Overview¶
F5 Insight is a monitoring and analytics platform that gives you a clear view of how your applications and systems are performing. It identifies potential problems and helps you fix them before they become major issues.
With smart health monitoring, real-time alerts, and AI-powered fixes, F5 Insight helps you keep things running smoothly while reducing downtime and manual effort.
Benefits and key features¶
For comprehensive feature documentation and configuration details, refer to:
- Deployment Guide — Install F5 Insight on your platform of choice.
- User Guide — Add BIG-IP devices to F5 Insight.
- Fleet Management — Manage software updates and upgrades for your BIG-IP devices.
- AI Chat Assistance — Use F5 Insight with your preferred large language model (LLM).
- F5 AI Data Fabric — Get enhanced telemetry on F5 Insight and optionally send data to F5 AI Data Fabric (AIDF).
See everything in one place
F5 Insight connects to all your F5 systems and provides a single dashboard where you can see everything that is happening. No more jumping between tools or guessing about your system health.
Smart alerts and AI-powered recommendations
When something goes wrong, F5 Insight notifies you immediately and suggests how to fix it. Using built-in AI through a large language model (LLM), it can walk you through the steps to resolve issues quickly.
Simple health report cards
Get easy-to-read report cards that show how your systems are performing. These reports highlight what needs attention and provide clear steps to improve.
