Lab 2 - Testing and Visibility
Let’s see that what we have configured is working.
  1. Login into the app while using the arcadia-re-lb load balancer http://arcadia-re-$$makeId$$.workshop.emea.f5se.com
    Object Value
    Username satoshi@bitcoin.com
    Password bitcoin
  2. Let’s look where each request is going
  1. Browse to Web App & API Protection -> Dashboards -> Performance Dashboard -> Under Load Balancers click arcadia-re-lb -> Requests
  2. In the Search input enter /v1/stock/ticker/all . When you observe the Origin Server column you can see that it mentions tn2-lon which is the Virtual Kubernetes F5 XC point of presence
