Create a Storage ClassΒΆ
During installation, the Fluentd logging and Cluster Wide Controller (CWC) must be able to access a persistent storage (storageClass). This is necessary for storing log files and Qkview collection process. Users must create a storageClass and refer in the SPKInstance CR, see Install BIG-IP Next for Kubernetes.
Verify if a storageClass is available.
kubectl get storageclass
If the
storageClassis available and set todefault type, you no need to specify in the SPKInstance CR during BIG-IP Next for Kubernetes installation process. Otherwise, you must refer thestorageClassname in the SPKInstance CR, see Install BIG-IP Next for Kubernetes.If you do not have a
storageClass, see Storage Classes to create.Once the
storageClassis created successfully, refer the newlystorageClassname in the SPKInstance CR, see Install BIG-IP Next for Kubernetes.Example Storage Class refernce for CWC:
spec: cwc: persistence: enabled: false accessMode: - ReadWriteOnce storageClass: storageclass-cwc size: 3Gi
Example Storage Class refernce for Fluentd:
spec: fluentd: persistence: enabled: false accessMode: - ReadWriteOnce storageClass: storageclass-fluentd size: 3Gi
