| Info |
Application |
UDP profile- %s is not soft referenced anywhere. |
| Info |
Application |
FastL4 profile- %s is also soft refernced in %s. |
| Info |
Application |
FastL4 profile- %s is not soft referenced anywhere. |
| Debug |
Application |
name = %s, cnf.objectMembers[name] = %v, newPoolMembers = %v |
| Info |
Application |
Creating: %v |
| Debug |
Application |
Ratio of atleast one pool member is updated. Found a pool member : %v with ratio updated from %v to %v |
| Info |
Application |
Updating: %v |
| Info |
Application |
Scaling up/Update: %v |
| Info |
Application |
Scaling down: %v |
| Debug |
Application |
name+service = %s+%s, service members = %v, new pool members = %v |
| Info |
Application |
Added F5Datagroup %s/%s |
| Error |
Application |
Error parsing address string %v |
| Error |
Application |
Error executing Diameter Create Template for IP %s: %v |
| Error |
Application |
Error executing Diameter Update Template for IP %s: %v |
| Error |
Application |
Error executing Diameter Delete Template for IP %s: %v |
| Error |
Application |
Error creating Diameter config with error: %v |
| Info |
Application |
Added F5SPKIngressDiameter %s/%s |
| Info |
Application |
F5SPKIngressDiameter External TCP Service: %s |
| Info |
Application |
F5SPKIngressDiameter External TCP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressDiameter External TCP Not enabled. |
| Info |
Application |
F5SPKIngressDiameter External SCTP Service: %s |
| Info |
Application |
F5SPKIngressDiameter External SCTP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressDiameter External SCTP Not enabled. |
| Info |
Application |
F5SPKIngressDiameter Internal TCP Service: %s |
| Info |
Application |
F5SPKIngressDiameter Internal TCP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressDiameter Internal TCP Not enabled. |
| Info |
Application |
F5SPKIngressDiameter Internal SCTP Service: %s |
| Info |
Application |
F5SPKIngressDiameter Internal SCTP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressDiameter Internal SCTP Not enabled. |
| Error |
Application |
Error adding or updating vlan list: %v |
| Info |
Application |
Diameter Create Protobuf template processing error, ExternalTCP Not Set |
| Info |
Application |
Diameter Create Protobuf template processing error, ExternalSCTP Not Set |
| Error |
Application |
Diameter Create Protobuf template processing error: %v |
| Info |
Application |
Scaling up/Creating: %v |
| Error |
Application |
Diameter Update Protobuf template processing error: %v |
| Error |
Application |
Diameter Scale Down Protobuf template processing error: %v |
| Error |
Application |
runGrpc Scale down error: %v |
| Info |
Application |
Delete all: %v |
| Error |
Application |
Diameter Delete Protobuf template processing error: %v |
| Info |
Application |
Updating full protobuf: %v |
| Info |
Application |
Update Profile: %v |
| Error |
Application |
Diameter Update Profile Prtotobuf template processing error: %v |
| Error |
Application |
runGrpc Update Profile error: %v |
| Info |
Application |
IPS profile- %s already exists |
| Info |
Application |
Updating Dnscache %s |
| Info |
Application |
Adding Dnscache %s |
| Info |
Application |
Updating DNSX Global Options %s |
| Info |
Application |
Adding DNSX Global Options %s |
| Info |
Application |
Updating Dnszone %s |
| Info |
Application |
Adding Dnszone %s |
| Error |
Application |
Failed to apply DNS Zone %s. Restoring config for TMM and ZXFRD. Re-apply the CR. |
| Info |
Application |
Non-Zero Destination port is only allowed for TCP/UDP ip protocol in Allowlist Entry, skipped entry: %v |
| Info |
Application |
Adding Dynamic AppsCategories %s/%s |
| Error |
Application |
Error DnsNat46Ipv4Subnet is empty |
| Info |
Application |
Added spkEgress %s/%s |
| Info |
Application |
APP: %s has CATEGORY: %s |
| Info |
Application |
Creating via gRPC snatpoolEx.SnatPoolTMMPodIPMap: %v |
| Info |
Application |
Creating via gRPC: %v |
| Error |
Application |
Error creating Egress with error: %v |
| Info |
Application |
Added F5FTP %s/%s |
| Info |
Application |
Client TCP profile- %s already exists |
| Info |
Application |
Server TCP profile- %s already exists |
| Info |
Application |
LastClientSide TCP profile- %s |
| Info |
Application |
LastServerSide TCP profile- %s |
| Info |
Application |
For Softref LogProfile- %s, Publisher- %s |
| Info |
Application |
Cient side TCP profile: %s, cannot delete, since it is referenced by some other profile also. |
| Info |
Application |
Server side TCP profile: %s, cannot delete, since it is referenced by some other profile also. |
| Error |
Application |
Error parsing destination address %s: %v |
| Error |
Application |
Error parsing ipv6 destination address %s: %v |
| Error |
Application |
Error parsing endpoint address %s: %v |
| Error |
Application |
Error parsing ipv6 endpoint address %s: %v |
| Error |
Application |
Error parsing translation address i.e. Snat IP %s: %v |
| Error |
Application |
Error parsing ipv6 translation address i.e. ipv6 Snat IP %s: %v |
| Error |
Application |
Error parsing static route address %s: %v |
| Error |
Application |
Error parsing ipv6 static route address %s: %v |
| Info |
Application |
Added F5SPKIngressGTP %s/%s |
| Info |
Application |
F5SPKIngressGTP Service %s/%d |
| Info |
Application |
F5SPKIngressGTP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressGTP Service %d with ipv4 endpoint: %s %d |
| Info |
Application |
F5SPKIngressGTP Service %d with ipv6 endpoint: %s %d |
| Error |
Application |
GTP Create Protobuf template processing error: %v |
| Error |
Application |
GTP Scaling up/Update Protobuf template processing error: %v |
| Error |
Application |
GTP Update Protobuf template processing error: %v |
| Error |
Application |
GTP Scale Down Prtotobuf template processing error: %v |
| Error |
Application |
GTP Delete Protobuf template processing error: %v |
| Error |
Application |
GTP Update Profile Prtotobuf template processing error: %v |
| Info |
Application |
HSL config : %v |
| Info |
Application |
Removing existing Hsl Publisher config for %s |
| Info |
Application |
Adding F5Hslpub %s/%s |
| Info |
Application |
PushFTPProfile error: %v |
| Info |
Application |
PushTFTPProfile error: %v |
| Info |
Application |
PushRTSPProfile error: %v |
| Info |
Application |
UpdateRTSPProfile error: %v |
| Info |
Application |
Deleting F5Hslpub crd %s |
| Error |
Application |
Error: %v |
| Error |
Application |
Error parsing IPV6 static route address %s: %v |
| Error |
Application |
Error Creating HTTP2 Configuration: Bidirectional traffic requires ServerSSL keys when ServerSSL Offload is false |
| Error |
Application |
Error executing HTTP2 Create Template for TMM pod with IP %s and internal vlan IP %s: %v |
| Error |
Application |
Error executing HTTP2 Update Template for TMM pod with IP %s and internal vlan IP %s: %v |
| Error |
Application |
Error executing HTTP2 Delete Template for TMM with IP %s and interal vlan IP %s: %v |
| Error |
Application |
Error creating HTTP2 config: %v |
| Info |
Application |
Added F5SPKIngressHTTP2 %s/%s |
| Info |
Application |
F5SPKIngressHTTP2 Destination Address %s, Destination Port %d |
| Error |
Application |
Error adding or updating ingress vlan list: %v |
| Error |
Application |
Error adding or updating egress vlan list: %v |
| Error |
Application |
HTTP2 Create Protobuf template processing error, Destination Not Set |
| Error |
Application |
HTTP2 Create Protobuf template processing error: %v |
| Debug |
Application |
name+service = %s+%s, pool members = %v, new pool members = %v |
| Error |
Application |
HTTP2 Update Protobuf template processing error: %v |
| Error |
Application |
HTTP2 Scale Down Protobuf template processing error: %v |
| Error |
Application |
gRPC error sending on scale down: %v |
| Error |
Application |
gRPC send error: %v |
| Error |
Application |
HTTP2 Update Profile Prtotobuf template processing error: %v |
| Error |
Application |
gRPC send Update Profile error: %v |
| Error |
Application |
HTTP2 Delete Protobuf template processing error: %v |
| Debug |
Application |
GRPC is not enabled. TCL config for F5SPKIngressHTTP2 not supported. |
| Error |
Application |
StoreToF5SPKIngressHTTP2Lister pointer is nil |
| Debug |
Application |
----IngressHTTP2 ------ routeNamespace: %v, serviceNamespace: %v\n |
| Info |
Application |
----IngressHTTP2 ------ routeServiceName: %v, serviceName: %v\n |
| Error |
Application |
Error executing ieUDP Create Template for IP %s: %v |
| Error |
Application |
Error executing ieUDP Update Template for IP %s: %v |
| Error |
Application |
Error executing ieUDP Delete Template for IP %s: %v |
| Error |
Application |
Error creating ieUDP config with error: %v |
| Info |
Application |
Added F5SPKIngressEgressUDP %s/%s |
| Info |
Application |
F5SPKIngressEgressUDP External Service: %s |
| Info |
Application |
F5SPKIngressEgressUDP External Destination Address %s, Destination Port %d |
| Error |
Application |
ieUDP Create Protobuf template processing error, External Destination Not Set |
| Error |
Application |
ieUDP Create Protobuf template processing error: %v |
| Error |
Application |
ieUDP Update Protobuf template processing error: %v |
| Error |
Application |
ieUDP Scale Down Protobuf template processing error: %v |
| Error |
Application |
ieUDP Delete Protobuf template processing error: %v |
| Error |
Application |
ieUDP Update Profile Prtotobuf template processing error: %v |
| Info |
Application |
GRPC is not enabled. TCL config for F5SPKIngressEgressUDP not supported. |
| Info |
Application |
Added F5Irule %s/%s |
| Info |
Application |
UpdateFTPProfile error: %v |
| Info |
Application |
UpdateTFTPProfile error: %v |
| Info |
Application |
CheckUpdatePPTPProfile error: %v |
| Info |
Application |
Removing existing Security Log Profile config for %s |
| Info |
Application |
Adding Security Log Profile %s |
| Error |
Application |
NGAP: Error marshaling to string %v |
| Error |
Application |
Error parsing SCTP alternate address string %v |
| Info |
Application |
Members under maddr field: %v |
| Error |
Application |
Error parsing IPv6 destination address string %v |
| Error |
Application |
Error parsing destination address string %v |
| Error |
Application |
Error parsing endpoint address string %v |
| Error |
Application |
Error parsing IPv6 SNAT address string %v |
| Error |
Application |
Error parsing SNAT address string %v |
| Error |
Application |
Error executing NGAP Create Template for IP %s: %v |
| Error |
Application |
Error executing NGAP UpdateProfile Template for IP %s: %v |
| Error |
Application |
Error creating NGAP config with error: %v |
| Info |
Application |
Added F5SPKIngressNGAP %s/%s |
| Info |
Application |
F5SPKIngressNGAP Destination Address %s, Destination Port %d |
| Info |
Application |
F5SPKIngressNGAP Service %d with ipv4: %s %d |
| Info |
Application |
F5SPKIngressNGAP Service %d with ipv6: %s %d |
| Error |
Application |
NGAP Create Protobuf template processing error: %v |
| Error |
Application |
NGAP Scaling up/Update Protobuf template processing error: %v |
| Error |
Application |
NGAP Update Protobuf template processing error: %v |
| Error |
Application |
NGAP Scale Down Prtotobuf template processing error: %v |
| Error |
Application |
NGAP Delete Protobuf template processing error: %v |
| Error |
Application |
gRPC message send error: %v |
| Error |
Application |
NGAP Update Profile Prtotobuf template processing error: %v |
| Error |
Application |
gRPC message send update error: %v |
| Error |
Application |
StoreToF5SPKIngressNGAPLister pointer is nil |
| Debug |
Application |
Policy id freed: %d |
| Info |
Application |
Updating PE policy %s |
| Info |
Application |
Adding PE policy %s |
| Debug |
Application |
Policy id allocated: %d |
| Info |
Application |
Removing existing Port List config for %s |
| Info |
