F5 XC EMEA Workshop > Class 1 - F5 XC Services > Publish the application Source |
Lab 2 - Testing and VisibilityΒΆ
In order to make sure all is working we will need to login into the application and look at the relevant dashboards.
Login into the app while using the arcadia-re-lb load balancer http://arcadia-re-$$makeId$$.workshop-sa.emea.f5se.com
Object Value Username satoshi@bitcoin.com Password bitcoin Browse to Web App & API Protection -> Dashboards -> Performance Dashboard -> Under Load Balancers click arcadia-re-lb
- Observe the different overall statistics provided by the Dashboard dashboard
- Observe the requests and plethora of information that can be seen for each request provided by the Requests dashboard
