F5 XC EMEA Workshop > Class 6 - F5 AI Security > F5 AI Guardrails Source |
Projects¶
So far, the scanners that we have created have been defined at a global level.
When we have multiple AI applications and need different policies, we need to use Projects.
When creating a Project it will initially default to the scanner configuration at the global level.
We can also enforce a scanner on all projects if we enable Enforce at the global level.
Let’s create a new project, in the main left tab go to Projects ⇒ Select CalypsoAI chat ⇒ Create ⇒ Set Chat name to Test project ⇒ Create
You can see that the global level scanners have been added automatically to the project.
If we want, we can add more scanners by clicking Add scanners or modify existing ones.
Click on the Prompt injection package and, as you can see, the scanner can be modified for our content.
From now on we will work at the project level.
To confirm everything is working, go to the Chat webpage and in the Project input change it from Global to Test project, then chat within the project.