Application |
Adding Port List %s/%s |
| Error |
Application |
Error during sending Port List create PCCD GRPC message: %v |
| Error |
Application |
Error during sending Port List delete PCCD GRPC message: %v |
| Error |
Application |
StoreToPortListLister pointer is nil |
| Info |
Application |
Added F5PPTP %s/%s |
| Info |
Application |
Error generating Pre-canned license configuration : %v |
| Info |
Application |
Added F5RTSP %s/%s |
| Info |
Application |
profile name: %s |
| Info |
Application |
Client TCP profile already exists |
| Info |
Application |
Server TCP profile already exists |
| Info |
Application |
UDP Client profile name: %s |
| Info |
Application |
UDP Server profile name: %s |
| Info |
Application |
Client UDP profile already exists |
| Info |
Application |
Server UDP profile already exists |
| Info |
Application |
FastL4 profile name: %s |
| Info |
Application |
Fastl4 profile already exists |
| Info |
Application |
IPS profile: %s |
| Info |
Application |
IPS Profile %s already exists |
| Info |
Application |
Client UDP profile- %s already exists |
| Info |
Application |
Server UDP profile- %s already exists |
| Info |
Application |
CR created client and server side UDP profile: %s, cannot delete, since another CR is referencing the same profile |
| Info |
Application |
CR created client side UDP profile: %s, cannot delete, since another CR is referencing the same profile |
| Info |
Application |
CR created server side UDP profile: %s, cannot delete, since another CR is referencing the same profile |
| Info |
Application |
CR created Fastl4 profile: %s, cannot delete, since another CR is referencing the same profile |
| Info |
Application |
Added F5SPKIngressSIP |
| Info |
Application |
Destination address and Port |
| Info |
Application |
IPv6 Destination address and Port |
| Info |
Application |
F5SPKIngressSIP Service: %d ipv4 Destination Address and Port |
| Info |
Application |
F5SPKIngressSIP Service: %d ipv6 Destination Address and Port |
| Info |
Application |
SIP Create Protobuf template processing error: %v |
| Info |
Application |
SIP Scaling up/Update Protobuf template processing error: %v |
| Info |
Application |
SIP Scaling down/Update Protobuf template processing error: %v |
| Info |
Application |
SIP Scale Down Protobuf template processing error: %v |
| Info |
Application |
Delete all pool members |
| Info |
Application |
SIP Delete Protobuf template processing error: %v |
| Info |
Application |
Update Profile |
| Info |
Application |
SIP Update Profile Protobuf template processing error: %v |
| Error |
Application |
StoreToF5SPKIngressSIPLister pointer is nil |
| Error |
Application |
Error executing Snatpool Create Template for IP %s: %v |
| Error |
Application |
Error executing Snatpool Delete Template for IP %s: %v |
| Info |
Application |
Error creating SNAT Pool with error: %v |
| Info |
Application |
Added F5Snatpool: %v |
| Info |
Application |
Snatpool Create Protobuf template processing error: %v |
| Info |
Application |
Snatpool Update Protobuf template processing error: %v |
| Info |
Compliance |
Added F5StaticRoute |
| Error |
Application |
Static Route Gateway and GatewayIpv6 contain different number of tmm ips '%s' and '%s' |
| Info |
Application |
Static route Create Protobuf template processing error: %v |
| Info |
Application |
Error creating Static Route with error: %v |
| Info |
Application |
Added F5SPKIngressTCP |
| Info |
Application |
| Info |
Application |
F5SPKIngressTCP Service ipv4 Destination Address Port and Ratio |
| Info |
Application |
TCP Create Protobuf template processing error: %v |
| Info |
Application |
Scaling up/Update and generating gRPC mesage |
| Info |
Application |
TCP Scaling up/Update Protobuf template processing error: %v |
| Info |
Application |
Scaling down and generating protobuf message |
| Info |
Application |
TCP Update Protobuf template processing error: %v |
| Info |
Application |
TCP Scale Down Protobuf template processing error: %v |
| Info |
Application |
TCP Delete Protobuf template processing error: %v |
| Info |
Application |
Update monitors |
| Info |
Application |
Updating full protobuf |
| Info |
Application |
Updating full protobuf when change in DisabledListedVlans |
| Info |
Application |
TCP Update Profile Protobuf template processing error: %v |
| Error |
Application |
StoreToF5SPKIngressTCPLister pointer is nil |
| Info |
Application |
Added F5TFTP %s/%s |
| Info |
Application |
Registered tmm endpoint for module %v |
| Info |
Application |
Added F5SPKIngressUDP |
| Info |
Application |
F5SPKIngressUDP Service ipv4 Destination Address and Port |
| Info |
Application |
F5SPKIngressUDP Service ipv6 Destination Address and Port |
| Info |
Application |
Vlan category: %s |
| Error |
Application |
Error updating vlan list for App in Category %s |
| Info |
Application |
| Info |
Application |
Creating protobuf message |
| Info |
Application |
Scaling up/Updating protobuf message |
| Error |
Application |
| Error |
Application |
| Error |
Application |
| Error |
Application |
udp Update Protobuf template processing error: %v |
| Error |
Application |
| Info |
Application |
Resource found in category map. Category: %s |
| Info |
Application |
Adding Resource to category map. Category: %s |
| Error |
Application |
StoreToF5SPKIngressUDPLister pointer is nil |
| Warning |
Application |
SelfIP not available, skip protobuf creation for address |
| Error |
Application |
Error executing Vlan Create Template for IP: %v |
| Info |
Application |
Ingress Route Vlan Create Protobuf template processing error: %v |
| Info |
Application |
Error creating Route Vlan with error: %v |
| Info |
Application |
Added F5Vlan |
| Info |
Application |
GRPC Manager is enabled |
| Info |
Application |
vlan over grpc enabled |
| Info |
Application |
Creating F5Vlan |
| Info |
Application |
Vlan found in category map. Category: %s |
| Error |
Application |
Vlan found in more than one previous category. |
| Info |
Application |
Vlan previously belonged to category map. Category: %s |
| Info |
Application |
Vlan added in category map. Category: %s |
| Error |
Application |
Error updating vlan list for %s |
| Error |
Application |
Error during creating bonded vlan %v: %v |
| Info |
Application |
Added F5ZERORATINGIRULE %s/%s |
| Info |
Application |
ModifySecureContextIrule SendGRPCMessage error: %v |
| Info |
Application |
ModifyFTPIrule SendGRPCMessage error: %v |
| Info |
Application |
SecureContextIRuleUpdate error: %v |
| Info |
Application |
FTPIRuleUpdate error: %v |
| Error |
Application |
Configmap %s/%s: Invalid value for the lb-method key: got %q: %v |
| Error |
Application |
Configmap %s/%s: Invalid value for worker-processes key: must be an integer or the string 'auto', got %q |
| Error |
Application |
ConfigMap Key 'opentracing' requires both 'opentracing-tracer' and 'opentracing-tracer-config' Keys configured, Opentracing will be disabled |
| Info |
Application |
Registering configurator for %s |
| Info |
Application |
Deleting crd key: %v, members: %v |
| Info |
Application |
Error updating Diameter in deletecrd with error: %v |
| Info |
Application |
Sending Diameter update in deletecrd message to %s:%s |
| Info |
Application |
Error updating Diameter in deletecrd protobuf with error: %v |
| Info |
Application |
Error deleting vlan list: %s |
| Info |
Application |
Sending Diameter delete message to %s:%s |
| Info |
Application |
Error deleting Diameter protobuf with error: %v |
| Info |
Application |
Deleting crd object from configurator |
| Info |
Application |
Deleting F5Vlan crd: %v |
| Info |
Application |
%v does not exist, do nothing |
| Info |
Application |
F5Vlan Delete Protobuf template processing error: %v |
| Info |
Application |
Sending VLAN delete message to %s:%s |
| Info |
Application |
Error deleting VLAN with error: %v |
| Info |
Application |
F5Vlan PCCD Delete Protobuf template processing error: %v |
| Info |
Application |
Error sending VLAN delete PCCD GRPC message: %v |
| Info |
Application |
Deleting F5StaticRoute crd: %v |
| Info |
Application |
StaticRoute Delete Protobuf template processing error: %v |
| Info |
Application |
Sending StaticRoute %s delete message to %v |
| Error |
Application |
Error deleting StaticRoute delete with error: %v |
| Info |
Application |
Deleting F5Snatpool crd: %v |
| Info |
Application |
Snatpool Delete Protobuf template processing error: %v |
| Info |
Application |
Sending Snatpool delete message to %s:%s |
| Info |
Application |
Error deleting SNAT Pool with error: %v |
| Info |
Application |
Deleting F5SPKEgress crd: %v |
| Info |
Application |
Error during GRPC delete message generation for Pem Policy: %v |
| Info |
Application |
Error during sending pem Policy delete GRPC message: %v |
| Info |
Application |
Error updating Ingress/Egress UDP in deletecrd with error: %v |
| Info |
Application |
Sending Ingress/Egress UDP update in deletecrd message to %s:%s |
| Info |
Application |
Error updating Ingress/Egress UDP in deletecrd protobuf with error: %v |
| Info |
Application |
Ingress/Egress UDP Delete Protobuf template processing error: %v |
| Info |
Application |
Sending Ingress/Egress UDP delete message to %s:%s |
| Info |
Application |
Error deleting Ingress/Egress UDP protobuf with error: %v |
| Info |
Application |
Deleting crd key: %v, service: %v, members: %v |
| Info |
Application |
Ingress HTTP2 Delete Protobuf template processing error: %v |
| Info |
Application |
Sending Ingress HTTP2 delete message to %s:%s |
| Info |
Application |
Error deleting Ingress HTTP2 protobuf with error: %v |
| Info |
Application |
Adding TMM Service Port %s |
| Info |
Application |
Removing TMM Service Port %s prefix: %s |
| Info |
Application |
service ports key %s |
| Info |
Application |
Adding to removallist %s |
| Error |
Application |
Error getting opening config tab pbuf %v |
| Error |
Application |
Error getting closing config tab pbuf %v |
| Info |
Application |
Error in generating Pre-Canned License Config, not applied to TMM |
| Debug |
Application |
Use case config sent |
| Debug |
Application |
Static route config sent |
| Debug |
Application |
Annotation Channel is ready to write |
| Debug |
Application |
To close the channel written false in channel after any error |
| Debug |
Application |
Written true in channel to unblock annotation |
| Error |
Application |
Error in reconfiguring TMM %v |
| Error |
Application |
Error in reconfiguring PCCD %v |
| Error |
Application |
Error in reconfiguring IPSD %v |
| Error |
Application |
Error in reconfiguring Downloader Pod %v |
| Error |
Application |
Error in reconfiguring GSLB %v |
| Error |
Application |
Error in reconfiguring DNSX %v |
| Info |
Application |
getGRPCCompleteConfigKey %s-%s |
| Error |
Application |
Ingress Egress Delete Protobuf template processing error: %v |
| Error |
Application |
| Error |
Application |
Error during GRPC delete message generation for FTP: %v |
| Error |
Application |
Error during PCCD GRPC delete message generation for FTP: %v |
| Error |
Application |
Error during GRPC delete message generation for TFTP: %v |
| Error |
Application |
Error during PCCD GRPC delete message generation for TFTP: %v |
| Error |
Application |
Error during GRPC delete message generation for ZERORATINGIRULE: %v |
| Error |
Application |
Error during GRPC delete message generation for RTSP: %v |
| Error |
Application |
Error during PCCD GRPC delete message generation for RTSP: %v |
| Error |
Application |
Error during GRPC delete message generation for PPTP: %v |
| Error |
Application |
Error during PCCD GRPC delete message generation for PPTP: %v |
| Error |
Application |
Error during GRPC delete message generation for Datagroup: %v |
| Error |
Application |
PemPolicy Delete Protobuf template processing error: %v |
| Error |
Application |
Error during sending delete GRPC message: %v |
| Error |
