F5 XC EMEA Workshop > Class 3 - Virtual Kubernetes > Deploying an application container Source |
Lab 1 - Workload configΒΆ
- We now need to create the workload that will define the configuration on how and where to deploy the Stocks POD
Distributed Apps -> Applications -> Virtual K8s -> Click on $$vk8sName$$ -> Workloads -> Add VK8s Workload
Object Value Name arcadia-stocks Select Type of Workload Service In the same screen -> Configure -> Under Containers click Add Item -> Fill the bellow data -> Apply
Object Value Name stocks Image Name registry.hub.docker.com/sorinboiaf5/arcadia-stocks:ocp In the same screen -> Under Where to Deploy the workload choose Regional Edge Sites -> Configure -> Fill the bellow data -> Apply
Object Value Input box system/tn2-lon In the same screen -> Under Advertise In Cluster click Configure -> Toggle the Show Advanced Fields switch -> Fill the bellow data -> Apply -> Apply -> Save and Exit
Object Value Port 80 Target Port Different than Port Different than Port 8080
