellow data -> Save and exit
    Object Value
    Name sentence-re-lb
    Domains sentence-re-$$makeId$$.workshop-sa.emea.f5se.com
    Load Balancer Type HTTP
    Automatically Manage DNS Records Enable <- Don’t forget this option
    Origin Pools Click Add Item, for the Origin Pool select $$namespace$$/sentence-public-endpoint -> Apply
3. So far, Sentence application is not protected but exposed all over the world on all F5XC RE. Check your Sentence application is exposed and reachable from the F5XC Global Network by browsing to http://sentence-re-$$makeId$$.workshop-sa.emea.f5se.com
Warning
Some Service Providers have a very long recursive cache. It can take several minutes to get a DNS response. You can change your DNS server to 1.1.1.1 or 8.8.8.8 to fix that.
