F5 XC EMEA Workshop > Class 1 - F5 XC Services > Layer 7 DDOS Source |
Lab 1 - DDOS protection config¶
- Enabling DDOS protection is done at the HTTP Load Balancer level.
Web App & API Protection -> Load Balancers -> HTTP Load Balancer -> Click the 3 dots under the arcadia-re-lb row -> Manage Configuration -> Edit Configuration -> Fill the bellow data -> Save and Exit
Object Value DDoS Detection Enable Auto Mitigation Enable