Application |
Error during sending delete PCCD GRPC message: %v |
| Info |
Application |
Triggering the tcp vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Error updating vlan list: %v |
| Info |
Application |
Triggering the udp vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the gtp vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the ngap vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the diameter vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the egress vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the Ingress Egress UDP vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the Ingress HTTP2 vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Triggering the HTTP2 egress vlan list update. Old List: %v - New List: %v |
| Info |
Application |
Resource found in category map. Name: %s Category: %s |
| Info |
Application |
Adding Resource to category map. Name: %s Category: %s |
| Info |
Application |
Infra related configs are allowed without license activation |
| Info |
Application |
Configs are not allowed since license is not activated |
| Info |
Application |
unable to translate address for grpcconfig: %v |
| Info |
Application |
Error parsing config as template %v |
| Error |
Application |
Unable to update gRPC endpoints %v |
| Info |
Application |
grpcRetryHandler: Logging Retry count %d for err: %v |
| Info |
Application |
Received configuration update but %s is not enabled |
| Info |
Application |
Received configuration update but no endpoints found for %s |
| Info |
Application |
Connected via %s to %s on ports %v successfully |
| Info |
Application |
Pre-Canned License config being applied. |
| Info |
Application |
Updating %d %s endpoints: %v |
| Info |
Application |
Setting %d %s endpoints: %v |
| Error |
Application |
Error deleting TMM service from namespace %s |
| Error |
Application |
Error generating random mac address: %v |
| Error |
Application |
Error getting node's mac address: %v |
| Error |
Application |
Ignoring event since received object is nil |
| Error |
Application |
error while updating status of %v CR: %v |
| Info |
Application |
Finalizer event, do nothing |
| Error |
Application |
Unexpected CRUD operation is received for object: %v |
| Info |
Application |
Adding CR event in sync queue: %v |
| Info |
Application |
Registering controller for %s |
| Info |
Application |
Starting controller for %s |
| Info |
Application |
Starting resource.TypeController != nil |
| Error |
Application |
Error retrieving installed CRD's: %v |
| Debug |
Application |
Report: %#v |
| Error |
Application |
Unable to get cached gRPC service object: %v |
| Info |
Application |
Endpoint task key not namespaced. Exiting syncEndpoint with no action taken |
| Info |
Application |
Scaled Up endpoint list: %+v |
| Info |
Application |
TMM gRPC endpoint scaled down |
| Info |
Application |
Endpoint does not get changed |
| Info |
Application |
This is not endpoint update event |
| Info |
Application |
Managing VLAN/SelfIP Mapping from TMM scaling event |
| Info |
Application |
Managing Snatpool Mapping from TMM scaling event |
| Info |
Application |
Managing Egress DNS46 Mapping from TMM scaling event |
| Info |
Application |
Managing Alternate Address Mapping from TMM scaling event |
| Info |
Application |
Managing NGAP Alternate Address Mapping from TMM scaling event |
| Info |
Application |
Managing TMM Internal IP Addresses from TMM scaling event |
| Info |
Application |
Managing HTTP2 Internal IP Addresses from TMM scaling event |
| Info |
Application |
key %s does not match namespace/name pattern |
| Info |
Application |
Namespace unhandled %s |
| Info |
Application |
TMM pod with %v IP is not ready |
| Error |
Application |
Heartbeat from tmm grpc server is failed. |
| Error |
Application |
Error getting the index for %v namespace\n. |
| Info |
Application |
Mismatch found in TCP endpoints, Requeuing... |
| Info |
Application |
Mismatch found in UDP endpoints, Requeuing... |
| Info |
Application |
Mismatch found in Diameter endpoints, Requeuing... |
| Info |
Application |
Mismatch found in Ingress/Egress UDP endpoints, Requeuing... |
| Info |
Application |
Mismatch found in HTTP2 endpoints, Requeuing... |
| Debug |
Application |
Syncing configmap %v |
| Info |
Application |
Task: %v |
| Info |
Application |
ServiceTypeLB: syncService for task: %v |
| Info |
Application |
Service task key not namespaced. Exiting syncService with no action taken |
| Info |
Application |
Issue syncing service, unhandled service namespace: %s |
| Info |
Application |
ServiceTypeLB: syncApplicationNSService for task: %v |
| Info |
Application |
Deleting Service: %v |
| Info |
Application |
Adding or Updating Service: %v |
| Debug |
Application |
Error getting endpoints for service %s from the cache: %v |
| Debug |
Application |
Error getting endpoints for service %s port %v: %v |
| Debug |
Application |
lbc.createTmmLBService: %v |
| Error |
Application |
Error getting TMM service in namespace %s |
| Info |
Application |
No remaining ports. Deleting service %s |
| Warning |
Application |
TMM service update failed: %v |
| Info |
Application |
Not creating service %s, disabled by lbc.createTmmLBService flag |
| Info |
Application |
service does not exist %s, creating |
| Warning |
Application |
Expected just one argument but received more. Ignoring the args |
| Info |
Application |
Error getting service %v: %v |
| Info |
Application |
Getting endpoints for Service: %v |
| Warning |
Application |
Error retrieving endpoints for the service %v: %v |
| Warning |
Application |
NOT considering the pool member : %v for pushing to tmm as the ratio : %v |
| Error |
Application |
Error getting list of kube nodes: %v |
| Error |
Application |
Error getting list of kube pods: %v |
| Error |
Application |
Error getting vtep IP: %v |
| Error |
Application |
Error getting gateway address: %v |
| Info |
Application |
Writing to configmap |
| Error |
Application |
Error listing pods : %v |
| Info |
Application |
Reading configmap data |
| Error |
Application |
Failed in GetScale with %s |
| Error |
Application |
Failed in UpdateScale with %s |
| Info |
Application |
Successfully scaled TMM deployment to %v |
| Info |
Application |
spawn grpc %v ipsd %v |
| Info |
Application |
pccd %v pccd container %v |
| Info |
Application |
Resouce Controller already started |
| Error |
Application |
License is not enabled.. skip Resource controllers |
| Error |
Application |
grpcSvc is not created skip Resource controllers |
| Error |
Application |
pccd endpoint is not created |
| Error |
Application |
Ipsd endpoint is not created |
| Info |
Application |
starting Resource Controllers |
| Error |
Application |
Error getting the alias name for the task %v\n. |
| Info |
Application |
Address-list doesn't exist with key: %v\n |
| Error |
Application |
Error when deleting configuration for %v: %v |
| Error |
Application |
Error on the type of AddressList object with key %v. |
| Error |
Application |
Error when creating configuration for %v: %v |
| Info |
Application |
Deleting %s: %v\n |
| Info |
Application |
Adding or Updating F5AddressList: %v\n |
| Error |
Application |
Error: %v |
| Error |
Application |
Error with AddOrUpdateF5AddressList configuration for %v: %v |
| Info |
Application |
For service %v: %v |
| Info |
Application |
error getting service %v from the cache: %v\n |
| Info |
Application |
createAddressList: %v |
| Info |
Application |
Error received unexpected object: %v |
| Info |
Application |
Adding Address List: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-addressList object: %v |
| Info |
Application |
Removing AddressList: %v |
| Info |
Application |
AddressList %v changed, syncing |
| Info |
Application |
Unhandled objectType |
| Error |
Application |
Error updating endpoints for %v/%v: %v, skipping |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Error |
Application |
BFD |
| Error |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-Pod object %v |
| Error |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Error |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Info |
Application |
BFD |
| Warning |
Application |
BFD |
| Info |
Application |
BFD |
| Error |
Application |
BFD |
| Error |
Application |
BFD |
| Error |
Application |
BFD |
| Info |
Application |
Adding or Updating F5DpiPeOptions: %v\n |
| Error |
Application |
Error on the type of dpiPeOptions object with key %v. |
| Error |
Application |
Error with AddOrUpdateF5DpiPeOptions configuration for %v: %v |
| Info |
Application |
createDpiPeOptions: %v |
| Info |
Application |
Setting sys db variables: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-DpiPeOptions object: %v |
| Info |
Application |
Removing DpiPeOptions: %v |
| Info |
Application |
DpiPeGlobalOptions %v changed, syncing |
| Info |
Application |
Creating default dpiPeOptions CR |
| Error |
Application |
Failed to create default F5DpiPeOptions CR |
| Info |
Application |
Waiting for Resource quota state to update after delete, before creating default F5DpiPeOptions CR: %v |
| Info |
Application |
Created default F5DpiPeOptions CR |
| Info |
Application |
unhandled kind %s |
| Error |
Application |
StoreToDpiPeOptionsLister pointer is nil |
| Info |
Application |
Unexpected object in F5DpiPeOptions lister. |
| Info |
Application |
Classification Profile does not exist with key:%v |
| Error |
Application |
Error on the type of PPTP object with key %v. |
| Info |
Application |
Adding or Updating F5DpiProfile: %v\n |
| Error |
Application |
Error with AddOrUpdateF5DpiProfile configuration for %v: %v |
| Info |
Application |
createDpiProfile: %v |
| Info |
Application |
Adding F5DPIProfile: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-DpiProfile object: %v |
| Info |
Application |
Removing DpiProfile: %v |
| Info |
Application |
Classification Profile %v changed, syncing |
| Error |
Application |
StoreToDpiProfileLister pointer is nil |
| Info |
Application |
Unexpected object in F5DpiProfile lister. |
| Error |
Application |
Error. Deleting not existed F5CommonDownloaderPolicy: %v\n |
| Info |
Application |
Common Downloader Profile does not exist with key:%v |
| Error |
Application |
Error on the type of the Common Downloader Policy object with key %v. |
| Error |
Application |
Error when creating the configuration for %v: %v |
| Info |
Application |
Deleting F5CommonDownloaderPolicy: %v\n |
| Error |
Application |
Error when deleting the config for F5CommonDownloaderPolicy %v: %v |
| Info |
Application |
Updating F5CommonDownloaderPolicy: %v\n |
| Info |
Application |
Adding F5CommonDownloaderPolicy: %v\n |
| Error |
Application |
ERROR with add or update config of Common Downloader Policy for %v: %v |
| Info |
Application |
Creating CommonDownloaderPolicy: %v |
| Info |
Application |
Adding Common Downloder Profile : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non Common Downloader Profile object: %v |
| Info |
Application |
Removing CommonDownloaderPolicy: %v |
| Info |
Application |
Common Downloader Policy %v changed, syncing |
| Info |
Application |
Data Group Reource does not exist with key:%v |
| Error |
Application |
Error on the type of Data Group object with key %v. |
| Info |
Application |
Adding or Updating F5Datagroup: %v\n |
| Error |
Application |
Error with AddOrUpdateF5Datagroup configuration for %v: %v |
| Info |
Application |
createF5Datagroup: %v |
| Info |
Application |
Adding F5Datagroup: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5Datagroup object: %v |
| Info |
Application |
Removing F5Datagroup: %v |
| Info |
Application |
dataGroup :%v changed, syncing |
| Info |
Application |
Updating Endpoints for %v |
| Error |
Application |
Error updating endpoints for %v: %v |
| Error |
Application |
StoreToF5DatagroupLister pointer is nil |
| Info |
Application |
Unexpected object in F5Datagroup lister. |
