F5 XC EMEA Workshop > Class 4 - API Protection > Dynamic API Protection Source |
Enable API validation¶
API Validation validates the requests and the responses, but also the content (JSON payload) based on the OpenAPI Specifications.
Note
As an example, API Validation validates if the value of a JSON key matches the specifications (integer, string, array …)
Example below
/adjectives:
get:
description: List all adjectives
tags:
- adjectives
responses:
'200':
description: a list of adjectives with their index
content:
application/json:
schema:
$ref: "#/components/schemas/Adjectives"
post:
description: create an adjective
tags:
- adjectives
requestBody:
content:
application/json:
schema:
type: object
properties:
name:
type: string
example:
responses:
'201':
description: adjective created
content:
application/json:
schema:
type: object
properties:
id:
type: integer
name:
type: string
example:
Having said, let’s enable API Validation.
Update your API Load Balancer¶
Warning
This section can’t be done if you are not part of an official F5 Workshop training. It requires a specific license (API Protection), and this license is provisionned only during official F5 events. You can bypass this section if you are not part of an official F5 training, and continue to the API Discovery lab.
Note
Please don’t open support ticket to increase this quota. This is done by F5ers in charge of the trainings (Matthieu Dierick, Sorin Boiangiu)
Enable API Validation for
All EndpointsClick on
View Configurationto customize the settingsEnable the
ValidationforRequestandResponseand select all the properties as shown below.Keep the setting
Fall Through ModetoAllowClick Apply and Save and Exit
Note
Fall Through Mode set to Allow means the system allows unknown endpoints. In a nutshell, any unknown API endpoint is not be blocked and the API Discovery process takes care of it.
Warning
Why not to block unknown endpoint? Because this endpoint could be legitimate by the Dev team, but SecOps are not aware “yet”. And it is better to have a visilibity on what is unknown instead of impacting the application and the business.
- SAVE your Load Balancer
Make a quick test of API Validation¶
The OpenAPI Spec file, specify the type of data expected by the API Endpoint. Let’s say we want to delete an entry for /adjectives.
The OAS spec file specify the type is
integerdelete: description: delete an adjective tags: - adjectives parameters: - name: id in: path required: true description: id of the adjective to retrieve schema: type: integer
Let send a wrong request where we replace the ID (integer) by a string
Change ' by " if the command does not work on your laptop. curl --location --request DELETE 'http://sentence-re-$$makeId$$.workshop-sa.emea.f5se.com/api/adjectives/beautiful'
Note
Here we replace the ID such as 4, by a string beautiful
Don’t expect to see any outcome from the command as we configured to
Reportand not toBlockin the “endpoint validation”. We need to keepReportso that the backend responds with sensitive information for the next lab.Go to Security Dashboard and check your logs (can take up to 1min to be displayed). You can see a violation
Request Path Parameter Violation
Note
We sent an ID with a string instead of an integer. F5XC can validate Request and Response body payload.
