External authentication and role-based access control¶
Overview¶
F5 Insight now supports external authentication, enabling enterprise customers to integrate with their existing identity infrastructure for centralized user management and secure access control.
Previously, F5 Insight supported only a single local administrator account (username: admin, password: SSH-configured password). With this release, administrators can configure external authentication providers, allowing multiple users to log in using their corporate credentials with role-based access control.
What’s new¶
| Feature | Description |
| External Authentication | Authenticate users via corporate LDAP or SAML identity providers |
| Supported LDAP Providers | Open LDAP |
| Supported SAML Providers | Ping, Okta |
| Role-Based Access Control (RBAC) | Three predefined roles - Admin, Operator, Viewer - controlling access to features and API endpoints |
| Role Mapping | Map external identity provider groups to F5 Insight roles |
Authentication methods (existing)¶
F5 Insight supports two authentication methods:
Local authentication¶
Local authentication uses the built-in administrator account created during installation.
| Attribute | Details |
| Username | admin |
| Password | Configured during system setup (SSH password) |
| Access Level | Full administrator access |
| Limitation | Single user only; no role differentiation |
External authentication (new)¶
External authentication allows users to log in using credentials managed by a corporate identity provider.
| Provider Type | Supported Providers | Protocol | Description |
| LDAP | Open LDAP | LDAP v3 | Directory-based authentication using LDAP credentials |
| SAML | Ping, Okta | SAML 2.0 | Single Sign-On (SSO) authentication via SAML identity providers |
Note
Custom identity provider implementations outside of the supported LDAP (Open LDAP) and SAML (Ping, Okta) providers are not supported in this release.
Login flows¶
Login screen¶
After an external authentication provider is configured and activated, the F5 Insight login screen displays additional log-in options:
- Local Login: Standard username and password fields for the built-in admin account.
- External Login: One or more buttons labeled “Sign in with <Provider Name>” for each configured external provider.
The provider name displayed on the login screen corresponds to the name configured by the administrator during provider setup.
Local user login¶
- Navigate to the F5 Insight login page (
https://<f5-insight-ip>). - Enter the local username and password.
- Select Sign In.
- Upon successful authentication, you are redirected to the F5 Insight dashboard.
LDAP login¶
- Navigate to the F5 Insight login page.
- Select Sign in with <LDAP Provider Name> (for example,
Log in with <LDAP Provider Name>). - You are redirected to the LDAP credential screen.
- Enter your LDAP username and password.
- Upon successful authentication, you are redirected to the F5 Insight dashboard with permissions based on your assigned role.
SAML login¶
- Select Sign in with <SAML Provider Name> (for example, “Log in with Okta” or “log in with Ping”).
- You are redirected to an intermediate authentication screen.
- On the intermediate screen, select the SAML log-in option again to proceed to the IdP authentication page.
- Enter the SAML credentials on the IdP authentication page.
Warning
Known Issue: In SAML login scenarios, selecting the external IdP log-in option redirects users to an intermediate screen. Users must select the SAML log-in option one more time to reach the IdP authentication page.
Note
By default, remote authentication uses an IP address for login page links and external auth endpoints. Use f5insight-set-fqdn to set a stable hostname instead. Using an FQDN is recommended for TLS certificate hostname validation, better user experience (friendly login URLs), and stable identity across IP changes. For more information, see Remote Authentication FQDN.
Session management¶
| Behavior | Details |
| Access Token Expiry | Tokens expire after 5 minutes |
| Automatic Refresh | Tokens are refreshed automatically in the background. No user action required |
| Session Timeout | If token refresh fails, you are redirected to the login page |
| Logout | Select the logout option to end your session |
Note
Access tokens are stored in browser memory only and are never persisted to local storage, ensuring enhanced security.
Configuring identity providers (administrator only)¶
Important
You must be logged in as an Admin user to configure identity providers.
Configuring an LDAP provider¶
- Log in to F5 Insight as an administrator.
- Navigate to .
- Select LDAP.
- Fill in the required configuration fields:
| Field | Description | Required |
| Provider Name | Display name for the provider (appears on the login screen) | Yes |
| Server URL | LDAP server hostname or IP address with port (for example, ldap://ldap.example.com:389 or ldaps://ldap.example.com:636) |
Yes |
| Base DN | Base Distinguished Name for user search queries | Yes |
| Bind DN | Distinguished Name used to authenticate with the LDAP server | Yes |
| Bind Password | Password for the Bind DN account | Yes |
| LDAP Attributes | Mapping of LDAP attributes to user properties (for example, mail, username, and so on) | Yes |
| Userbase DN | User search base DN | Yes |
| User filters | User lookup attribute key (for example, uid); do not use a full LDAP filter expression |
Yes |
| User object | LDAP object class used for user entries | Yes |
- Select Save to store the configuration.
