BGP routing - CRD reference
Overview
This section provides reference for every custom resource definition (CRD) used to configure BGP routing, VXLAN tunnels, and VRF isolation in F5 BIG-IP Next for Kubernetes (BNK). All field definitions, types, constraints, and validation rules are derived directly from the CRD schema YAML files.
CRD summary
CRD
API group
API version
Scope
GlobalRoutingConfig
k8s.f5net.com
v1alpha1
Namespaced
RoutingConfig
k8s.f5net.com
v1alpha1
Namespaced
RoutingTemplate
k8s.f5net.com
v1alpha1
Namespaced
VXLAN
k8s.f5net.com
v1
Namespaced
VRF
k8s.f5net.com
v1
Namespaced
Important
All five CRDs are immutable after creation. You must delete and recreate the resource to make changes.
CRD dependency and ordering
Create resources in the following order:
Order
CRD
Depends on
1
RoutingTemplate
2
Vrf
3
Vxlan
Vrf (via spec.vrf)
4
GlobalRoutingConfig
RoutingTemplate (via spec.templateRef), Kubernetes Secret (via spec.neighborSecrets)
5
RoutingConfig
GlobalRoutingConfig (must be successful), RoutingTemplate, Vxlan (via spec.vxlanRef) or Vrf (via spec.vrf)
