Lab 2 - ObserveΒΆ
Under the Virtual K8s tab you can see that the regular Kubernets objects are available like Deployments, Services, Pods and a lot more
  1. Check that the Stocks pod is up and running
  1. Distributed Apps -> Applications -> Virtual K8s -> Click on $$vk8sName$$ -> Pods