| Info |
Application |
Diameter Reource does not exist with key:%v |
| Error |
Application |
Error updating altaddresstmmipmap: %v |
| Info |
Application |
Adding or Updating F5SPKIngressDiameter: %v\n |
| Info |
Application |
createF5SPKIngressDiameter: %v |
| Info |
Application |
AvailableAlternateAddressList to be assigned: %v\n |
| Info |
Application |
Alternate Addresses and TMM IP mapping read fro configMap: %v\n |
| Error |
Application |
Error when reading configmap %v: |
| Error |
Application |
No available Custom Resource for F5SPKIngressDiameter CRD |
| Error |
Application |
error while getting F5diameter alias object from store by CR name: %v |
| Info |
Application |
TMM to alternate addresses assignment: %v\n |
| Error |
Application |
Error grpc service not available: %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressDiameter configuration for %v: %v; TmmToAddList: %v |
| Info |
Application |
Now Managing TMM Alt Addresses Assignments |
| Info |
Application |
Alternate addresses and TMM Ips mappings read from configmap: %v |
| Info |
Application |
Alt addresses to be updated/removed list: %v |
| Info |
Application |
CRD EDIT case started |
| Info |
Application |
TMM to alternate addresses assignment: %v |
| Info |
Application |
TMM Scale or CRD install \n |
| Info |
Application |
Alternate address range is not available for assigning to TMMs |
| Error |
Application |
Error disassociating alternate addresses from TMM. Alternate addresses does not exists in map. |
| Info |
Application |
lbc.altAddressesTMMPodIP: %v\n |
| Info |
Application |
Adding F5SPKIngressDiameter: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKIngressDiameter object: %v |
| Info |
Application |
Removing F5SPKIngressDiameter: %v |
| Info |
Application |
F5SPKIngressDiameter %v changed, syncing |
| Info |
Application |
Unhandled objectType: %s |
| Info |
Application |
Endpoint mismatch for service name: %s - initialTotalEndps len: %d - totalEndps len: %d |
| Warning |
Application |
**CRD Kind IngressRouteDiameter is Deprecated instead use F5SPKIngressDiameter |
| Info |
Application |
Adding IngressRouteDiameter: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteDiameter object: %v |
| Info |
Application |
Removing IngressRouteDiameter: %v |
| Warning |
Application |
**CRD kind IngressRouteDiameter is Deprecated instead use F5SPKIngressDiameter |
| Info |
Application |
IngressRouteDiameter %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteDiameters CR: %v |
| Info |
Application |
Error creating F5SPKIngressDiameters from old CR %+v of kind IngressRouteDiameter |
| Info |
Application |
Error Deleting converted F5SPKIngressDiameters %+v |
| Error |
Application |
Error retrieving installed deprecated IngressRouteDiameters CR: %v |
| Error |
Application |
Error retrieving CR: %v |
| Info |
Application |
Error updating converted F5SPKIngressDiameters from old CR %+v of kind IngressRouteDiameter |
| Info |
Application |
Unexpected object in F5Dns lister. |
| Error |
Application |
Error in key %s. The format of a key should be namespace/name. |
| Info |
Application |
Dns config doesn't exist with key: %v\n |
| Error |
Application |
Error on the type of Dns object with key %v. |
| Info |
Application |
Adding or Updating %s: %v\n |
| Error |
Application |
Error with AddOrUpdateF5Dns configuration for %v: %v |
| Info |
Application |
createF5Dns: %v |
| Info |
Application |
Adding F5Dns: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5Dns object: %v |
| Info |
Application |
Removing F5Dns: %v |
| Info |
Application |
F5Dns %v changed, syncing |
| Info |
Application |
Adding F5Dnscache: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5Dnscache object: %v |
| Info |
Application |
Removing F5Dnscache: %v |
| Info |
Application |
F5Dnscache %v changed, syncing |
| Info |
Application |
Dnscache config doesn't exist with key: %v |
| Error |
Application |
Error on the type of the dnscache object with key %v. |
| Info |
Application |
Adding or Updating F5Dnscache: %v\n |
| Error |
Application |
Error with AddOrUpdateF5Dnscache configuration for %v: %v |
| Info |
Application |
createDnscache: %v |
| Info |
Application |
Adding F5DnsxGlobalOptions: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5DnsxGlobalOptions object: %v |
| Info |
Application |
Removing F5DnsxGlobalOptions: %v |
| Info |
Application |
F5DnsxGlobalOptions %v changed, syncing |
| Info |
Application |
Dnsxglobaloptions does not exist with key:%v |
| Error |
Application |
Error on the type of the dnsxglobaloptions object with key %v. |
| Info |
Application |
Adding or Updating F5DnsxGlobalOptions: %v\n |
| Error |
Application |
Error with AddOrUpdateF5DnsxGlobalOptions configuration for %v: %v |
| Info |
Application |
createDnsxglobaloptions: %v |
| Info |
Application |
Adding F5DnsZone: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5DnsZone object: %v |
| Info |
Application |
Removing F5DnsZone: %v |
| Info |
Application |
F5DnsZone %v changed, syncing |
| Info |
Application |
DNSZone does not exist with key:%v |
| Error |
Application |
Error on the type of the dnszone object with key %v. |
| Info |
Application |
Deleting %s: %v |
| Info |
Application |
Adding or Updating F5DnsZone: %v\n |
| Error |
Application |
Error with AddOrUpdateF5DnsZone configuration for %v: %v |
| Info |
Application |
createDnszone: %v |
| Error |
Application |
AppNS |
| Info |
Application |
Dos config doesn't exist with key: %v |
| Error |
Application |
Error on the type of the Dos object with key %v |
| Info |
Application |
Dos CRD timed out, deleting %s: %v |
| Info |
Application |
Adding or Updating F5Dos : %v\n |
| Error |
Application |
Licensing error: %v |
| Error |
Application |
ERROR with add or update config of DDos for %v: %v\n |
| Info |
Application |
Creating F5Dos: %v |
| Info |
Application |
Adding F5Dos: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-F5Dos object: %v |
| Info |
Application |
Deleting F5Dos: %v |
| Info |
Application |
Updating F5Dos: %v |
| Info |
Application |
Adding or Updating F5DpiApps: %v\n |
| Error |
Application |
Error on the type of dynamicAppsCategories object with key %v. |
| Error |
Application |
Error with AddOrUpdateF5DpiApps configuration for %v: %v |
| Info |
Application |
createDpiApps: %v |
| Info |
Application |
Adding Dynamic Apps Categories: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-DpiApps object: %v |
| Info |
Application |
Removing DpiApps: %v |
| Info |
Application |
Dynamic Profile %v changed, syncing |
| Error |
Application |
StoreToDpiAppsLister pointer is nil |
| Info |
Application |
Unexpected object in F5DpiApps lister. |
| Info |
Application |
f5SPKEgress does not exist with key:%v |
| Info |
Application |
Deleting F5SPKEgress: %v\n |
| Info |
Application |
Adding or Updating F5SPKEgress: %v\n |
| Error |
Application |
Error when creating configuration for %v: bad or missing DnsNat46Ipv4Subnet |
| Error |
Application |
No available Custom Resource for F5SPKSnatpool CRD |
| Error |
Application |
error while getting F5SPKEgressEx alias object from store by CR name: %v |
| Error |
Application |
F5SPKEgress requires a dnsCacheName when dnsNat46Enabled is true. Please delete the %v Egress CR and reconfigure. |
| Error |
Application |
F5SPKEgress out of DNS46 Translation Addresses, too many TMMs. |
| Error |
Application |
F5SPKEgress %v already configured on TMM:%v, configuration will not be modified. |
| Error |
Application |
Error with AddOrUpdateF5SpkEgress configuration for %v: %v; TmmToAddList: %v |
| Info |
Application |
createF5SPKEgressRoute: %v |
| Info |
Application |
Adding F5SPKEgress: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKEgress object: %v |
| Info |
Application |
Removing F5SPKEgress: %v |
| Info |
Application |
F5SPKEgress %v changed, syncing |
| Warning |
Application |
**CRD Kind IngressRouteFastL4 is Deprecated,instead use F5SPKIngressTCP |
| Info |
Application |
Adding IngressRouteFastL4: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteFastL4 object: %v |
| Info |
Application |
Removing IngressRouteFastL4: %v |
| Info |
Application |
IngressRouteFastL4 %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteFastL4s CR: %v |
| Info |
Application |
Error creating F5SPKIngressTCPs from old CR %+v of kind IngressRouteFastL4 |
| Info |
Application |
Error Deleting converted F5SPKIngressTCPs %+v |
| Error |
Application |
Error retrieving installed IngressRouteFastL4 CR: %v |
| Info |
Application |
Error updating converted F5SPKIngressTCPs from old CR %+v of kind IngressRouteFastL4 |
| Error |
Application |
Error getting the alias name for the task |
| Info |
Application |
Deleting pod FastL4 profile config |
| Error |
Application |
Error when deleting configuration: %v |
| Error |
Application |
Error on the type of fastL4 object with key |
| Error |
Application |
Error when creating the configuration: %v |
| Error |
Application |
Error while getting staticroute alias object from store by CR name |
| Error |
Application |
Error with add or update config of FastL4 Profile: %v |
| Info |
Application |
Creating FastL4 Profile |
| Info |
Compliance |
Adding FastL4 |
| Info |
Compliance |
Error DeletedFinalStateUnknown contained non-FastL4 object: %v |
| Info |
Compliance |
Removing FastL4 Profile |
| Info |
Compliance |
FastL4 changed, syncing |
| Error |
Application |
Error. Deleting not existed F5FirewallPolicy: %v\n. |
| Info |
Application |
FirewallPolicy doesn't exist with key: %v\n. |
| Error |
Application |
Error when deleting the config for F5FirewallPolicy %v: %v |
| Error |
Application |
Error on the type of the firewallPolicy object with key %v. |
| Info |
Application |
Deleting F5FirewallPolicy: %v\n |
| Info |
Application |
Updating F5FirewallPolicy: %v\n |
| Info |
Application |
Adding F5FirewallPolicy: %v\n |
| Error |
Application |
ERROR with add or update config of firewall policy for %v: %v |
| Info |
Application |
Creating FIREWALL Policy: %v |
| Info |
Application |
Error received unexpected object (add): %v |
| Info |
Application |
Adding Firewall Policy : %v |
| Info |
Application |
Error received unexpected object (delete): %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non FirewallPolicy object: %v |
| Info |
Application |
Removing FirewallPolicy: %v |
| Info |
Application |
Error received unexpected object (update): %v |
| Info |
Application |
Firewall Policy %v changed, syncing |
| Error |
Application |
Error. Deleting not existed F5FirewallRulelist: %v\n |
| Info |
Application |
Deleting F5FirewallRulelist: %v\n |
| Error |
Application |
Error when deleting the config for F5FirewallRulelist %v: %v |
| Info |
Application |
Updating F5FirewallRulelist: %v\n |
| Info |
Application |
Adding F5FirewallRulelist: %v\n |
| Error |
Application |
Error on the type of firewallRulelist object with key %v. |
| Error |
Application |
ERROR with add or update config of firewall rulelist for %v: %v |
| Info |
Application |
Creating FIREWALL Rulelist: %v |
| Info |
Application |
Adding Firewall Rulelist : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non FirewallRulelist object: %v |
| Info |
Application |
Removing FirewallRulelist: %v |
| Info |
Application |
Firewall Rulelist %v changed, syncing |
| Error |
Application |
Error. Deleting not existed FTP: %v\n |
| Info |
Application |
FTP Resource does not exist with key:%v |
| Error |
Application |
Error on the type of FTP object with key %v. |
| Info |
Application |
Adding or Updating F5FTP: %v\n |
| Error |
Application |
Error with AddOrUpdateF5FTP configuration for %v: %v |
| Info |
Application |
createF5FTP: %v |
| Info |
Application |
Adding F5FTP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5FTP object: %v |
| Info |
Application |
Removing F5FTP: %v |
| Info |
Application |
F5FTP %v changed, syncing |
| Info |
Application |
Unexpected object in F5FTP lister. |
