Last updated on: 2023-05-31 20:07:09.
Lab 2 - Deploy the app in Azure AKS and expose it on Volterra Global Network
../../../_images/archi-lab2.png
Deploy an AKS in Azure
Note
Check your AZ CLI is up and running in the right Tenant (F5 Sales) and Subscription (f5-AZR_4261_SALES_EMEA_SE - 1005fe30-e19e-4091-8480-8b61ecb8106e).
  • az account list
"cloudName": "AzureCloud",
"homeTenantId": "e569f29e-b098-4cea-b6f0-48fa8532d64a",
"id": "1005fe30-e19e-4091-8480-8b61ecb8106e",
"isDefault": true,
"managedByTenants": [
    "tenantId": "dd3dfd2f-6a3b-40d1-9be0-bf8327d81c50"
"name": "f5-AZR_4261_SALES_EMEA_SE",
"state": "Enabled",
"tenantId": "e569f29e-b098-4cea-b6f0-48fa8532d64a",
"user": {
  "name": "M.Dierick@F5.com",
  "type": "user"
  • If needed, you can switch to the EMEA-SE subs : az account set –subscription “f5-AZR_4261_SALES_EMEA_SE”
  • Clone this Git to your laptop (dev branch) : https://github.com/f5devcentral/volterra-workshop-10x
  • In the dev branch, enter to the folder labs-content/class3/terraform
  • Modify variables.tf according your project.
    Warning
    Volterra does not support objects > 64 characters. So, use short name in your prefix and cluster name. 10 characters max per variable.
    variable "resource_prefix" {
    default = "Matt"
    variable "cluster_name" {
    default     = "akscluster"
    description = "K8S Cluster for Matt"
    variable "location" {
    default     = "westeurope"
    description = "The Azure Region in which all resources in this example should be provisioned"
    variable "vm_size" {
    default     = "Standard_B2ms"
    description = "2 vpus, 8 GiB memory"
  • Deploy your Terraform plan
    terraform init
    terraform plan
    terraform apply
    Note
    Do not close your terminal, because the outcomes will be used in the next step to download your kubeconfig
  • Get your kubeconfig file from yoru Azure AKS :
    az aks get-credentials --resource-group <YOUR-RG> --name <YOUR_CLUSTER_NAME> --file kubeconfig-myname
Publish the App without Colors microservice
  • Use your favorite k8s client (kubectl, Lens …) and connect to your cluster
  • Deploy the 2 manifests to publish the sentence app on your AKS
    • Deploy labs-content/class3/k8s-deployments/aks-sentence-deployment.yaml
    • Deploy labs-content/class3/k8s-deployments/aks-sentence-deployment-nginx.yaml
Note
Wait few seconds, and try to connect to the Azure LB created by the manifest
../../../_images/colors-only.png
Expose the app with F5 Distributed Cloud
  • DELETE the labs-content/class3/k8s-deployments/aks-sentence-deployment-nginx.yaml manifest so that we can now push the same without a LB
  • PUSH the labs-content/class3/k8s-deployments/aks-sentence-deployment-nginx-private.yaml manifest
Note
Check the LB service is deleted. If not, delete it manually.
Note
Now, Sentence app is not published externally. A voltNode is required to access the app.
Deploy a new Azure Vnet Site
  • First, in Azure Portal, create a new Subnet in your Vnet. The Terraform only created one Subnet (10.240.0.0/16). This subnet is our private subnet.
    • Create a new subnet in the same Vnet (10.241.0.0/16). Name it aks-subnet-public.
  • Deploy a Azure VNET Volterra Node (Dual NIC) and assign the existing private and public subnets from your AKS Vnet.
    Note
    The resource group must be a new resourve group. You can’t use an existing one.
    ../../../_images/azure-site.png ../../../_images/subnet.png
    • For the Cloud Credentials, select azure-emea-se
    • Paste your public SSH key in case you need to connect to it for troubleshooting
  • Apply the Azure Vnet Site
  • WAIT and upgrade the node from the VotlConsole if required.
Discover the services
  • Create a service discovery
    • Select your site, select site local inside network and upload your kubeconfig file
    • In VIP Publishing Configuration settings, Don’t forget to publish fully qualified domain to VIP mapping
    Warning
    There is a known bug here, this can take up to 15 minutes to display the services.
    ../../../_images/sd.png
  • You should see all services + nginx as a nodeport
    ../../../_images/sd-ok.png
Create an Global Load Balancer and expose Sentence App
  • Create an Origin Pool with Nginx Frontend webserver as a member
    • Select k8s service type
    • Enter service name (copy paste from service discovery)
    • Select Inside network
    • Port 80 (port of the service in K8S)
    Note
    Team discussion : How does Volterra manage to find the right back-end pool member (analogy to BIG-IP) ??? Check the LB and origin pool status.
  • Create an LB to expose the Nginx Frontend webserver
    • Domain : sentence-<myname>.emea-ent.f5demos.com
    • HTTPS auto-cert
    • Select your Origin Pool
Note
Test your deployment
