Deploy F5 Insight Services on VMware ESXi / vSphere¶
This guide walks you through the process of deploying an F5 Insight Services virtual machine instance from a pre-built OVA image on VMware ESXi 7.x+ or vSphere.
Overview¶
F5 Insight Services is a comprehensive monitoring and analytics platform designed specifically for F5 BIG-IP devices. It delivers powerful capabilities to help you manage and optimize your infrastructure:
Benefits and key features¶
- Real-time Device Monitoring: Continuously monitors F5 BIG-IP devices at configurable intervals
- AI-Powered Insights: Leverages artificial intelligence to analyze metrics and provide intelligent recommendations
- Advanced Data Pipeline: Built on OpenTelemetry with Prometheus for metrics collection and ClickHouse for high-performance data storage
- Modern UI: Features a React-based dashboard with customizable visualizations
- External Grafana Integration: Seamlessly integrates with external Grafana instances for advanced dashboards and analytics
By following this guide, you will successfully deploy F5 Insight Services as a virtual machine on your VMware infrastructure using the pre-built OVA image, giving you immediate access to powerful monitoring and analytics capabilities for your F5 BIG-IP environment.
Prerequisites¶
Before you begin, ensure you have the following requirements in place:
VMware environment specifications¶
Your VMware infrastructure must meet these specifications:
| Specification | Requirement |
| Platform Version | VMware ESXi 7.0+ or vCenter Server / vSphere Client 7.0+ |
| Administrative Access | Administrative access to the ESXi host or vCenter |
| Storage | Datastore with at least 650GB of available space (thick provisioned) |
| Networking | Network port group configured with connectivity to BIG-IP devices |
Minimum hardware requirements (F5 Insight VM)¶
| Resource | Minimum specification | Sizing / planning notes |
| CPU | 12 vCPUs | 8 vCPUs are dedicated to analytics and data processing workloads. An additional 4 vCPUs are allocated for BIG-IP management functions such as upgrades, patching, and maintenance. |
| CPU scalability | +6 vCPUs per additional 50 BIG-IP instances | The base 12 vCPU allocation supports approximately 50 BIG-IP instances. Add 6 vCPUs for every additional 50 BIG-IP instances to maintain analytics and management performance. |
| Memory | 16 GB RAM | Standard minimum memory requirement for F5 Insight deployment and operation. |
| Memory scalability | +4 GB RAM per additional 50 BIG-IP instances | The base 16 GB RAM allocation supports approximately 50 BIG-IP instances. Add 4 GB RAM for every additional 50 BIG-IP instances to accommodate increased analytics workload and data processing requirements. |
| Disk storage | 650 GB total | Includes 500 GB for the initial F5 Insight installation and 150 GB for the operating system, upgrades, and updates. |
| Storage scalability | +500 GB per additional 50 BIG-IP instances | The initial 500 GB allocation supports approximately 50 BIG-IP instances. Plan for an additional 500 GB of storage capacity for every subsequent group of 50 BIG-IP instances. |
Network requirements¶
Ensure the following network connectivity:
| Category | Requirement / Rule | Direction |
| External Access | Connectivity from F5 Insight to product.apis.f5.com:443 for “connected” license activation and updates. (optional if using Disconnected Mode Licensing)
See Licensing and Entitlement for Disconnected Mode Licensing for environments that do not allow outbound internet access. |
Outbound |
| External Access | Connectivity from F5 Insight to us.edge.df.f5.com:443 for F5 AI Data Fabric (AIDF) (optional) |
Outbound |
| External Access | Connectivity from F5 Insight to OpenAI compatible/Anthropic server for LLM Insights (optional) | Outbound |
| Internal Access | Connectivity from F5 Insight to BIG-IP devices | Outbound |
| Internal Access | Connectivity from F5 Insight to OpenAI compatible server for LLM Insights (optional) | Outbound |
| Firewall (SSH) | Port 22 | Inbound to F5 Insight |
| Firewall (HTTPS) | Port 443 | Inbound to F5 Insight |
| Firewall (Mgmt) | Port 443 | Outbound to BIG-IP Management Port |
Architecture overview¶
F5 Insight Services operates as a collection of containerized microservices orchestrated by K3s, a lightweight Kubernetes distribution designed for resource-efficient deployments.