| Error |
Application |
StoreToF5FTPLister pointer is nil |
| Error |
Application |
Error. Deleting not existed GlobalContext: %v\n. |
| Info |
Application |
Deleting GlobalContext: %v\n |
| Error |
Application |
Error when deleting the config for F5GlobalContext %v: %v |
| Info |
Application |
Updating F5GlobalContext: %v\n |
| Info |
Application |
Adding F5GlobalContext: %v\n |
| Error |
Application |
Error on the type of the GlobalContext object with key %v. |
| Error |
Application |
ERROR with add or update config of GlobalContextAddErr for %v: %v |
| Info |
Application |
Creating Global Context: %v |
| Info |
Application |
Adding Global Context : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non globalContext object: %v |
| Info |
Application |
Removing globalContext: %v |
| Info |
Application |
Global context %v changed, syncing |
| Info |
Application |
Unable to fetch gRPC service object from cache: %v |
| Info |
Application |
unable to handle gRPC service update, service does not exist in cache |
| Info |
Application |
Error getting grpc endpoint from cache %v |
| Info |
Application |
Ignoring %v, does not match Grpc service name %s |
| Info |
Application |
Error getting controller namespace service from cache %v |
| Info |
Application |
Deleting Service: %v\n |
| Info |
Application |
Error encountered handling the deletion of gRPC service: %v |
| Info |
Application |
Error encountered handling the updating of gRPC service: %v |
| Info |
Application |
Service %s is NOT gRPC service |
| Error |
Application |
Unable to update GSLB Engine gRPC endpoints of TMM type: %v |
| Info |
Application |
Unable to update TMM gRPC endpoints: %v |
| Error |
Application |
CRD Update POD_IP env missing. |
| Info |
Application |
CRD Update gRPC endpoint: [%s]:%d |
| Error |
Application |
Error in getting the alias name for the task %v\n. |
| Error |
Application |
Error in deleting configuration for %v: %v |
| Error |
Application |
Error in the type of GslbDatacenter object with key %v. |
| Error |
Application |
Error in creating configuration for %v: %v |
| Error |
Application |
Error in AddOrUpdateF5GslbDatacenter configuration for %v: %v |
| Info |
Application |
createF5GslbDatacenter: %v |
| Info |
Application |
Adding F5GslbDatacenter: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5GslbDatacenter object: %v |
| Info |
Application |
Removing F5GslbDatacenter %v |
| Info |
Application |
F5GslbDatacenter %v changed, syncing |
| Info |
Application |
Unexpected object in F5GslbDatacenter lister. |
| Error |
Application |
Error in getting the alias name for the task %v. |
| Error |
Application |
Error in the type of GslbMonitor object with key %v. |
| Error |
Application |
Error in AddOrUpdateF5GslbMonitor configuration for %v: %v |
| Info |
Application |
createF5GslbMonitor: %v |
| Info |
Application |
Adding F5GslbMonitor: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5GslbMonitor object: %v |
| Info |
Application |
Removing F5GslbMonitor %v |
| Info |
Application |
F5GslbMonitor %v changed, syncing |
| Info |
Application |
Unexpected object in F5GslbMonitor lister. |
| Error |
Application |
Error in the type of GslbPool object with key %v. |
| Error |
Application |
Error in AddOrUpdateF5GslbPool configuration for %v: %v |
| Info |
Application |
createF5GslbPool: %v |
| Info |
Application |
Adding F5GslbPool: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5GslbPool object: %v |
| Info |
Application |
Removing F5GslbPool %v |
| Info |
Application |
F5GslbPool %v changed, syncing |
| Info |
Application |
Unexpected object in F5GslbPool lister. |
| Error |
Application |
Error in the type of GslbServer object with key %v. |
| Error |
Application |
Error in AddOrUpdateF5GslbServer configuration for %v: %v |
| Info |
Application |
createF5GslbServer: %v |
| Info |
Application |
Adding F5GslbServer: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5GslbServer object: %v |
| Info |
Application |
Removing F5GslbServer %v |
| Info |
Application |
F5GslbServer %v changed, syncing |
| Info |
Application |
Unexpected object in F5GslbServer lister. |
| Error |
Application |
Error in the type of GslbWideip object with key %v. |
| Error |
Application |
Error in AddOrUpdateF5GslbWideip configuration for %v: %v |
| Info |
Application |
createF5GslbWideip: %v |
| Info |
Application |
Adding F5GslbWideip: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5GslbWideip object: %v |
| Info |
Application |
Removing F5GslbWideip %v |
| Info |
Application |
F5GslbWideip %v changed, syncing |
| Info |
Application |
Unexpected object in F5GslbWideip lister. |
| Error |
Application |
Error getting the index for the namespace\n. |
| Error |
Application |
Error getting the index for the namespace. |
| Info |
Application |
GTP does not exist with key:%v |
| Info |
Application |
Adding or Updating F5SPKIngressGTP: %v\n |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressGTP configuration for %v: %v |
| Info |
Application |
createF5SPKIngressGTP: %v |
| Info |
Application |
Adding F5SPKIngressGTP: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKIngressGTP object: %v |
| Info |
Application |
Removing F5SPKIngressGTP: %v |
| Info |
Application |
F5SPKIngressGTP %v changed, syncing |
| Info |
Application |
hslpublisher does not exist with key:%v |
| Error |
Application |
Error on the type of the protocol inspection profile object with key %v. |
| Info |
Application |
Adding or Updating F5Hslpub: %v\n |
| Error |
Application |
Error with AddOrUpdateF5Hslpub configuration for %v: %v |
| Info |
Application |
createF5Hslpub: %v |
| Info |
Application |
Adding HSL Publisher : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non Hslpub object: %v |
| Info |
Application |
Removing Hslpub: %v |
| Info |
Application |
HSL Publisher %v changed, syncing |
| Info |
Application |
HTTP2 does not exist with key:%v |
| Info |
Application |
Adding or Updating F5SPKIngressHTTP2: %v\n |
| Info |
Application |
createF5SPKIngressHTTP2: %v |
| Error |
Application |
No available Custom Resource for F5SPKIngressHTTP2 CRD |
| Error |
Application |
Error while getting F5http2 alias object from store by CR name: %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressHTTP2 configuration for %v: %v; TmmToAddList: %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressHTTP2 configuration for %v: %v; TmmIPList: %v |
| Info |
Application |
Adding F5SPKIngressHTTP2: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKIngressHTTP2 object: %v |
| Info |
Application |
Removing F5SPKIngressHTTP2: %v |
| Info |
Application |
F5SPKIngressHTTP2 %v changed, syncing |
| Info |
Application |
Endpoint mismatch for App name: %s - initialTotalEndps len: %d - totalEndps len: %d |
| Info |
Application |
ieUDP does not exist with key:%v |
| Info |
Application |
Adding or Updating F5SPKIngressEgressUDP: %v\n |
| Info |
Application |
createF5SPKIngressEgressUDP: %v |
| Error |
Application |
No available Custom Resource for F5SPKIngressEgressUDP CRD |
| Error |
Application |
error while getting F5ieUDP alias object from store by CR name: %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressEgressUDP configuration for %v: %v; TmmToAddList: %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressEgressUDP configuration for %v: %v; TmmIPList: %v |
| Info |
Application |
Adding F5SPKIngressEgressUDP: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKIngressEgressUDP object: %v |
| Info |
Application |
Removing F5SPKIngressEgressUDP: %v |
| Info |
Application |
F5SPKIngressEgressUDP %v changed, syncing |
| Info |
Application |
unhandled objectType %s |
| Info |
Application |
Irule Resource does not exist with key:%v |
| Error |
Application |
Error on the type of Irule object with key %v. |
| Info |
Application |
Adding or Updating F5Irule: %v\n |
| Error |
Application |
Error with AddOrUpdateF5Irule configuration for %v: %v |
| Info |
Application |
createF5Irule: %v |
| Info |
Application |
Adding F5Irule: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5Irule object: %v |
| Info |
Application |
Removing F5Irule: %v |
| Info |
Application |
irule :%v changed, syncing |
| Info |
Application |
Security log profile doesn't exist with key %v\n |
| Error |
Application |
Error on the type of LogProfile object with key %v. |
| Info |
Application |
Adding or Updating LogProfile: %v\n |
| Error |
Application |
Error with AddOrUpdateF5LogProfile configuration for %v: %v |
| Info |
Application |
createF5LogProfile: %v |
| Info |
Application |
Adding LogProfile: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-LogProfile object: %v |
| Info |
Application |
Removing LogProfile: %v |
| Info |
Application |
LogProfile %v changed, syncing |
| Info |
Application |
Adding Namespace: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained Namespace object: %v |
| Info |
Application |
Removing Namespace: %v |
| Info |
Application |
Add Namespace: %v key: %v |
| Info |
Application |
Add annotation TMM Pod For VLAN: %v |
| Info |
Application |
Delete Namespace: %v |
| Info |
Application |
Remove annotation TMM Pod For VLAN: %v |
| Info |
Application |
NatPolicy doesn't exist with key: %v\n |
| Error |
Application |
Error when deleting the config for F5NatPolicy %v: %v |
| Error |
Application |
Error on the type of the NatPolicy object with key %v. |
| Info |
Application |
Deleting F5NatPolicy: %v\n |
| Info |
Application |
Updating F5NatPolicy: %v\n |
| Info |
Application |
Adding F5NatPolicy: %v\n |
| Error |
Application |
ERROR with add or update config of nat policy for %v: %v |
| Info |
Application |
Adding NAT Policy : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-NatPolicy object: %v |
| Info |
Application |
Removing NAT policy: %v |
| Info |
Application |
Nat Policy %v changed, syncing |
| Error |
Application |
NGAP resource does not exist with key:%v |
| Error |
Application |
Error updating altNGAPaddresstmmipmap: %v |
| Info |
Application |
Adding or Updating F5SPKIngressNGAP: %v\n |
| Info |
Application |
createF5SPKIngressNGAP: %v |
| Info |
Application |
createF5SPKIngressNGAP Service name: %v |
| Error |
Application |
Error getting gateway address for endpoint: %v |
| Info |
Application |
lbc.NGAPSctpAlternateIpsTMMPodIP: %v\n |
| Error |
Application |
Error disassociating alternate addresses from TMM. Alternate addresses does not exists in map |
| Error |
Application |
No available Custom Resource for F5SPKIngressNgap CRD |
| Error |
Application |
error while getting F5SPKNGAP alias object from store by CR name: %v kind %v NS %v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressNGAP configuration for %v: %v; TmmToAddList: %v |
| Error |
Application |
No available Custom Resource for F5SPKIngressNGAP CRD |
| Error |
Application |
Error while getting F5SPKNGAP alias object from store by CR name. |
| Info |
Application |
ManageNGAPSctpAlternateIpsTMMPodIP |
| Info |
Application |
Adding F5SPKIngressNGAP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKIngressNGAP object: %v |
| Info |
Application |
Removing F5SPKIngressNGAP: %v |
| Info |
Application |
F5SPKIngressNGAP %v changed, syncing |
| Error |
Application |
Error updating NGAP endpoints for %v/%v: %v, skipping |
| Debug |
Application |
PE profile config doesn't exist with key: %v |
| Error |
Application |
Error on the type of the PemProfile object with key %v |
| Info |
Application |
PE profile CRD timed out, deleting %s: %v |
| Info |
Application |
Updating %s: %v\n |
| Info |
Application |
Adding %s: %v\n |
| Error |
Application |
Error: with add or update config of PE Profile for %v: %v |
| Info |
Application |
Creating PE Profile: %v |
| Info |
Application |
Adding PE Profile: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-PeProfile object: %v |
| Info |
Application |
Deleting PE Profile: %v |
| Info |
Application |
Updating PE Profile: %v |
