F5 XC EMEA Workshop > Class 1 - F5 XC Services > Publish the application Source |
Lab 1 - Expose the applicationΒΆ
For this lab, we will use the following configuration
- Create the Origin Pool targeting Arcadia public app
Web App & API Protection -> Load Balancers -> Origin Pool -> Add Origin Pool -> Fill the bellow data
Object Value Name arcadia-public-endpoint Port 443 TLS Enable Origin Server Verification Skip Verification In the same screen -> Origin Servers -> Add Item -> Fill the bellow data -> Apply -> Save and exit
Object Value DNS name $$hostArcadia$$
- Create the HTTP LB
Web App & API Protection -> Load Balancers -> HTTP Load Balancer -> Add HTTP Load Balancer -> Fill the bellow data -> Save and exit
Object Value Name arcadia-re-lb Domains arcadia-re-$$makeId$$.workshop-sa.emea.f5se.com Load Balancer Type HTTP Automatically Manage DNS Records Enable Origin Pools Click Add Item, for the Origin Pool select $$namespace$$/arcadia-public-endpoint -> Apply
3. So far, Arcadia is not protected but exposed all over the world on all F5XC RE. Check your Arcadia application is exposed and reachable from the F5XC Global Network by browsing to http://arcadia-re-$$makeId$$.workshop-sa.emea.f5se.com
Warning
Some Service Providers have a very long recursive cache. It can take several minutes to get a DNS response. You can change your DNS server to 1.1.1.1 or 8.8.8.8 to fix that.
