destinationAddress |
The external IPv4 address of the application. Defaults to localhost (127.0.0.1). |
destinationPort |
The external service port of the application. |
spec.category |
The F5SPKVLAN category to associate with the virtual server. |
ipv6destinationAddress |
The external IPv6 address of the application. |
snat |
Translate the source IP address of ingress packets to TMM's self IP addresses. Use SRC_TRANS_AUTOMAP to enable, and SRC_TRANS_NONE to disable (default). |
serviceDownAction |
The action to take when the service associated with the pool is marked down by a monitor or removed by Kubernetes: POOLMBR_ACTION_NONE (default), POOLMBR_ACTION_REJECT, POOLMBR_ACTION_DROP, or POOLMBR_ACTION_RESELECT. See K15095 for more detail. |
allowNoPayload |
Allow the passage of datagrams containing header information, but no essential data: true / false. The default is true. |
bufferMaxBytes |
The ingress buffer byte limit. The default value is 655350. Maximum allowed value is 16777215. |
bufferMaxPackets |
The ingress buffer packet limit. The default value is 0. Maximum allowed value is 255. |
datagramLoadBalancing |
Provides the ability to load balance UDP datagram by datagram: true / false. The default is false. |
idleTimeout |
The number of seconds that a connection is idle before the connection is eligible for deletion. The default value is 60 seconds. |
ipDFMode |
Describe the outgoing packet Don't Fragment (DF) bit. Modes: Pmtu - Set the packet DF big based on the ip pmtu setting. Preserve - Preserve the incoming packet DF bit. Set - Set the outgoing UDP packet DF bit. Clear -Clear the outgoing UDP packet DF bit. |
ipTTLMode |
Describe the outgoing packet TTL. Modes are: Proxy - Set the IPv4 TTL to 255 and IPv6 to 64. Preserve - Preserve the original IP TTL value. Decrement - Set IP TTL to original packet TTL minus 1. Set - Set IP TTL to values from ip-ttl-v4 and ip-ttl-v6 in the same profile. |
ipTosToClient |
The Type of Service level assigned to packets sent to clients. The default value is 0 (zero). |
linkQosToClient |
The Quality of Service level assigned to packets sent to clients. The default value is 0 (zero). |
loadBalancingMethod |
The traffic load balancing algorithm used. |
noChecksum |
Enables checksum processing. If IPv6, always perform checksum processing (true/false). The default value is false. |
proxyMss |
Advertise the same MSS to the server as negotiated with the client (true/false). The default value is false. |
sendBufferSizes |
The send buffer byte limit (536 to 16777215). The default value is 655350. |
ipTTLV4 |
The outgoing packet IP TTL value for IPv4 traffic. The default is 255. |
ipTTLV4 |
The outgoing packet IP TTL value for IPv6 traffic. The default is 64. |
vlans.vlanList |
A list specifying VLANs to listen for application traffic. |
vlans.category |
Specifies an F5SPKVLAN category parameter value to either allow or deny ingress traffic. |
vlans.disableListedVlans |
Disables the VLANs specified with the vlanList parameter: true (default) or false. Excluding one VLAN may simplify having to enable many VLANS. |