| Debug |
Application |
PE Policy config doesn't exist with key: %v |
| Error |
Application |
Error when deleting configuration for %s %v: %v |
| Error |
Application |
Error on the type of the PE Policy object with key %v |
| Info |
Application |
PE policy CRD timed out, deleting %s: %v |
| Info |
Application |
Updating PE Policy: %v\n |
| Info |
Application |
Adding PE Policy: %v\n |
| Error |
Application |
Error with add or update config of PE policy for %v: %v |
| Info |
Application |
Creating PE Policy: %v |
| Info |
Application |
Adding PE Policy: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-PePolicy object: %v |
| Info |
Application |
Deleting PE Policy: %v |
| Info |
Application |
Updating PE Policy: %v |
| Error |
Application |
Alias name is %v\n. |
| Error |
Application |
Error. Deleting not existed Pool: %v\n |
| Error |
Application |
Error when deleting the config for %s %v: %v |
| Error |
Application |
Error on the type of the Pool object with key %v. |
| Error |
Application |
Error with AddOrUpdatePool configuration for %v: %v |
| Info |
Application |
Create Pool: %v |
| Info |
Application |
Adding Pool: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-Pool object: %v |
| Info |
Application |
Removing Pool: %v |
| Info |
Application |
| Info |
Application |
portlist does not exist with key:%v |
| Error |
Application |
Error on the type of PortList object with key %v. |
| Info |
Application |
Adding or Updating F5AddF5PortListressList: %v\n |
| Error |
Application |
Error with AddOrUpdateF5PortList configuration for %v: %v |
| Info |
Application |
createPortList: %v |
| Info |
Application |
Adding Port List: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-PortList object: %v |
| Info |
Application |
Removing PortList : %v |
| Info |
Application |
PortList %v changed, syncing |
| Info |
Application |
pptp does not exist with key:%v |
| Info |
Application |
Adding or Updating F5PPTP: %v\n |
| Error |
Application |
Error with AddOrUpdateF5PPTP configuration for %v: %v |
| Info |
Application |
createF5PPTP: %v |
| Info |
Application |
Adding F5PPTP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5PPTP object: %v |
| Info |
Application |
Removing F5PPTP: %v |
| Info |
Application |
F5PPTP %v changed, syncing |
| Info |
Application |
Unexpected object in F5PPTP lister. |
| Error |
Application |
StoreToF5PPTPLister pointer is nil |
| Info |
Application |
ProtocolInspectionProfile config doesn't with key: %v\n |
| Error |
Application |
Error when deleting the config for F5ProtocolInspectionProfile %v: %v |
| Info |
Application |
Deleting F5ProtocolInspectionProfile: %v\n |
| Info |
Application |
Updating F5ProtocolInspectionProfile: %v\n |
| Info |
Application |
Adding F5ProtocolInspectionProfile: %v\n |
| Error |
Application |
ERROR with add or update config of protocol inspection profile for %v: %v |
| Info |
Application |
Creating ProtocolInspectionProfile: %v |
| Info |
Application |
Adding Protocol Inspection Profile : %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non Protocol Inspection Profile object: %v |
| Info |
Application |
Removing ProtocolInspectionProfile: %v |
| Info |
Application |
Protocol Inspection Profile %v changed, syncing |
| Info |
Application |
rtsp resource does not exist with key:%v |
| Error |
Application |
Error on the type of RTSP object with key %v. |
| Info |
Application |
Adding or Updating RTSP: %v\n |
| Error |
Application |
Error with AddOrUpdateF5RTSP configuration for %v: %v |
| Info |
Application |
createF5RTSP: %v |
| Info |
Application |
Adding F5RTSP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5RTSP object: %v |
| Info |
Application |
Removing F5RTSP: %v |
| Info |
Application |
F5RTSP %v changed, syncing |
| Info |
Application |
Unexpected object in F5RTSP lister. |
| Error |
Application |
StoreToF5RTSPLister pointer is nil |
| Info |
Application |
Unexpected object in F5SecureContext lister. |
| Info |
Application |
SecureContext config doesn't exist with key %v\n |
| Error |
Application |
Error on the type of the SecureContext object with key %v. |
| Error |
Application |
Error with AddOrUpdateSecureContext configuration for %v: %v |
| Error |
Application |
Failed to write stats-config to annotations with error: %s |
| Info |
Application |
Create SecureContext: %v |
| Info |
Application |
Adding SecureContext: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-SecureContext object: %v |
| Info |
Application |
Removing SecureContext: %v |
| Info |
Application |
SecureContext %v changed, syncing |
| Info |
Application |
Adding ServiceType LB IP Pool: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-serviceTypeLB IP Pool object: %v |
| Info |
Application |
Removing ServiceTypeLBIpPool: %v |
| Info |
Application |
ServiceTypeLBIpPool %v changed, syncing |
| Error |
Application |
Error getting the alias name for the task %v |
| Error |
Application |
Error on the type of AddressList object with key %v |
| Error |
Application |
Error getting the index for the namespace |
| Info |
Application |
Deleting %v\n |
| Error |
Application |
Error getting the index from app namespace list |
| Info |
Application |
createF5SPKIngressSIP |
| Info |
Compliance |
Error DeletedFinalStateUnknown contained non-F5SPKIngressSIP object: %v |
| Info |
Compliance |
CR changed, syncing |
| Error |
Application |
Error updating endpoints: %v, skipping |
| Info |
Application |
Endpoint mismatch - initialTotalEndps len: %d - totalEndps len: %d |
| Error |
Application |
Error when getting snatpool: %v |
| Info |
Application |
SNATPool does not exist with key:%v |
| Error |
Application |
Error updating snatpooltmmipmap: %v |
| Error |
Application |
Error on the type of snatpool object with key |
| Error |
Application |
Error when creating configuration: %v |
| Info |
Application |
Deleting Snatpool |
| Info |
Application |
createF5Snatpool |
| Info |
Application |
AvailableSnatPool to be assigned: %v |
| Info |
Application |
lbc.snatPoolTMMPodIP: %v |
| Error |
Application |
Error when reading configmap: %v |
| Info |
Compliance |
Adding F5Snatpool |
| Info |
Compliance |
Error DeletedFinalStateUnknown contained non-F5Snatpool object: %v |
| Info |
Compliance |
Removing F5Snatpool |
| Info |
Compliance |
F5Snatpool changed, syncing |
| Error |
Application |
Error assigning SNAT pool to TMM. SnatPool range not available |
| Error |
Application |
Error disassociating SNAT pool from TMM. SnatPool does not existing in map |
| Error |
Application |
No available Custom Resource for F5Snatpool CRD |
| Error |
Application |
Error while getting F5Snatpool alias object from store by CR name |
| Info |
Application |
ManageSnatPoolTMMPodIP |
| Info |
Application |
TMM to snatpool assignment: %v |
| Error |
Application |
Error with AddOrUpdateF5Snatpool configuration: %v; TmmToAddList: %v |
| Info |
Application |
DEBUG: ****** |
| Info |
Application |
DEBUG: %v |
| Info |
Application |
DEBUG: lbc.configurator.GetSnatpoolConfig:%v |
| Info |
Application |
DEBUG: lbc.snatPoolTMMPodIP:%v |
| Info |
Application |
DEBUG: lbc.availableSnatPool:%v |
| Warning |
Application |
**CRD Kind IngressRouteSnatpool is Deprecated,instead use F5SPKSnatpool |
| Info |
Application |
Adding IngressRouteSnatpool: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteSnatpool object: %v |
| Info |
Application |
Removing IngressRouteSnatpool: %v |
| Info |
Application |
IngressRouteSnatpool %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteSnatpools CR: %v |
| Info |
Application |
Error creating F5SPKSnatpools from old CR %+v of Kind IngressRouteSnatpool |
| Info |
Application |
Error Deleting converted F5SPKSnatpools %+v |
| Error |
Application |
Error retriving installed IngressRouteSnatpool CR: %v |
| Error |
Application |
Error retrieving F5SPKSnatpool CR: %v |
| Info |
Application |
Error updating converted F5SPKSnatpools from old CR %+v of Kind IngressRouteSnatpool |
| Info |
Application |
StaticRoute does not exist with key:%v |
| Error |
Application |
Error on the type of the static route object |
| Error |
Application |
error while getting staticroute alias object from store by CR name: %v |
| Error |
Application |
Error with AddOrUpdateF5StaticRoute configuration: %v |
| Info |
Application |
createF5StaticRoute |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5StaticRoute object: %v |
| Warning |
Application |
**CRD Kind IngressRouteStaticRoute is Deprecated,instead use F5SPKStaticRoute |
| Info |
Application |
Adding IngressRouteStaticRoute: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteStaticRoute object: %v |
| Info |
Application |
Removing IngressRouteStaticRoute: %v |
| Info |
Application |
IngressRouteStaticRoute %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteStaticRoute CR: %v |
| Info |
Application |
Error creating F5SPKStaticRoute from old CR %+v of Kind IngressRouteStaticRoute |
| Info |
Application |
Error Deleting converted F5SPKStaticRoute %+v |
| Error |
Application |
Error retrieving installed IngressRouteStaticRoutes CR: %v |
| Info |
Application |
Error updating converted F5SPKStaticRoute from old CR %+v of Kind IngressRouteStaticRoute |
| Info |
Application |
TCP Resource does not exist with key:%v |
| Info |
Compliance |
Deleting ingress for TCP |
| Error |
Application |
ServiceName: %s or Namespace: %s is empty |
| Error |
Application |
Error getting index for the namespace |
| Info |
Application |
createF5SPKIngressTCP |
| Debug |
Application |
Node has additional bridge |
| Info |
Application |
Default |
| Info |
Compliance |
Error DeletedFinalStateUnknown contained non-F5SPKIngressTCP object: %v |
| Info |
Application |
Deleting pod TCP profile config |
| Info |
Application |
Adding Updating F5TcpSetting: %v\n |
| Error |
Application |
Error on the type of tcpSetting object with key %v. |
| Error |
Application |
ERROR with add or update config of TCP Profile for %v: %v |
| Info |
Application |
Creating TCP Profile: %v |
| Info |
Application |
Adding TcpSetting: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-TcpSetting object: %v |
| Info |
Application |
Removing TCP Profile: %v |
| Info |
Application |
TcpSetting %v changed, syncing |
| Info |
Application |
TFTP Resource does not exist with key:%v |
| Error |
Application |
Error on the type of TFTP object with key %v. |
| Info |
Application |
Adding or Updating TFTP: %v\n |
| Error |
Application |
Error with AddOrUpdateF5TFTP configuration for %v: %v |
| Info |
Application |
createF5TFTP: %v |
| Info |
Application |
Adding F5TFTP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5TFTP object: %v |
| Info |
Application |
Removing F5TFTP: %v |
| Info |
Application |
F5TFTP %v changed, syncing |
| Info |
Application |
Unexpected object in F5TFTP lister. |
| Error |
Application |
StoreToF5TFTPLister pointer is nil |
| Info |
Application |
Adding pods (scale up): %v |
| Info |
Application |
Adding Active TMM to persist manager name: %s id: %s ip: %s |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-Pod object: %v |
| Info |
Application |
Deleting vlan[%v] tmm[%v] |
| Info |
Application |
Removing pod (scale down): %v |
| Debug |
Application |
IP become available again, check to see if there are tmm haven't been assigned IP |
| Info |
Application |
Pods %v changed, syncing -- Status %s |
| Info |
Application |
TMM pod event qualified: %+v |
| Info |
Application |
Not CNI2.0, skip remove annotation for TMM POD |
| Debug |
Application |
Waiting to annotateTmmPods until all config is applied |
| Debug |
Application |
Annotate channel unblocked, Annotate TmmPods |
| Info |
Application |
Not CNI2.0, skip annotation for TMM POD |
| Info |
Application |
Not CNI2.0, getting the Tmm Pod Internal Vlan from persist manager |
| Info |
Application |
Excluding the tmm %v as its marked with DeletionTimestamp |
| Info |
Application |
Excluding the tmm %v which is in not running |
