F5 Application Delivery Controller Solutions > Introduction to ADC Deployments with BIG-IP LTM > BIG-IP LTM HA Configuration - Source | Edit on
Lab 3: Use SSL Offload, Best Practices, and iApps¶
In this lab you will create an HTTPS web application and use the BIG-IP SSL offload feature to free up CPU resources from the web servers. You’ll update the BIG-IP configuration by including some best practices. Finally you’ll re-create the HTTPS web application by using BIG-IP iApps.
Task 1 – Use SSL Offload¶
In the Configuration Utility, open the Pool List page and click Create.
Use the following information for the new pool, and then click Finished.
Form field
Value
Name
https_pool
Health Monitors
https_443
New Members
Node List: node1 (10.1.20.11) Service Port: 443 (Click Add)
Node List: node2 (10.1.20.12) Service Port: 443 (Click Add)
Node List: node3 (10.1.20.13) Service Port: 443 (Click Add)
Open the Virtual Server List page and click Create.
Use the following information for the new virtual server, and then click Finished.
Form field
Value
Name
https_virtual
Destination Address/ Mask
10.1.10.20
Service Port
443
HTTP Profile
http
Acceleration > HTTP Compression Profile
httpcompression
Resources > Default Pool
https_pool
Use a new tab to access https://10.1.10.20.
The page fails to load. At this point the BIG-IP system is simply forwarding SSL requests to the downstream HTTPS web server without decrypting them first. This prevents the BIG-IP system from performing any HTTP functions (such as HTTP compression) which is why the page fails to load.
In the Configuration Utility, on the Virtual Server List page click https_virtual, and then for SSL Profile (Client) move clientssl to the Selected list.
For SSL Profile (Server) move serverssl-insecure-compatible to the Selected list, and then click Update.
Reload the https://10.1.10.20 page.
The page displays as expected.
Identify the protocol used in the URL, and the port used on the downstream server (in the Pool member address/port entry).
Although the BIG-IP system is now decrypting requests, it is re-encrypting before sending to the HTTPS web servers, which means they must perform the CPU-intensive task of decrypting requests and encrypting responses.
In the Configuration Utility, on the https_virtual page, for SSL Profile (Server) move serverssl-insecure-compatible back to the Available list, and then click Update.
Open the Resources page.
From the Default Pool list select http_pool, and then click Update.
The BIP-IP system is now performing SSL offload, sending all downstream requests using port 80. This means that the web servers no longer need to perform the CPU-intensive task of decrypting requests and encrypting responses.
Close the tab.
Task 2 – Configure BIG-IP Best Practices¶
Close the Configuration Utility, then open Internet Explorer and access https://10.1.10.240.
Currently the BIG-IP system can be accessed by the outside world using the external self IP address, which is not recommended.
Log into the BIG-IP system, and then open the Network > Self IPs page and click 10.1.10.240.
From the Port Lockdown list select Allow None, and then click Update.
Return to the Self IPs page.
Why are you now unable to access the BIG-IP system?
Close Internet Explorer, then open Chrome and access https://10.1.1.245 and then log into the BIG-IP system as admin / admin.
It is not recommended to use the default admin account.
Open the System > Users > Authentication page and click Change.
From the User Directory list select Remote – Active Directory.
Use the following information, and then click Finished.
Form field
Value
Host
10.1.20.251
Remote Directory Tree
DC=f5demo,DC=com
Bind DN
CN=Service Account,OU=Corporate,DC=f5demo,DC=com
Bind Password
password
Check Member Attribute
Enabled (selected)
Role
Guest
Open the Remote Role Groups page and click Create.
Form field
Value
Group Name
F5Admins
Line Order
10
Attribute String
memberOf=CN=loraxadmins,CN=Users,DC=f5demo,DC=com
Assigned Role
Administrator
Terminal Access
tmsh
Create another role group using the following information, and then click Finished.
Form field
Value
Group Name
F5ResourceAdmins
Line Order
15
Attribute String
memberOf=CN=resadmins,CN=Users,DC=f5demo,DC=com
Assigned Role
Resource Administrator
Terminal Access
Disabled
Form field
Value
Group Name
F5Operators
Line Order
20
Attribute String
memberOf=CN=operators,CN=Users,DC=f5demo,DC=com
Assigned Role
Operator
Terminal Access
Disabled
Open the System > Users > User List page.
Select the admin account and change the password to admin-pass and then click Update.
Log in as bigip_operator / password.
Notice the user’s role at the top of the page.
Open the Virtual Server List page and examine the Create button.
This user can view all virtual servers and other BIG-IP system objects, but can’t create or update objects.
Log out and then log back in as bigip_ra / password.
Open the Virtual Server List page.
This user and see and manage all virtual servers.
Open the System > Users > Authentication page and examine the Change button.
Log out and then log back in as bigip_admin / admin. (NOTE: You are intentionally logging in with the wrong password.)
Log in as bigip_admin / password.
Open the System > Logs > Audit > List page, and then sort the list by the Time column in descending order.
Examine the login and logout details for the three users.
You can see when each user logged in, logged out, and failed to login correctly.
Task 3 – Re-create the Application using iApp¶
Open the Virtual Server List page, then select the http_virtual and https_virtual checkboxes, and then click Delete twice.
Open the Pool List page, then select the http_pool and https_pool checkboxes, and then click Delete twice.
Open the Node List page, then select the node1, node2, and node3 checkboxes, and then click Delete twice.
Open the iApps > Application Services > Applications page and click Create.
Create an application using the following information, and then click Finished.
Form field
Value
User Name
https_app
Template
f5.http
Network > Do you want to use the latest TCP profiles?
Yes
SSL Encryption > How should the BIG-IP system handle SSL traffic?
Terminate SSL from clients, plaintext to servers
Virtual Server and Pools > What IP address do you want to use
10.1.10.20
FQDN
www.f5demo.com
Web servers
10.1.20.11: 80 (Click Add) 10.1.20.12: 80 (Click Add) 10.1.20.13: 80
Application Health > What HTTP URI
/index.php
Expected Response
Welcome
iApp created two virtual servers for the web application. The port 80 virtual server is used to redirect requests to the port 443 virtual server.
Open the Pool List page.
iApp created a pool with three pool members and a monitor attached (which you can identify by it being identified as available).
Open the Monitors page and click https_app_http_monitor.
iApp created the custom HTTP monitor for the web application.
Use a new tab to access http://10.1.10.20.
Notice that the request is redirected to https. The requests are sent to the web servers on port 80, identifying that SSL offload is taking place.
Close the tab.