Key components¶
Kubernetes Platform:
- K3s: Lightweight Kubernetes distribution (automatically installed)
- Helm: Package manager for Kubernetes (pre-installed)
Application Services:
- Container Images: All service images are pre-loaded during image build
- Persistent Storage: F5 Insight stores data in persistent storage
Download the F5 Insight OVA image¶
Steps to obtain the OVA:
- Navigate to my.f5.com and enter your credentials
- Scroll down to the bottom of the page and choose f5insight-<version>.ova
- Save the file to a location accessible from your browser or workstation
Deploy the OVA on vSphere / ESXi¶
Using the vSphere client (Web UI - HTML5 GUI)¶
Open the vSphere Client
- Navigate to your vSphere or ESXi web interface:
# vCenter: https://<VCENTER_HOST>/ui # ESXi: https://<ESXI_HOST>/ui
- Log in using your administrator credentials.
Start the OVF/OVA Deployment Wizard
- In vCenter: Right-click a host, cluster, or resource pool and select Deploy OVF Template
- In ESXi standalone: Select Create / Register VM, then select Deploy a virtual machine from an OVF or OVA file
- Select Next to proceed.
Select the OVA File
- Select Choose Files or drag-and-drop the OVA file into the wizard
- Browse to and select your f5insight-<VERSION>.ova file
- The wizard will parse the OVF descriptor and display the VM name
- Select Next
Name and Location
- Enter the VM name: f5-insight-01 (or your preferred name)
- Select the target datacenter or folder (vCenter only)
- Select Next
Select Compute Resource
- Select the ESXi host, cluster, or resource pool where the VM will run
- Select Next
Review Details
- Verify the OVA details: disk size, network, CPU, and memory
- Select Next
Select Storage
- Select the target datastore with at least 650GB of available space
- Set Virtual disk format to Thick Provision Lazy Zeroed (recommended for performance)
- Select Next
Note
Thick Provision Eager Zeroed offers slightly better write performance but takes longer during deployment as it zeroes all allocated blocks. Thick Provision Lazy Zeroed is a good balance for most deployments.
Select Networks
- Map the VM Network in the OVA to the appropriate port group on your ESXi host
- Select the port group that provides connectivity to both your management network and BIG-IP devices
- Select Next
Note
Choose the network port group that provides connectivity to your BIG-IP devices. Consult your network or vSphere administrator if unsure which port group to select.
Ready to Complete
- Review all deployment settings
- Do NOT check “Power on after deployment” - we need to adjust settings and set cloud-init guestinfo parameters first
- Select Finish
Wait for the deployment task to complete. This may take several minutes depending on network speed and datastore performance.
Adjust VM settings after import¶
After the OVA deployment completes, review and adjust the VM settings to ensure they meet F5 Insight requirements.
- Edit VM Settings
- Right-click the VM and select Edit Settings
- Verify CPU
- Confirm CPU is set to 12 vCPUs
- If your host supports it, you can increase vCPUs for heavier workloads
- Verify Memory
- Confirm Memory is set to 16 GB
- Uncheck Reserve all guest memory unless you want guaranteed memory allocation
- Verify Disk Size
- Under Hard disk 1, confirm the disk size is 650 GB
- If the disk imported at a smaller size, increase it to 650GB
- Ensure Disk Provisioning shows Thick Provision
- Verify Network Adapter
- Confirm the network adapter type is VMXNET3
- Confirm it is connected to the correct port group
- Ensure Connect At Power On is checked
- Enable VMware Tools (Optional)
- Under VM Options > VMware Tools, check Sync guest time with host
- Select OK to save all changes
Configure a static IP address before first boot using Cloud-Init for VMware ESX¶
Note
If DHCP is not available on your management network, you must configure a static IP address before powering on the VM. Refer to Configure a Static IP Address Before First Boot Using Cloud-Init for more details.
Configure Cloud-Init¶
F5 Insight uses Cloud-Init for initial user provisioning. On VMware ESXi and vSphere, you can pass Cloud-Init directly through VMware advanced virtual machine (VM) parameters using guestinfo.userdata.
Prepare cloud-config and Base64 encode¶
Create a local
cloud-config.ymlfile:#cloud-config chpasswd: expire: true users: - name: admin # Change the password below to your desired password password: "F5ChangeM3" type: text
Important
Do not remove
#cloud-configfrom the top of the file. This line is required for cloud-init to recognize the payload.Base64-encode the file contents.
Use one of the following options based on your platform:
Warning
Ensure the Base64 output is a single line with no extra spaces or line breaks, as it will be pasted directly into the vSphere advanced configuration.
