Workshop Volterra 10x > Class1 - F5XC WAAP Use Cases > Module 3 - Use Case 3 - Protect an app running in Public Cloud only Source |
Lab 1 - Expose the private Arcadia application through the Mesh Node only (CE-Only)¶
For this lab, as the Mesh Node is shared between all SE/Students, we will use a fake FQDN/DNS for your LB
. There is one DNS provided by Azure, but so that all of SE/Students can push their own HTTP LB, each of you will use a fake FQDN for the LB. You will add a new entry in your Host file
in order to target the Azure Mesh Node LB public IP addess.
FYI, the public Azure IP address of the node is:
- For EMEA-SE tenant
20.224.0.208
- For F5-EMEA-WORKSHOP tenant
74.234.144.33
- For F5-CHANNEL tenant
20.107.50.6
Create a HTTP LB and expose it on the Mesh Node only¶
If you understand correctly this use case, we want the WAAP policy applied on a HTTP LB exposed on the Mesh Node in Azure only. We don’t want the users/consumers to transit through the F5XC Global Network.
Create a new
HTTP LB
- NOT A HTTPS LB.For the FQDN, use this convention
arcadia-<se_name_or_student_id>-ceonly.fakefqdn.azure
Select the Origin Pool used and created in the previous lab. The private Origin Pool.
Expose this LB on the corresponding site (based on your tenant)
Tenant Site name EMEA-SE tenant demo-waap-emea F5-EMEA-WORKSHOP tenant emea-azure-node F5-CHANNEL tenant azure-emea-waap - In VIP Configuration, enable
Show Advanced Fields
- Advertise Custom
- Create a new custom config (show advanced fields)
- Select the
site according above table
and expose onoutside
interface (the one exposed by the Azure LB)
Assign your WAAP policy
Modify you Host file entries¶
- Modify your host file in order to target the right Azure IP address (look at above which address to use based on your Tenant) for the FQDN created
arcadia-<se_name>-ceonly.fakefqdn.azure
Test your CE-Only lab¶
- As previous labs, connect to your LB and send attacks
Note
As you can notice, in the 3 use cases, we keep consistancy with one WAAP policy whereever the LB or the App reside.
