F5 XC EMEA Workshop > Class 1 - F5 XC Services > RE + CE Source |
Lab 2 - Testing and Visibility¶
In order to make sure all is going to the internal endpoint we will need to generate traffic and look at the relevant dashboards.
Login into the app while using the arcadia-re-lb load balancer http://arcadia-re-$$makeId$$.workshop-sa.emea.f5se.com
Object Value Username satoshi@bitcoin.com Password bitcoin Let’s look where each request is going
Browse to Web App & API Protection -> Dashboards -> Performance Dashboard -> Under Load Balancers click arcadia-re-lb -> Requests
You can see that request before the origin pool change where using the public IP address as the app Origin Server but now we can see the site name $$ceOnPrem.clusterName$$
