F5 XC EMEA Workshop > Class 3 - Virtual Kubernetes > Routing to Virtual Kubernetes Pod Source |
Lab 1 - Routing configΒΆ
- First we need to create a new origin pool which will point directly to application in the F5 XC Virtual Kubernetes.
Web App & API Protection -> Load Balancers -> Origin Pool -> Add Origin Pool -> Fill the bellow data
Object Value Name arcadia-stocks-vk8s Port 80 In the same screen -> Origin Servers -> Add Item -> Fill the bellow data -> Apply -> Save and exit
Object Value Select Type of Origin Server K8s Service Name of Origin Server on given Sitess Service Name arcadia-stocks.$$namespace$$ Site or Virtual Site Virtual Site Virtual Site ves-io-shared/ves-io-all-res Select Network on the site vK8s Networks on Site
- Our next step is to change the routing of the arcadia-re-lb to point to the new created origin pool for the /v1/stock/ route.
Web App & API Protection -> Load Balancers -> HTTP Load Balancer -> Click the 3 dots under the arcadia-re-lb row -> Manage Configuration -> Edit Configuration -> Under Routes and click Edit Configuration -> Add Item -> Fill the bellow data -> Apply -> Apply -> Save and Exit
Object Value HTTP Method Any Prefix /v1/stock/ Origin Pools Click Add Item and set the Origin Poll to $$namespace$$/arcadia-stocks-vk8s -> Apply