| Info |
Application |
Evicting the tmm POD %v IP address %v from vlan %v |
| Error |
Application |
Error in updating tmm pod annotations: %v |
| Error |
Application |
Error in deleting tmm pod from vlan: %v |
| Error |
Application |
Error in fetching tmm pod details: %v |
| Info |
Application |
Adding F5SPKTrafficDistribution: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5SPKTrafficDistribution object: %v |
| Info |
Application |
Removing F5SPKTrafficDistribution: %v |
| Info |
Application |
F5SPKTrafficDistribution %v changed, syncing |
| Info |
Application |
Received event on F5SPKTrafficDistribution with task : %v |
| Error |
Application |
Error getting the index for %v namespace |
| Error |
Application |
Error getting traffic distribution lister object with key: %v |
| Info |
Application |
Traffic distribution object with key : %v does not exist\n |
| Info |
Application |
No TCP CR pointing to traffic distribution CR with key: %s |
| Info |
Application |
*: TCP object : %s points to traffic distribution object with key: %s, reconcile TCP |
| Error |
Application |
Error on the type of F5SPKTrafficDistribution for the object with key : %v. |
| Info |
Application |
No TCP CR pointing to traffic distribution CR : %s |
| Info |
Application |
*: TCP object : %s points to traffic distribution CR with name : %s, reconcile TCP |
| Error |
Application |
Store to F5SPKTrafficDistributionLister pointer is nil |
| Error |
Application |
TrafficDistributionName: %s or Namespace: %s is empty |
| Error |
Application |
Error getting TrafficDistribution for the namespace |
| Info |
Application |
Weight %d |
| Error |
Application |
Error getting the index for namespace. |
| Info |
Application |
UDP Resource does not exist with key:%v |
| Error |
Application |
Error with AddOrUpdateF5SPKIngressUDP configuration: %v |
| Info |
Application |
createF5SPKIngressUDP |
| Error |
Application |
Error getting the index from app namespace list. |
| Info |
Compliance |
Error DeletedFinalStateUnknown contained non-F5SPKIngressUDP object: %v |
| Error |
Application |
Error adding or updating: %v |
| Info |
Application |
Unhandled objectTypes |
| Warning |
Application |
**CRD Kind IngressRouteUDP is Deprecated,instead use F5SPKIngressUDP |
| Info |
Application |
Adding IngressRouteUDP: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteUDP object: %v |
| Info |
Application |
Removing IngressRouteUDP: %v |
| Info |
Application |
IngressRouteUDP %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteUDP CR: %v |
| Info |
Application |
Error creating F5SPKIngressUDP from old CR %+v of kind IngressRouteUDP |
| Info |
Application |
Error Deleting converted F5SPKIngressUDP %+v |
| Error |
Application |
Error retrieving installed IngressRouteUDPs CR: %v |
| Error |
Application |
Error retrieving F5SPKIngressUDPs CR's: %v |
| Info |
Application |
Error updating converted F5SPKIngressUDPs from old CR %+v of kind IngressRouteUDP |
| Info |
Application |
Deleting pod UDP profile config |
| Info |
Application |
Adding Updating F5UdpSetting: %v\n |
| Error |
Application |
Error on the type of udpSetting object with key %v. |
| Error |
Application |
ERROR with add or update config of UDP Profile for %v: %v |
| Info |
Application |
Creating UDP Profile: %v |
| Info |
Application |
Adding UdpSetting: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-UdpSetting object: %v |
| Info |
Application |
Removing UDP Profile: %v |
| Info |
Application |
UdpSetting %v changed, syncing |
| Info |
Application |
Virtual Dos config doesn't exist with key: %v |
| Error |
Application |
Error on the type of the Virtual Dos object with key %v |
| Info |
Application |
Virtual Dos CRD timed out, deleting %s: %v |
| Info |
Application |
Adding or Updating F5VDos : %v\n |
| Error |
Application |
ERROR with add or update config of Virtual DDos for %v: %v\n |
| Info |
Application |
Creating F5VDos: %v |
| Info |
Application |
Adding F5VDos: %v |
| Error |
Application |
Error DeletedFinalStateUnknown contained non-F5VDos object: %v |
| Info |
Application |
Deleting F5VDos: %v |
| Info |
Application |
Updating F5VDos: %v |
| Error |
Application |
Error. Deleting not existed F5Vlan |
| Info |
Application |
Deleting F5Vlan |
| Info |
Application |
Updating F5Vlan |
| Info |
Application |
Adding F5Vlan |
| Info |
Application |
Delete lbc.vlanTmm[%v] |
| Info |
Application |
Updating Self IP Mappings After Deletion |
| Error |
Application |
Error on the type of the vlan object with key %v. |
| Info |
Application |
reconcileSelfIPMappings doing nothing. No data to be reconciled. |
| Error |
Application |
Error assigning SelfIP_V4 for vlan to tmm at IP |
| Error |
Application |
Error assigning SelfIP_V6 for vlan to tmm at IP |
| Error |
Application |
Error assigning both v4 and v6 SelfIP for vlan to tmm at IP |
| Error |
Application |
Error assigning SelfIP to TMM at IP. SelfIP_V6 not available for vlan |
| Error |
Application |
Error assigning SelfIP to TMM at IP. SelfIP_V4 not available for vlan |
| Error |
Application |
Error disassociating SelfIPV4 pool from TMM at IP. SelfIPV4 does not exist in map for vlan |
| Error |
Application |
Error disassociating SelfIPV6 pool from TMM at IP. SelfIPV6 does not exist in map for vlan |
| Error |
Application |
Error fetching the tmm eviction list: %v |
| Error |
Application |
Error evicting tmm pods: %v |
| Info |
Application |
tmmToAddList is %v |
| Info |
Application |
vlan is not set in tmmToAddList[%v] => Add |
| Debug |
Application |
Vlan config sent |
| Error |
Application |
error while getting F5Vlan alias object from store by CR name |
| Error |
Application |
Error with AddOrUpdateF5Vlan configuration: %v |
| Debug |
Application |
Delay the annotateTmmPodsForVlanIP |
| Info |
Application |
changing vlan CR status to SUCCESS since no active TMM found |
| Info |
Application |
Updating Self IP Mappings |
| Info |
Application |
lbc.vlanTmm= %v |
| Warning |
Application |
**CRD Kind IngressRouteVlan is Deprecated,instead use F5SPKVlan |
| Info |
Application |
Adding IngressRouteVlan: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-IngressRouteVlan object: %v |
| Info |
Application |
Removing IngressRouteVlan: %v |
| Info |
Application |
IngressRouteVlan %v changed, syncing |
| Error |
Application |
Error retrieving installed IngressRouteVlans CR: %v |
| Info |
Application |
Error creating F5SPKVlans from old CR %+v of Kind IngressRouteVlan |
| Info |
Application |
Error Deleting converted F5SPKVlans %+v |
| Error |
Application |
Error retrieving F5SPKVlans CR's: %v |
| Info |
Application |
Error updating converted F5SPKVlans from old CR %+v of Kind IngressRouteVlan |
| Info |
Application |
Adding or Updating F5ZERORATINGIRULE: %v\n |
| Error |
Application |
Error on the type of zeroRating object with key %v. |
| Error |
Application |
Error with AddOrUpdateF5ZERORATINGIRULE configuration for %v: %v |
| Info |
Application |
createF5ZERORATINGIRULE: %v |
| Info |
Application |
Adding F5ZeroRatingIrule: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-F5ZeroRatingIrule object: %v |
| Info |
Application |
Removing F5ZeroRatingIrule: %v |
| Info |
Application |
F5ZeroRatingIrule %v changed, syncing |
| Info |
Application |
Finalizer already present %v |
| Error |
Application |
Could not find object from store for %v CR kind |
| Error |
Application |
Store update returned this error %v for object %v-%v-%v for operation %v |
| Info |
Application |
Finalizer %v for %v of namespace %v SUCCESS |
| Info |
Application |
Finalizer is not supported for %v |
| Info |
Application |
Updated CR relationship map : %v |
| Info |
Application |
CR relationship map does not include entry for kind: %v and key: %v |
| Debug |
Application |
Adding ConfigMap: %v |
| Debug |
Application |
Error DeletedFinalStateUnknown contained non-ConfigMap object: %v |
| Debug |
Application |
Removing ConfigMap: %v |
| Debug |
Application |
ConfigMap %v changed, syncing |
| Info |
Application |
Adding endpoints: %v |
| Debug |
Application |
Error DeletedFinalStateUnknown contained non-Endpoints object: %v |
| Debug |
Application |
Removing endpoints: %v |
| Debug |
Application |
Endpoints %v changed, syncing |
| Info |
Application |
gRPC TMM service endpoint event qualified: %+v |
| Info |
Application |
Adding service: %v |
| Info |
Application |
Error DeletedFinalStateUnknown contained non-Service object: %v |
| Info |
Application |
Removing service: %v |
| Info |
Application |
Service %v changed, syncing |
| Debug |
Application |
Service %v has not changed, no need to sync |
| Debug |
Application |
service ports changed |
| Debug |
Application |
service external name changed |
| Debug |
Application |
service type changed |
| Debug |
Application |
Adding VirtualServer: %v |
| Debug |
Application |
Error DeletedFinalStateUnknown contained non-VirtualServer object: %v |
| Debug |
Application |
Removing VirtualServer: %v |
| Debug |
Application |
VirtualServer %v changed, syncing |
| Debug |
Application |
Adding VirtualServerRoute: %v |
| Debug |
Application |
Error DeletedFinalStateUnknown contained non-VirtualServerRoute object: %v |
| Debug |
Application |
Removing VirtualServerRoute: %v |
| Debug |
Application |
VirtualServerRoute %v changed, syncing |
| Error |
Application |
Create named pipe %s failed with %v |
| Error |
Application |
Reading from pipe %s failed with %v |
| Info |
Application |
Received new update on license status change: %v |
| Info |
Application |
Error in conversion |
| Info |
Application |
Bringing up TMM, replicas %d |
| Error |
Application |
Failed to scale TMMs: %v |
| Error |
Application |
Failed to update service: %v |
| Info |
Application |
Scaling down TMM |
| Error |
Application |
Unrecognized message |
| Info |
Application |
Creating ServiceLBPersistManager for App namespaces: %s - writing ConfigMap to %s |
| Error |
Application |
Error locating past persistence ConfigMaps: %v |
| Error |
Application |
Deletion of IP %s failed with error: %v |
| Info |
Application |
IP %s not found |
| Info |
Application |
Attempting to locate and digest existing persistence ConfigMap for application namespace %v |
| Info |
Application |
No ConfigMaps found matching %s |
| Error |
Application |
Error in sanitizing data for configMap name %s |
| Info |
Application |
Saving Persisted Data to Configmap %s |
| Info |
Application |
Serialized Persisted Data: %s |
| Info |
Application |
Creating ConfigMap |
| Info |
Application |
Updating ConfigMap %v |
| Info |
Application |
Deserializing the ConfigMap: %s failed with error %v |
| Info |
Application |
Successfully retrieved ConfigMap: %v |
| Error |
Application |
No data found for namespace %s |
| Info |
Application |
ServiceTypeLB: addServiceNameIPEntryInPersistStore serviceName: %s, ipAddress, %v, port: %s, namespace: %s |
| Error |
Application |
Persistence entry already exists: %v |
| Error |
Application |
Entry already exists: %v |
| Error |
Application |
Unsupported Protocol: %s in ServiceType Loadbalancer |
| Error |
Application |
Deletion of service from Persistence Store failed for Service: %v |
| Error |
Application |
Error Deleting converted F5SPKIngressNGAP %+v |
| Error |
Application |
Error retrieving Service:%s, err: %v |
| Error |
Application |
Service: %s type is LoadBalancer but class is not matching f5net.com |
| Error |
Application |
Error: Getting External IP from IP Pool, error: %v |
| Error |
Application |
Error: ServiceIP Persist Add failed |
| Info |
Application |
Destination Address is: %v |
| Info |
Application |
Destination Address already created: %+v |
| Info |
Application |
Generate Ingress TCP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Generated TCP Ingress already present: %+v |
| Info |
Application |
generate TCP Ingress |
| Error |
Application |
Error creating F5SPKIngressTCPs, Conflicting CR is found of kind IngressRouteFastL4, %+v |
