Lab 1: Configure BIG-IP Trunks, VLAN's, and Self-IP's
In Lab 1, we will setup basic network-level settings on our BIG-IPs. We will define Trunks, VLANs, and local Self IPs. These configuration items will assist in establishing connectivity to/from our BIG-IPs, and between BIG-IPs.
Lab Tasks:
  • Task 1: Create BIG-IP Trunks
  • Task 2: Create BIG-IP VLANs
  • Task 3: Create BIG-IP Self IPs
In Task 1, we will define BIG-IP trunks. These trunks will be used in subsequent labs, becoming part of our HA Group configuration.
  1. On both BIG-IP devices, configure trunks under the Network configuration section.
    Use the following table to create & define your three Trunks:
    Trunk Name
    Interface Member
    Description / Function
    int_trunk
    1.1
    Trunk to simulate a connection to internal infrastructure
    ext_trunk
    1.2
    Trunk to simulate a connection to external infrastructure
    HA_trunk
    1.3
    Trunk to simulate a high-availability network connection
  2. Navigate to: Network > Trunks > Trunk List, then click the "+" button to create a new Trunk:
    ../../_images/image128.png
  3. Provide a Trunk Name, and move the respective Available interface to the "Members" section.
  4. Click Repeat to define your next trunk.
    When you define the last trunk, you may select the "Finished" button
    • Internal Trunk:
    ../../_images/image225.png ../../_images/image318.png
    • External Trunk:
    ../../_images/image417.png
    • HA Trunk:
    ../../_images/image510.png
    • View of Trunk List after creating all three trunks:
    ../../_images/image67.png
In Task 2, we will define our VLANs on our BIG-IPs. Our VLANs will be associated with their respective trunk from Task 1.
  1. On both BIG-IP devices, configure VLANs under the Network configuration section.
    Use the following table to create & define your three VLANs:
    Name
    Tag
    Interface
    Tagging
    int_vlan_10
    10
    int_trunk
    Untagged
    ext_vlan_20
    20
    ext_trunk
    Untagged
    HA_vlan_30
    30
    HA_trunk
    Untagged
  2. Navigate to: Network > VLANs > VLAN List, then click the "+" button to create a new VLAN:
    ../../_images/image76.png
  3. Create the respective VLANs per the table above.
    • Internal VLAN:
    ../../_images/image86.png ../../_images/image96.png
    • External VLAN:
    ../../_images/image107.png
    • HA VLAN:
    ../../_images/image1110.png
    • View of the VLAN List after all VLANs have been defined, and associated to their respective Trunk:
    ../../_images/image129.png
In Task 3, we will configure our Local Self IPs of each BIG-IP. These IPs will be our L3 connectivity to our BIG-IP networks.
  1. On both BIG-IP devices, configure their respective Self IPs under the Network configuration section.
    Use the following table to create & define your three Self IPs:
    BIG-IP
    Name
    IP address
    Netmask
    VLAN
    Port Lockdown
    bigipA
    self_vlan10
    10.1.10.241
    255.255.255.0
    int_vlan_10
    Allow None (default)
    bigipA
    self_vlan20
    10.1.20.241
    255.255.255.0
    ext_vlan_20
    bigipA
    self_vlan30
    10.1.30.241
    255.255.255.0
    HA_vlan_30
    bigipB
    self_vlan10
    10.1.10.242
    255.255.255.0
    int_vlan_10
    bigipB
    self_vlan20
    10.1.20.242
    255.255.255.0
    ext_vlan_20
    bigipB
    self_vlan30
    10.1.30.242
    255.255.255.0
    HA_vlan_30
  2. Navigate to: Network > Self IPs, then click the "+" button to create a new Self IP:
    ../../_images/image136.png
  3. Create the respective Self IPs per the table above.
    • Self IP, VLAN 10:
    ../../_images/image145.png
    • Self IP, VLAN 20:
    ../../_images/image155.png
    • Self IP, HA VLAN 30:
    ../../_images/image165.png
    • Example view of the Self IP List from BIG-IP-A after all Self IPs have been defined:
    ../../_images/image175.png
Lab Summary
In this lab, you setup basic BIG-IP network-level configuration settings. After completion of these lab tasks, you should have network connectivity between the devices on all VLANs. These configuration objects will assist with the subsequent labs.
This completes Lab 1.