- Select Create to enable the provider on the login screen.
Note
After activation, a “Log in with <Provider Name>” button appears on the login page immediately.
Note
For LDAP configuration, set User filters to uid in the example flow. Do not enter a full LDAP filter string such as (&(objectClass=inetOrgPerson)(uid={0})) in that field.
Note
The LDAP server must be reachable on a standard LDAP port: 389 for LDAP (or LDAP with StartTLS) and 636 for LDAPS. Make sure firewall and network policy rules allow traffic from F5 Insight to the selected port.
LDAP configuration notes and sample LDIF expectations¶
The following values represent the expected LDAP entry patterns used by OpenLDAP deployments similar to the sample data used for F5 Insight validation.
Expected user object classes and attributes¶
User entries are expected under a people container such as ou=People,dc=ldap,dc=example,dc=com with object classes:
personorganizationalPersoninetOrgPerson
Common user attributes expected by provider mapping:
uid: login identifier (for example,adminuser)mail: email addresscn: display namegivenName: first namesn: last nameuserPassword: LDAP bind password hash
Expected group object classes and attributes¶
Group entries are expected under a groups container such as ou=Groups,dc=ldap,dc=example,dc=com.
Dual-compatible group entries can include both:
groupOfUniqueNameswithuniqueMemberDN valuesposixGroupwithgidNumberandmemberUidvalues
This supports both DN-based and POSIX username-based membership lookup.
Sample LDIF entry shapes¶
dn: uid=adminuser,ou=People,dc=ldap,dc=example,dc=com
objectClass: person
objectClass: organizationalPerson
objectClass: inetOrgPerson
uid: adminuser
mail: adminuser@ldap.example.com
cn: Addy Ministrator
givenName: Addy
sn: Ministrator
userPassword: {SSHA}<hash>
dn: cn=admin,ou=Groups,dc=ldap,dc=example,dc=com
objectClass: groupOfUniqueNames
objectClass: posixGroup
cn: admin
gidNumber: 10002
uniqueMember: uid=adminuser,ou=People,dc=ldap,dc=example,dc=com
memberUid: adminuser
Associated OpenLDAP search commands¶
Use these commands to validate expected directory content and group mapping behavior.
# Base user lookup by uid
ldapsearch -x -H ldap://localhost \
-b ou=People,dc=ldap,dc=example,dc=com \
-D "cn=admin,dc=ldap,dc=example,dc=com" -w ldappass \
"(uid=adminuser)" dn uid mail cn givenName sn
# Inspect one group and verify dual object classes and membership attributes
-b ou=Groups,dc=ldap,dc=example,dc=com \
"(cn=admin)" dn objectClass gidNumber uniqueMember memberUid
# POSIX-style group membership query
"(memberUid=adminuser)" dn cn
# Dual-mode membership query (DN-based OR POSIX-style)
"(|(uniqueMember=uid=adminuser,ou=People,dc=ldap,dc=example,dc=com)(memberUid=adminuser))" dn cn
Recommended LDAP provider mapping values¶
- User search base:
ou=People,dc=ldap,dc=example,dc=com - User object class:
inetOrgPerson - Username attribute:
uid - Email attribute:
mail - Display name attribute:
cn - First name attribute:
givenName - Last name attribute:
sn
Configuring a SAML provider¶
- Navigate to .
- Select SAML.
| Metadata XML / URL | SAML metadata obtained from the IdP (Ping or Okta) | Yes |
| Binding | SAML binding type: POST or Redirect | Yes |
Note
The administrator must first configure F5 Insight as a trusted Service Provider on the IdP (Ping or Okta), obtain the SAML metadata XML or URL, and then paste it into the F5 Insight configuration.
Part 2: Configure Okta¶
Initial F5 Insight for Okta¶
- Navigate to System Management -> User Administration -> SSO/Identity Providers.
- Select SAML from the available providers.
- Provide a name, metadata XML or metadata URL, and binding.
Note
We recommend to create the Okta application before starting this step. When initially creating the Okta SAML 2.0 application, the IAM administrator must supply placeholder values for Single Sign-On URL and Audience URI (SP Entity ID), for example https://<insight_fqdn_or_ip>. This allows working Metadata URL or XML values from the Okta app to be entered during F5 Insight provider setup.
