F5 XC EMEA Workshop > Class 1 - F5 XC Services > Bot Advanced Source |
Lab 1 - Bot advanced configΒΆ
- Enabling Malicious User Detection is done at the HTTP Load Balancer level. In our example we will enable only Spam Sources and Anonymous Proxies
Web App & API Protection -> Load Balancers -> HTTP Load Balancer -> Click the 3 dots under the arcadia-re-lb row -> Manage Configuration -> Edit Configuration -> Fill the bellow data
Object Value Bot Defense Enable Bot Defense Region EU On the same place click Configure under Bot Defense Policy -> Configure -> App Endpoint Type -> Configure -> Add Item -> Fill the bellow data -> Apply -> Apply -> Apply -> Save and Exit
Object Value Name login HTTP Methods POST Endpoint Label Undefined Prefix /v1/login Select Bot Mitigation action Block
