F5 Application Delivery Controller Solutions > BIG-IP® Local Traffic Manager (LTM) - Getting Started Source | Edit on
Lab 2: The Basics (Networking, Pools and Virtual Servers)¶
In this lab we will access the Management GUI. We will then create the VLANs and assign self IP addresses to our VLAN. As mentioned during our lecture portion, BIG-IPs may be put in-line or one-armed depending on your customer’s requirements and topology.
Creating VLANs¶
You will need create two untagged VLANs, one client-side VLAN (client_vlan and one server-side VLAN (server_vlan) for the devices in your network.
From the sidebar select Network >> VLANs then select Create
Under General Properties:
The name is for management purposes only, you could name them after your children or pets
Tag: <leave blank>
Entering a tag is only required for “Tagged” (802.1q interfaces. “Untagged” interfaces will automatically get a tag which is used for internal L2 segmentation of traffic.
Under Resources in the Interfaces section:
When you have completed your VLAN configuration, hit the Finished button
Create another untagged VLAN named server_vlan on interface 1.2.
Assigning a Self IP addresses to your VLANs¶
Go to Network >> Self IPs, select Create.
Create a new self IP, for the server_vlan and client_vlan VLANs.
In Network >> Self IPs >> New Self IP, under Configuration enter:
**Server-Side Client-side** **Name**: server_ip client_ip **IP Address**: 10.1.20.245 10.1.10.245 **Netmask**: 255.255.255.0 255.255.255.0 **VLAN**: server_vlan client_vlan **Port** **Lockdown**: Allow None Allow None
The default “Allow None” means the Self IP would respond only to ICMP.
The “Allow Defaults” selection opens the following on the self IP of the VLAN
TCP: ssh, domain, snmp, https
TCP: 4353, 6699 (for F5 protocols, such as HA and iQuery)
UDP: 520, cap, domain, f5-iquery, snmp
PROTOCOL: ospf
Note
Even with “Allow None” chosen, traffic destined for a virtual server or object on the F5 (e.g. NAT) are able to pass through without issue as any object created on the F5 is by default allowed to pass through.
When you have completed your self-IP configuration, hit the
button. You should have something similar to the following
Assigning the Default Gateway¶
Go to Network > Routes and then Add.
Verify your network configuration
Ping your client-side self IP (10.1.10.245) to verify connectivity
Use an SSH utility, such as puTTY, to access your BIG-IP management port at 10.1.1.245.
User: root Password: default
Ping your default gateway, 10.1.10.1
Ping a web server at 10.1.20.11.
Creating Pools¶
In this lab we will build a pool and virtual server to support our web site and verify our configurations by accessing our web servers through the BIG-IP. Verification will be performed visually and through various statistical interfaces.
From the sidebar, select Local Traffic >> Pools then select Create. Here we will create our new pool
Under Configuration:
The name is for management purposes only, no spaces can be used
Description: <optional>
Health Monitor: http
Under Members:
Load Balancing Method: <leave at the default Round Robin>
Priority Group Activation: <leave at default>
New Members:
Address
Service Port
10.1.20.11
80
10.1.20.12
80
10.1.20.13
80
As you enter each IP address and port combination, hit the Add button
When you have completed your pool configuration, hit the Finished button
Creating Virtual Servers¶
Now let’s build our virtual server
Under Local Traffic >> Virtual Servers, click the “+” icon
Type: Standard
Source/Address: <leave blank>
Note
The default is 0.0.0.0/0, all source IP address are allowed
Destination Address/Mask: 10.1.10.100
Note
The default mask is /32
Service Port: 80 or HTTP
Under Configurations
The web servers do not use the BIG-IP LTM as the default gateway. This means return traffic will route around the BIG-IP LTM and the TCP handshake will fail. To prevent this we can configure SNAT Automap on the Virtual Server. This will translate the client IP to the self IP of the egress VLAN and ensure the response returns to the BIG-IP.
Source Address Translation: Auto Map
Under Resources
iRules: none
Default Pool: From the drop down menu, select the pool (www_pool) which you created earlier
Default Persistence Profile: None
Fallback Persistence Profile: None
When you have completed your virtual server configuration, hit the Finished button
You have now created a Virtual Server (Note: Items in blue are links)
Now let’s see if our virtual server works!
Open the browser to the Virtual Server you just created
Refresh the browser screen several times (use “<ctrl>” F5)
Go to your BIG-IP and view the statistics for the www_vs virtual server and the www_pool pool and its associated members
Go to Statistics > Module Statistics > Local Traffic
Go to Local Traffic >> Virtual Servers >> Statistics
Go to Local Traffic >> Pools >> Statistics
Did each pool member receive the same number of connections?
Did each pool member receive approximately the same number of bytes?
Note the Source and Destination address when you go to directly and through the virtual server
Let’s archive our configuration in case we have to fall back later.
Go to System >> Archives and select Create.
Name your archive lab2_the_basics_net_pool_vs