Windows uses unique newline characters (CRLF), so the encoding commands below normalize newlines to ensure compatibility with cloud-init’s expected format.
# macOS (BSD base64) base64 -i cloud-config.yml | tr -d '\n' # Linux (GNU coreutils base64) base64 -w 0 cloud-config.yml
# Windows PowerShell / PowerShell 7+ [Convert]::ToBase64String([Text.Encoding]::UTF8.GetBytes(((Get-Content -Raw .\cloud-config.yml) -replace "`r`n?", "`n")))
# Portable option (Python 3 on macOS/Linux/Windows) python -c "import base64,pathlib;d=pathlib.Path('cloud-config.yml').read_bytes().replace(b'\r\n',b'\n').replace(b'\r',b'\n');print(base64.b64encode(d).decode())"Optional browser helper:
Download the cloud-config Base64 helper (HTML)Right-click the link above and select Save link as… to download the standalone helper page.
Copy the single-line Base64 output; you will paste it into vSphere in the next step.
Configure guestinfo in vSphere UI¶
Open VM settings:
- In the vSphere Client, right-click the F5 Insight VM and select Edit Settings
Add VMware advanced configuration parameters:
Select the VM Options tab
Expand Advanced and select Edit Configuration
Add:
guestinfo.userdata.encoding=base64guestinfo.userdata=<PASTE_BASE64_FROM_PREVIOUS_STEP>
Select OK to save
Ensure the
guestinfo.userdatavalue is a single line with no extra spaces or line breaks.
Start the VM¶
Once the VM settings are verified and guestinfo parameters are set:
- Right-click the VM and select Power > Power On
- Open the Console tab (or launch the web console / VMRC) to monitor the boot process
The VM will boot into F5 Insight and begin its first-boot initialization.
Initial VM configuration¶
Wait for First Boot to Complete
The F5 Insight VM runs an automated first-boot setup script that:
- Initializes K3s cluster
- Deploys all services via Helm
- Configures persistent storage
- Sets up secrets and certificates
This takes approximately 5-10 minutes.
Monitor the first boot progress:
# SSH into the VM (use the IP address shown in the console or vSphere summary) ssh admin@<VM_IP_ADDRESS> # Watch the first boot logs sudo tail -f /opt/f5insight/logs/f5insight-startup.log # Check systemd service status sudo systemctl status f5insight-first-boot.service # When complete, you should see: # f5insight-first-boot.service - F5 Insight First Boot Setup # Loaded: loaded (/etc/systemd/system/f5insight-first-boot.service; enabled) # Active: inactive (dead) since ...
Note
You can find the VM’s IP address in the vSphere Client under the VM’s Summary tab, or from the Console tab after boot.
Verify services are running
# Check K3s status sudo systemctl status k3s # Check all pods in f5-insight namespace sudo kubectl get pods -n f5-insight # Expected output (all pods should be Running or Completed): # NAME READY STATUS RESTARTS AGE # backend-xxxx 2/2 Running 0 45s # cacher-xxxx 2/2 Running 0 45s # clickhouse-0 2/2 Running 0 44s # f5-insight-node-exporter-xxxx 2/2 Running 0 45s # f5-insight-postgres-0 2/2 Running 0 44s # f5-insight-postgres-init-xxxx 0/1 Completed 0 44s # f5-insight-vault-0 3/3 Running 0 44s # frontend-xxxx 2/2 Running 0 45s # otel-collector-xxxx 2/2 Running 0 45s # system-manager-xxxx 2/2 Running 0 45s # victoriametrics-0 2/2 Running 0 44s # vmagent-xxxx 2/2 Running 0 45s # vmalert-xxxx 2/2 Running 0 45s # Check services sudo kubectl get svc -n f5-insight
Verify network connectivity
# Test external connectivity curl -I https://www.google.com # Check if VM can reach your BIG-IP devices ping <BIGIP_IP_ADDRESS> telnet <BIGIP_IP_ADDRESS> 443
Accessing F5 Insight Services¶
Once the VM is fully initialized, you can access the services:
Web interface¶
| Service | URL | Default Credentials |
| F5 Insight UI | https://<VM_IP> | Credentials provisioned via cloud-init |
First time access¶
- Open F5 Insight UI: https://<VM_IP>:443
- Login with the credentials you configured in cloud-init
Post-Installation configuration and licensing¶
- Login with your credentials to F5 Insight at https://<VM_IP>:443
- Once you login, select “Get Started”
- Input your JWT and select “Validate & Activate License”
Configure AI provider API keys¶
- Select your LLM provider and fill in the corresponding credentials, then select “Save & Continue”
- Insert your AIDF credentials. You can get the credentials from your account team. However, for now during beta, please select “Skip for Now”
Add BIG-IP devices to F5 Insight¶
Once you press “Skip for Now” you will be greeted with a page to “Start Fresh” or “Import configuration from Existing Application Study Tool Instance.”
