Lab 3: Troubleshooting
Location and content of dynamic routing log files:
For each dynamic routing protocol, the BIG-IP system logs messages to a file that pertains to the route domain in which the protocol is running. An example of the path name to a dynamic routing log file is /var/log/zebos/rd1/zebos.log file, where rd1 is the route domain of the protocol instance.
On E_A_BIGIP configure the following logging statement for BGP:
[root@E_A_BIGIP-13:Active:Standalone] log # imish
E_A_BIGIP-13.local[0]>enable
E_A_BIGIP-13.local[0]#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
E_A_BIGIP-13.local[0](config)#log file /var/log/zebos/rd0/zebos.log
E_A_BIGIP-13.local[0]#wr
Building configuration...
[OK]
E_A_BIGIP-13.local[0]#exit
On E_A_BIGIP configure BGP debugging:
Copy to clipboard
E_A_BIGIP-13.local[0]#deb bgp all
Copy to clipboard
E_A_BIGIP-13.local[0]#sh debug bgp
BGP debugging status:
    BGP debugging is on
    BGP nht debugging is on
    BGP nsm debugging is on
    BGP events debugging is on
    BGP keepalives debugging is on
    BGP updates debugging is on
    BGP fsm debugging is on
    BGP filter debugging is on
    BGP Route Flap Dampening debugging is on
    BGP Bidirectional Forwarding Detection is on
Copy to clipboard
[OK]
On E_A_BIGIP view BGP log messages:
Copy to clipboard
root@(E_A_BIGIP-13)(cfg-sync Standalone)(Active)(/Common)(tmos)# quit
[root@E_A_BIGIP-13:Active:Standalone] config # cd /var/log
[root@E_A_BIGIP-13:Active:Standalone] log # ls | grep zebos
zebos
[root@E_A_BIGIP-13:Active:Standalone] log # cd zebos
[root@E_A_BIGIP-13:Active:Standalone] zebos # ls
rd0
[root@E_A_BIGIP-13:Active:Standalone] zebos # cd rd0
[root@E_A_BIGIP-13:Active:Standalone] rd0 # ls
zebos.log
[root@E_A_BIGIP-13:Active:Standalone] rd0 # more zebos.log
2018/07/09 11:49:14 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.20.4 (FD=11)
2018/07/09 11:49:14 informational: BGP : [NETWORK] Accept Thread: 10.2.20.4 - No such Peer configured
2018/07/09 11:49:16 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.40.4 (FD=11)
2018/07/09 11:49:16 informational: BGP : [NETWORK] Accept Thread: 10.2.40.4 - No such Peer configured
2018/07/09 11:49:21 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.20.4 (FD=11)
2018/07/09 11:49:21 informational: BGP : [NETWORK] Accept Thread: 10.2.20.4 - No such Peer configured
2018/07/09 11:49:26 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.40.4 (FD=11)
2018/07/09 11:49:26 informational: BGP : [NETWORK] Accept Thread: 10.2.40.4 - No such Peer configured
2018/07/09 11:49:28 informational: BGP : [RIB] Scanning BGP Network Routes...
2018/07/09 11:49:30 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.20.4 (FD=11)
2018/07/09 11:49:30 informational: BGP : [NETWORK] Accept Thread: 10.2.20.4 - No such Peer configured
2018/07/09 11:49:33 informational: BGP : [INIT] peer: 10.2.20.4 GR enabled for IPv4 (1).
2018/07/09 11:49:33 informational: BGP : 10.2.20.4-Outgoing [FSM] State: Idle Event: 35 op_state: MASTER
2018/07/09 11:49:33 informational: BGP : 10.2.20.4-Outgoing [FSM] State: Idle Event: 1 op_state: MASTER
2018/07/09 11:49:36 informational: BGP : [NETWORK] Accept Thread: Incoming conn from host 10.2.40.4 (FD=11)
2018/07/09 11:49:36 informational: BGP : [NETWORK] Accept Thread: 10.2.40.4 - No such Peer configured
Copy to clipboard
On E_A_BIGIP disable BGP debugging:
E_A_BIGIP-13.local[0]#undebug bgp all
[OK]
Copy to clipboard
Note
This completes Lab 3
