Enable API traffic discovery
In the previous section, we enabled API Validation in order to enforce protection on what we know from the OpenAPI Spec file. But we kept the Fall Through Mode to Allow so that we do not break the application or impact business down when DevOps push a new version of the API, but SecOps are not ready or up to date.
The API Discovery will provide visility for SecOps in order to see this Drift. This Drift is the difference between what we know and what we see / what is consumed
../../../_images/slide-api-discovery.png
But OWASP Top10 requires also to provide visibility on PII (Personal Identifiable Information) in order to avoid Data Leakage. To do so, we will enable Sensitive Data Disvovery
Enable API Endpoint Discovery
  • If you skipped the lab2 “Enable Code Scanning Discovery, edit your Load Balancer again, go to API Protection and enable API Discovery (keep the default settings)
../../../_images/enable-traffic-discovery.png
Enable Sensitive Data Discovery
OWASP Top10 API requires to detect and discover sensitive datas in Requests and Responses. F5 Distributed Cloud supports this and provides a predefined list (+400) of known PII (Personal Identifiable Information), such as:
  • email
  • credit card number
  • US Social Security Number
  • IP address
Note
By default, a list is already assigned to the Load Balancer
../../../_images/default-pii-setting.png
But if you want to detect your own PII, such as:
  • Country Social Security Number
  • Mobile Phone Number
  • Etc …
You must create your own patterns.
Create custom Sensitive Data Discovery
  • In Sensitive Data Discovery, select Custom
  • Add a new item
    • Give a name: custom-frenchies
    • Select the Compliance Frameworks required for this API Application. We select PCI-DSS GDPR
Note
By selecting PCI-DSS and GDPR, all data patterns classified as PCI-DSS and GDPR will be added.
  • But now, we want to add custom patterns to detect frenchy sensitive datas
  • Configure Defined Custom Sensitive Data Types, and add 2 items
    • Name: france-ssn
      • Data Type Rules:
        • Value Pattern
        • Regex Value : [12][0-9]{2}(0[1-9]|1[0-2])(2[AB]|[0-9]{2})[0-9]{3}[0-9]{3}([0-9]{2})
      • Mark as Sensitive Data
      • Mark as PII
      • Relevant Compliance: GDPR
      ../../../_images/pii-ssn.png
    • Name: france-mobile-phone
      • Data Type Rules:
        • Value Pattern
        • Regex Value : ^(?:(?:\+|00)33|0)\s*[1-9](?:[\s.-]*\d{2}){4}$
      • Mark as PII
  • Apply and Save your LB config
Run the traffic generator script
It is time to run a traffic generator script to populate the logs and the AI/ML engines.
  • SSH or WEBSSH to the Jumphost
  • Run this script into /home/ubuntu/api-protection-lab folder
cd /home/ubuntu/api-protection-lab
bash api-all.sh sentence-re-$$makeId$$.workshop-sa.emea.f5se.com
Note
Please tell your instructor you reached this point.