Example App Values
| Property | Value |
| App Type | SAML 2.0 |
| App Name | F5 Insight |
| Single sign-on URL | https://<f5insight_fqdn_or_ip> |
| Audience URI (SP Entity ID) | https://<f5insight_fqdn_or_ip> |
| Name Format | EmailAddress |
| Application Username |
- Save the provider.
- Select Edit for the new provider and expand the SAML Metadata section.
- Note the following values from F5 Insight:
- SAML Metadata URL (Audience URI / SP Entity ID)
- SAML ACS Intent API URL (Single sign-on URL)
Update the Okta application¶
- Log in to the Okta Admin Console and navigate to .
- Select the previously created application.
- Configure SAML settings:
- Single Sign-On URL: Paste the SAML ACS Intent API URL copied from F5 Insight.
- Audience URI (SP Entity ID): Paste the SAML Metadata URL copied from F5 Insight.
- Go to and add the required user attributes (set format to
Basic).
| Name | Value |
user.email |
| lastname | user.lastName |
| firstname | user.firstName |
| username | user.email |
| displayname | user.displayName |
- Add a Group Attribute Statement:
- Name:
groups - Name format:
Unspecified - Filter: Select Matches regex and input
- Name:
- Save the application.
Managing identity providers¶
| Action | Steps |
| View Providers | Navigate to Settings > User Administration > SSO Identity Providers to view all configured providers |
| Activate Provider | Select Activate on a configured provider to enable it on the login page |
| Deactivate Provider | Select Deactivate to remove the provider from the login page without deleting the configuration |
| Edit Provider | Select the provider and update the configuration fields, then select Save Changes |
| Delete Provider | Select the provider and select Delete to remove the configuration |
| Test Provider | Use the Validate option to test the provider configuration before activating |
Note
Editing an LDAP provider: LDAP edit configuration requires a password to enable the test connection button.
Note
The Test Connection option is available for LDAP providers only. It validates the LDAP connection and retrieves the available LDAP groups.
API configuration¶
Identity providers can also be managed using the F5 Insight REST API.
Identity Provider Endpoints
| Method | Endpoint | Description |
GET |
/auth/identity-providers |
List all configured identity providers |
POST |
/auth/identity-providers/ldap |
Create a new LDAP provider |
POST |
/auth/identity-providers/saml |
Create a new SAML provider |
GET |
/auth/identity-providers/{id} |
Get details of a specific provider |
PUT |
/auth/identity-providers/ldap/{id} |
Update an LDAP provider |
PUT |
/auth/identity-providers/saml/{id} |
Update a SAML provider |
DELETE |
Delete a provider |
POST |
/auth/identity-providers/{id}/activate |
Activate a provider |
POST |
/auth/identity-providers/{id}/deactivate |
Deactivate a provider |
POST |
/auth/identity-providers/validate |
Test a provider configuration |
Note
Refer to the F5 Insight API Documentation for detailed request/response schemas, payload examples, and authentication requirements.
Role-Based Access Control (RBAC)¶
F5 Insight enforces Role-Based Access Control (RBAC) to manage what each user can access and perform within the platform.
