GenAI scanner
The GenAI Scanner is a natural-language scanner. What you use when “matching” depends on meaning, intent, or context, not a fixed string/pattern.
For example, if we want to make sure that a person’s specific salary is not leaked but still allow questions about general salary information, we would need to build a GenAI scanner.
  1. In the main left tab go to Scanners ⇒ Build a custom scanner ⇒ GenAI scanner
  2. Set the Name to Specific Salaries
  3. In the Description enter specific individual salary information
  4. Click Save ⇒ Save version
After saving the scanner we find ourselves in the Playground area. Here we can directly test all custom scanners against different text patterns.
  1. Enable Test for the Specific Salaries scanner on the right-hand side of the page.
  2. In the message input area of the Playground enter the text below. This will get blocked because it is a response with someone’s salary.
    Your manager makes $1000000 a year.
  3. Now try the below. This will not be blocked because it is an average.
    The average salary in the HR department is $500000 a year.
