SPKInfrastructure CR ParametersΒΆ
SPKInfrastructure helps users configure networking specifications for F5 BIG-IP Next for Kubernetes installation. The table below describes the SPKInfrastructure spec parameters.
| Parameter | Description | Default Values |
calicoRouter string |
Specifies the configuration options for the Calico routing setup. It determines the behavior or interaction of the routing mechanism with different components or protocols. Available options are: ICNI2, BFDToOVN or OvnMeg | Default |
| * ICNI2: Configuration for integrating Calico with ICNI2. | ||
| * BFDToOVN: Enables Bidirectional Forwarding Detection (BFD) for the integration with OVN (Open Virtual Network). | ||
| * OvnMeg: Configuration for managing and enabling OVN-related routing mechanisms. | ||
hugepages boolean |
Enable or disable the hugepages for TMM: true or false | true |
platformType string |
Specifies the type of platform on which the infrastructure will be deployed. Available options are: other, ocp or robin | others |
sriovResources string |
Specifies the SR-IOV (Single Root I/O Virtualization) resources to be used. | nvidia.com/bf3_p0_sf: "1" nvidia.com/bf3_p1_sf: "1" |
wholeClusterMode string |
Enable or disable the wholeClusterMode. TMM will run as DaemonSet if wholeClusterMode is enabled (One TMM pod per DPU). TMM will run as Deployment if wholeClusterMode is disabled |
disabled |
The table below describes the CR spec.egress parameters.
ipPoolCidrInfo.cidrList string |
Specifies the list of cluster CIDR. | value: "" value: "" |
ipPoolCidrInfo.ipPoolList string |
Specifies the list of IPPool CIDR. | value: "" value: "" |