Predefined roles¶
| Role | Description | Access Level |
| Admin | Full system access including user management, device configuration, and all settings | Full read/write access to all features and API endpoints |
| Operator | Device configuration and troubleshooting | Read/write access to devices, provisioning, telemetry, and system management. No access to User Administration |
| Viewer | Read-only access for monitoring and observation | View-only access to dashboards, devices, and configurations. Cannot add, edit, or delete resources |
Role permissions matrix¶
Admin Role - Full Access
| Feature Area | GET | POST | PUT/PATCH | DELETE |
| Device Management | Yes | Yes | Yes | Yes |
| Telemetry | Yes | Yes | Yes | Yes |
| AI Integrations | Yes | Yes | Yes | Yes |
| Provisioning | Yes | Yes | Yes | Yes |
| System Management | Yes | Yes | Yes | Yes |
| License Management | Yes | Yes | Yes | Yes |
| User Management | Yes | Yes | Yes | Yes |
| Dashboards | Yes |
Operator Role - Operational Access
| Device Management | Yes | Yes | Yes | No |
| Telemetry | Yes | Yes | Yes | No |
| AI Integrations | Yes | Yes | Yes | No |
| Provisioning | Yes | Yes | Yes | No |
| System Management | Yes | Yes | No | No |
| License Management | Yes | Yes | Yes | No |
| Dashboards | Yes |
Viewer Role - Read-Only Access
| Device Management | Yes | No | No | No |
| Telemetry | Yes | No | No | No |
| AI Integrations | Yes | No | No | No |
| Provisioning | Yes | No | No | No |
| System Management | Yes | No | No | No |
| License Management | Yes | No | No | No |
| User Management | No | No | No | No |
| Dashboards | Yes |
Default role assignment¶
| Scenario | Assigned Role |
| Local admin user | Always Admin |
| External user with a matching group attribute | Role as per group-to-role mapping (Admin, Operator, or Viewer) |
| External user with no group attribute configured | Defaults to Viewer |
UI access by role¶
| Feature / Section | Admin | Operator | Viewer |
| Dashboards | View - Yes | View - Yes | View - Yes |
| Devices - View | Yes | Yes | Yes |
| Devices - Add/Edit/Delete | Yes | Add/Edit - Yes | No |
| User Administration | Yes | No | No |
| System Settings | Yes | Yes (limited) | No |
| AI Chat | Yes | Yes | Yes |
| F5 Insight Upgrade | Yes | Yes | Yes |
Role mapping (administrator only)¶
Role mapping determines which F5 Insight role an external user receives upon login. Roles are assigned based on group attributes configured on the LDAP or SAML identity provider.
Navigate to Settings > User Administration > Role > Role Mapping
How role mapping works¶
- The administrator configures a group attribute on the LDAP or SAML server for each user or user group.
- When an external user logs in to F5 Insight, the system reads the group attribute from the authentication response.
- F5 Insight maps the attribute value to the corresponding role (Admin, Operator, or Viewer).
- The user is granted access based on the mapped role.
- If no matching group attribute is found, the user is assigned the Viewer role by default.
Configuring role mapping¶
- Navigate to Settings > User Administration > Role > Role Mapping.
- Select the configured identity provider (LDAP or SAML).
- Specify the group attribute name that the IdP uses to indicate the user’s role.
- Map the attribute values to F5 Insight roles:
| IdP Group Attribute Value | F5 Insight Role |
(configured by admin, example, f5-admin) |
Admin |
(configured by admin, example, f5-operator) |
Operator |
(configured by admin, example, f5-viewer) |
Viewer |
| (no attribute or unmatched value) | Viewer (default) |
- Select Save.
Example - LDAP role mapping¶
| LDAP User | Group Attribute Value | F5 Insight Role | Access Level |
john.smith |
f5-admin |
Admin | Full access including User Administration |
jane.doe |
f5-operator |
Operator | Operational access, no User Administration |
bob.wilson |
f5-viewer |
Viewer | Read-only access |
new.user |
(not configured) | Viewer (default) | Read-only access |
Example - SAML role mapping (Okta / Ping)¶
| SAML User | Group Attribute in Assertion | F5 Insight Role |
admin@company.com |
admins |
Admin |
operator@company.com |
operators |
Operator |
user@company.com |
(no group attribute) | Viewer (default) |
Modifying or deleting role mappings¶
| Action | Steps | Impact |
| Modify Mapping | Navigate to Role Mapping, update the group attribute or role assignment, select Save. | Changes take effect on the user’s next login |
| Delete Mapping | Select the mapping, select Delete Mapping | Users previously assigned via this mapping default to Viewer on their next login |
Role mapping API endpoints¶
In this release, roles are read-only: GET /auth/roles and GET /auth/roles/{role_id}. No create role, update role, or edit permissions APIs.
GET |
/auth/roles |
List all available roles |
POST |
/auth/roles |
Create a custom role (not available in this release) |
GET |
/auth/roles/{role_id} |
Get role details and permissions |
PUT |
Update a role |
PUT |
/auth/roles/{role_id}/permissions |
Update role permissions |
Checking your permissions¶
Any authenticated user can check their current permissions using the UI or API.
Viewing your permissions¶
Your assigned role and permissions are visible in the UI based on the features and actions available to you.
Use the following API endpoints to programmatically check your permissions:
GET |
/auth/me/permissions |
View your current role and permissions |
POST |
/auth/permissions/check |
Check if you have permission for a specific action |
Understanding access denied responses¶
| HTTP Status Code | Meaning | Action |
| 401 Unauthorized | Your session has expired or your token is invalid | Log in again |
| 403 Forbidden | You do not have permission to perform this action | Contact your administrator to request the appropriate role |
