F5 XC EMEA Workshop > Class 4 - API Protection > Expose the API Application Source |
Test your modern API application protectionΒΆ
If you have curl on your machine, go to the next step. Else, connect with SSH or WEBSSH to the Jumphost machine
Run the following curl commands
curl -H "Content-Type: application/json;charset=UTF-8" http://sentence-re-$$makeId$$.workshop-sa.emea.f5se.com/api/adjectives
curl -H "Content-Type: application/json;charset=UTF-8" http://sentence-re-$$makeId$$.workshop-sa.emea.f5se.com/api/animals
curl -H "Content-Type: application/json;charset=UTF-8" http://sentence-re-$$makeId$$.workshop-sa.emea.f5se.com/api/locations
