Lab 3 - Expose the application to the world
The Customer Edge is up an running in order to expose the inernal K8s application we will need to go through a few steps:
  • CE will discover the K8s
  • Publish the application on the F5 XC platform and define the routing to each service based on the HTTP Path.
  1. First we need to import the kubeconfig file that will be used to access the Kubernetes API in order to discover the application service.
    Go to the Multi-Cloud App Connect -> Manage -> Service Discoveries -> Add Discovery -> Fill in the bellow data -> Save and Exit .
    Object Value
    Name $$kubeconfig$$
    Virtual-Site or Site or Network Site
    Reference system/$$ceOnPrem.clusterName$$
    Network Type Site Local Network
    K8S Discovery Configuration Click on Configure -> Configure -> In the Secret to Blindfold paste the kubeconfig -> Apply -> Apply
  2. In the current view ( Service Discoveries ) click Refresh.
    You can observe that $$kubeconfig$$ has discovered 6 services. Click on the 6 Services and you will be able to see the services and PODs of our application.
  3. Now we configure a HTTP health check that will help us check the availability of the kubernetes cluster and send traffic only to working servers.
    Go to Multi-Cloud App Connect -> Manage -> Load Balancers -> Health Checks -> Add Health Check -> Fill the bellow data -> Save and Exit
    Object Value
    Name arcadia-hc
    HTTP HealthCheck Click Edit Configuration -> Change the Path to /healthz -> Apply
  4. Next we need to create the Origin Pools which will point to our services.
    Go to Multi-Cloud App Connect -> Manage -> Load Balancers -> Origin Pools
    We will need to create 5 Origin Pools each represeting the services that need to be accessed by users, create the Origin Pools based on the bellow data.
  1. Click Add Origin Pool
    Object Value
    Name arcadia-frontend
    Port 80
    Health Checks Click Add Item -> In the new dropdown choose $$namespace$$/arcadia-hc
  2. Under Origin Servers click Add Item -> Fill the bellow data -> Apply -> Save and Exit
    Object Value
    Select Type of Origin Server K8s Service Name of Origin Server on given Sites
    Service Name arcadia-frontend.arcadiacrypto
    Site system/$$ceOnPrem.clusterName$$
    Select Network on the site Outside Network
  3. Repeat steps a and b for the other application services, the only thing that needs to be changed is the Name and Service Name.
    The additional services are:
    Name Service Name
    arcadia-login arcadia-login.arcadiacrypto
    arcadia-stock-transaction arcadia-stock-transaction.arcadiacrypto
    arcadia-stocks arcadia-stocks.arcadiacrypto
    arcadia-users arcadia-users.arcadiacrypto
  1. The last step will be to configure the HTTP Load Balancer that will enable to expose through the F5 XC platform the Kubernetes internal application.
    1. Go to Multi-Cloud App Connect -> Manage -> Load Balancers -> HTTP Load Balancers -> Add HTTP Load Balancer -> Fill the bellow data
      Object Value
      Name arcadia-ce-k8s-lb
      Domains arcadia-ce-k8s-$$makeId$$.workshop.emea.f5se.com
      Load Balancer Type HTTP
      Automatically Manage DNS Records Enable
      Origin Pools Click Add Item, for the Origin Pool select $$namespace$$/arcadia-frontend -> Apply
    2. On the same page go to Routes and click Configure -> Repeat this 4 times for each service ( Add Item -> Fill in the bellow -> Apply )
      Prefix Origin Pools
      /v1/login $$namespace$$/arcadia-login
      /v1/stockt $$namespace$$/arcadia-stock-transaction
      /v1/stock/ $$namespace$$/arcadia-stocks
      /v1/user $$namespace$$/arcadia-users
    3. We are almost done, click Apply -> Save and Exit
    1. All is done our application is published. Let’s check that all is working well.
    Browse to arcadia-ce-k8s-$$makeId$$.workshop.emea.f5se.com and login to the app.
    Object Value
    Username satoshi@bitcoin.com
    Password bitcoin
    Click on the Exchange tab on the left and go buy or sell some crypto currency.