If you choose to “Start Fresh” you will have the option to add a CA, add devices via YAML, or add individual devices manually. In addition, you must choose which module or data you would like to see populated.
Note
We recommend using a CA when adding devices, but that configuration is optional.
Note
In addition, we are going to ask that you sort your BIG-IP devices by datacenter. Tagging of devices to a specific datacenter is crucial in providing timely alerts, cross comparison of performance, and much more.
If you choose to go the YAML route, please paste the appropriate configuration files when prompted.
Once done, you will be sent to the homepage.
Configure BIG-IP for additional application logs/telemetry¶
F5 Insight’s OTEL Syslog receiver will be listening on port 30514 for SSLO logs and iRule telemetry.
On BIG-IP (via TMSH or GUI):
Refer to Application telemetry and F5 AI Data Fabric guide for more details.
Appendix: CLI-Only deployment with ovftool¶
For administrators who prefer the command line, VMware’s ovftool can deploy an OVA directly to ESXi or vCenter without the GUI.
Install ovftool¶
Download ovftool from VMware’s developer portal (requires a Broadcom account):
# https://developer.broadcom.com/tools/open-virtualization-format-ovf-tool/latest
# Install per VMware's instructions for your platform
# Verify installation
ovftool --version
Deploy the OVA¶
# Variables - Customize these values
OVA="f5insight-<VERSION>.ova"
VM_NAME="f5-insight-01"
ESXI_HOST="<ESXI_HOST>"
ESXI_USER="root"
DATASTORE="<DATASTORE_NAME>"
NETWORK="VM Network" # Your port group name
CLOUD_CONFIG_FILE="cloud-config.yml"
# Encode user-data as a single-line Base64 string for guestinfo.userdata
USERDATA="$(base64 < "$CLOUD_CONFIG_FILE" | tr -d '\n')"
# Option 1: Deploy directly to ESXi host
ovftool \
--name="$VM_NAME" \
--datastore="$DATASTORE" \
--network="$NETWORK" \
--diskMode=thick \
--powerOffTarget \
--allowExtraConfig \
--extraConfig:guestinfo.userdata.encoding="base64" \
--extraConfig:guestinfo.userdata="$USERDATA" \
--acceptAllEulas \
"$OVA" \
"vi://${ESXI_USER}@${ESXI_HOST}/"
# Option 2: Deploy via vCenter
VCENTER="<VCENTER_HOST>"
DATACENTER="<DATACENTER_NAME>"
CLUSTER="<CLUSTER_NAME>"
ovftool \
--name="$VM_NAME" \
--diskMode=thick \
--powerOffTarget \
--acceptAllEulas \
"$OVA" \
"vi://${ESXI_USER}@${VCENTER}/${DATACENTER}/host/${CLUSTER}/"
Note
You will be prompted for the ESXi or vCenter password. Add --password=<PASS> to skip the prompt (not recommended for shared scripts).
Post-Deploy CLI steps¶
After deploying via ovftool, you still need to set cloud-init guestinfo parameters and adjust VM settings. The vSphere Client GUI is the most straightforward way to do this:
- Generate a Base64 cloud-config payload and set
guestinfo.userdataandguestinfo.userdata.encoding(see the Configure Cloud-Init section above) - Verify CPU, memory, disk, and network settings
- Power on the VM
Alternatively, if you have SSH access to the ESXi host:
# Find the VM ID
vim-cmd vmsvc/getallvms | grep f5-insight
# Power on the VM (after setting guestinfo via GUI)
vim-cmd vmsvc/power.on <VMID>
# Check power state
vim-cmd vmsvc/power.getstate <VMID>
# Get the VM IP (requires VMware Tools)
vim-cmd vmsvc/get.guest <VMID> | grep ipAddress
Note
For most post-deploy adjustments (CPU, memory, disk resize, guestinfo parameters), the vSphere Client GUI is more straightforward than CLI. The ovftool CLI is most useful for automating the initial OVA deployment step.
