Connecting to the app
The first step to implement F5 AI Red Team is to define the endpoint we are testing. That can either be the inference API of a model or the API of an Agent.
In the main left tab go to Connections, observe all the built-in inference endpoints that we can connect to. You can also see the Ollama inference which has been preconfigured.
Click on Manage on the Openai Compatible row. Click on the three dots on the genai-azure-openai row ⇒ Manage model.
You can observe the configuration we have created in order to connect to the model on the Azure OpenAI inference endpoint.