| Error |
Application |
Please backup old CR and delete for LoadBalancer to create a new Ingress |
| Info |
Application |
Generate Ingress UDP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Generated UDP Ingress already present: %+v |
| Info |
Application |
generate UDP Ingress |
| Error |
Application |
Error creating F5SPKIngressUDPs, Conflicting CR is found %+v |
| Error |
Application |
Error creating F5SPKIngressUDPs CR %+v |
| Info |
Application |
Generate Ingress SCTP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Generated SCTP Ingress already present: %+v |
| Info |
Application |
generate SCTP Ingress |
| Error |
Application |
Error creating F5SPKIngressNGAPs, Conflicting CR is found %+v |
| Error |
Application |
Error creating F5SPKIngressSCTPs from old CR %+v |
| Info |
Application |
Create New Ingress TCP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Create New Ingress UDP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Create New Ingress SCTP serviceName: %s, serviceNamespace: %s, destinationIP: %v |
| Info |
Application |
Update Service with external IP serviceName: %s, namespace: %s, destinationAddresses: %v |
| Info |
Application |
Service already has LoadBalancer IP: %s |
| Info |
Application |
Service updated: %v |
| Error |
Application |
IPFamily not supported |
| Info |
Application |
Service Network Persistence Store |
| Error |
Application |
Could not get list of IPs from LB Pool Resource |
| Info |
Application |
IP Reservation error: %v |
| Info |
Application |
Going to find f5SPKServiceTypeLBIpPoolList from appNamespace: %s |
| Info |
Application |
f5SPKServiceTypeLBIpPoolList returned is: %v |
| Error |
Application |
List of LBIPPool resource failed |
| Error |
Application |
Service Network Persistence Free IP Lookup Failed |
| Info |
Application |
Service Network Persistence Used IP Lookup |
| Info |
Application |
| Error |
Application |
Couldn't get key for object %v: %v |
| Error |
Application |
Couldn't create a task for object %v: %v |
| Debug |
Application |
Adding an element with a key: %v |
| Error |
Application |
Requeuing %v, err %v |
| Error |
Application |
Requeuing %v after %s, err %v |
| Debug |
Application |
Syncing %v |
| Error |
Application |
create error in test for tmm pods: %v |
| Error |
Application |
tmm pod add error: %v |
| Error |
Application |
create error in test |
| Error |
Application |
Grpc Service Add error: %v |
| Error |
Application |
Sync error: %v |
| Info |
Application |
Traffic distribution CR : %s configuration : %v |
| Info |
Application |
configured deployments and the running deployments do not match |
| Debug |
Application |
Endpoint : %v deployment : %v |
| Debug |
Application |
could not trace the deployment for the endpoint : %v |
| Debug |
Application |
V4 deployment : %v ratio : %v |
| Debug |
Application |
V6 deployment : %v ratio : %v |
| Debug |
Application |
Deployment List1: %v Deployment List2: %v |
| Debug |
Application |
Deployment name based on PodIPs for the endpoint:%v is :%v |
| Debug |
Application |
Deployment name for the endpoint:%v is :%v |
| Error |
Application |
error while updating status for F5BigAlgFtps CR: %v |
| Error |
Application |
error while updating status for F5BigAlgPptps CR: %v |
| Error |
Application |
error while updating status for F5BigAlgRtsps CR: %v |
| Error |
Application |
error while updating status for F5BigAlgTftps CR: %v |
| Error |
Application |
error while updating status for F5BigCneAddresslists CR: %v |
| Error |
Application |
error while updating status for F5BigCneDatagroups CR: %v |
| Error |
Application |
error while updating status for F5BigCneDownloaders CR: %v |
| Error |
Application |
error while updating status for F5BigCnePortlists CR: %v |
| Error |
Application |
error while updating status for F5BigCneSnatpools CR: %v |
| Error |
Application |
error while updating status for F5BigContextGlobals CR: %v |
| Error |
Application |
error while updating status for F5BigContextSecures CR: %v |
| Error |
Application |
error while updating status for F5BigDdosPolicys CR: %v |
| Error |
Application |
error while updating status for F5BigDdosProfiles CR: %v |
| Error |
Application |
error while updating status for F5BigDnsApps CR: %v |
| Error |
Application |
error while updating status for F5BigDnsCaches CR: %v |
| Error |
Application |
error while updating status for F5BigDnsZones CR: %v |
| Error |
Application |
error while updating status for F5BigDnsxGlobalOptionss CR: %v |
| Error |
Application |
error while updating status for F5BigFastl4Settings CR: %v |
| Error |
Application |
error while updating status for F5BigFwPolicys CR: %v |
| Error |
Application |
error while updating status for F5BigFwRulelists CR: %v |
| Error |
Application |
error while updating status for F5BigGslbDatacenters CR: %v |
| Error |
Application |
error while updating status for F5BigGslbMonitors CR: %v |
| Error |
Application |
error while updating status for F5BigGslbPools CR: %v |
| Error |
Application |
error while updating status for F5BigGslbServers CR: %v |
| Error |
Application |
error while updating status for F5BigGslbWideips CR: %v |
| Error |
Application |
error while updating status for F5BigIpsPolicys CR: %v |
| Error |
Application |
error while updating status for F5BigIrules CR: %v |
| Error |
Application |
error while updating status for F5BigLogHslpubs CR: %v |
| Error |
Application |
error while updating status for F5BigLogProfiles CR: %v |
| Error |
Application |
error while updating status for F5BigNatPolicys CR: %v |
| Error |
Application |
error while updating status for F5BigNetStaticroutes CR: %v |
| Error |
Application |
error while updating status for F5BigNetVlans CR: %v |
| Error |
Application |
error while updating status for F5BigPePolicys CR: %v |
| Error |
Application |
error while updating status for F5BigPeProfiles CR: %v |
| Error |
Application |
error while updating status for F5BigPools CR: %v |
| Error |
Application |
error while updating status for F5BigTcpSettings CR: %v |
| Error |
Application |
error while updating status for F5BigUdpSettings CR: %v |
| Error |
Application |
error while updating status for F5BigZeroratingPolicys CR: %v |
| Error |
Application |
error while updating status for F5SPKAddressLists CR: %v |
| Error |
Application |
error while updating status for F5SPKDatagroups CR: %v |
| Error |
Application |
error while updating status for F5SPKDnscaches CR: %v |
| Error |
Application |
error while updating status for F5SPKEgresss CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressDiameters CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressEgressUDPs CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressGTPs CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressHTTP2s CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressNGAPs CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressTCPs CR: %v |
| Error |
Application |
error while updating status for F5SPKIngressUDPs CR: %v |
| Error |
Application |
error while updating status for F5SPKPortLists CR: %v |
| Error |
Application |
error while updating status for F5SPKSnatpools CR: %v |
| Error |
Application |
error while updating status for F5SPKStaticRoutes CR: %v |
| Error |
Application |
error while updating status for F5SPKTrafficDistributions CR: %v |
| Error |
Application |
error while updating status for F5SPKVlans CR: %v |
| Error |
Application |
error while updating status for F5SPKZeroRatingIrules CR: %v |
| Info |
Application |
status subresource is not supported for %v |
| Error |
Application |
unknown object type found %v |
| Error |
Application |
Could not find object from store for %v CR kind and %v CR name |
| Error |
Application |
F5BigLogProfile object %s status is %s |
| Error |
Application |
F5BigLogHslpub object %s status is %s |
| Error |
Application |
F5SPKIngressTCP object %s status is %s |
| Error |
Application |
F5SPKTrafficDistribution object %s status is %s |
| Error |
Application |
F5SPKIngressUDP object %s status is %s |
| Error |
Application |
F5SPKVlan object %s status is %s |
| Error |
Application |
F5BigNetVlan object %s status is %s |
| Error |
Application |
F5SPKSnatpool object %s status is %s |
| Error |
Application |
F5BigCneSnatpool object %s status is %s |
| Error |
Application |
F5SPKStaticRoute object %s status is %s |
| Error |
Application |
F5BigNetStaticroute object %s status is %s |
| Error |
Application |
F5BigFastl4Setting object %s status is %s |
| Error |
Application |
F5BigCneDatagroup object %s status is %s |
| Error |
Application |
F5BigCneAddresslist object %s status is %s |
| Error |
Application |
F5SPKAddressList object %s status is %s |
| Error |
Application |
F5BigCnePortlist object %s status is %s |
| Error |
Application |
F5SPKPortList object %s status is %s |
| Error |
Application |
F5BigUdpSetting object %s status is %s |
| Error |
Application |
F5BigAlgTftp object %s status is %s |
| Error |
Application |
F5BigAlgRtsp object %s status is %s |
| Error |
Application |
F5BigAlgPptp object %s status is %s |
| Error |
Application |
F5BigZeroratingPolicy object %s status is %s |
| Error |
Application |
F5BigAlgFtp object %s status is %s |
| Error |
Application |
F5BigNatPolicy object %s status is %s |
| Error |
Application |
F5BigFwPolicy object %s status is %s |
| Error |
Application |
F5BigTcpSetting object %s status is %s |
| Error |
Application |
F5BigDdosPolicy object %s status is %s |
| Error |
Application |
F5BigDdosProfile object %s status is %s |
| Error |
Application |
F5SPKIngressDiameter object %s status is %s |
| Error |
Application |
F5SPKIngressNGAP object %s status is %s |
| Error |
Application |
F5SPKIngressGTP object %s status is %s |
| Error |
Application |
F5SPKIngressHTTP2 object %s status is %s |
| Error |
Application |
F5SPKIngressEgressUDP object %s status is %s |
| Error |
Application |
F5SPKEgress object %s status is %s |
| Error |
Application |
F5SPKDnscache object %s status is %s |
| Error |
Application |
F5BigDnsCache object %s status is %s |
| Error |
Application |
F5BigDnsApp object %s status is %s |
| Error |
Application |
F5BigDnsZone object %s status is %s |
| Error |
Application |
F5BigDnsxGlobalOptions object %s status is %s |
| Error |
Application |
F5BigIpsPolicy object %s status is %s |
| Error |
Application |
F5BigCneDownloader object %s status is %s |
| Error |
Application |
F5BigContextGlobal object %s status is %s |
| Error |
Application |
F5BigContextSecure object %s status is %s |
| Error |
Application |
F5BigGslbPool object %s status is %s |
| Error |
Application |
F5BigGslbWideip object %s status is %s |
| Error |
Application |
F5BigGslbDatacenter object %s status is %s |
| Error |
Application |
F5BigGslbServer object %s status is %s |
| Error |
Application |
F5BigGslbMonitor object %s status is %s |
| Error |
Application |
F5BigIrule object %s status is %s |
| Error |
Application |
F5BigFwRulelist object %s status is %s |
| Error |
Application |
F5BigPePolicy object %s status is %s |
| Error |
Application |
F5BigPeProfile object %s status is %s |
| Info |
Application |
CR dependency check is not supported for %v CR type |
| Info |
Application |
DEBUG: lbc.SelfIPV4TMMAssignment:%v |
| Info |
Application |
DEBUG: lbc.SelfIPV6TMMAssignment:%v |
| Info |
Application |
DEBUG: lbc.availableV4SelfIP:%v |
| Info |
Application |
DEBUG: lbc.availableV6SelfIP:%v |
| Error |
Application |
validation_handler: no body in the http request |
| Error |
Application |
validation_handler: error while reading the http request: %v |
| Error |
Application |
validation_handler: empty body |
| Error |
Application |
validation_handler: incorrect body |
| Info |
Application |
Admission review for a different namespace, ignoring.. |
| Error |
Application |
validation_handler: Can't encode response: %v |
| Error |
Application |
validation_handler: Can't write response: %v |
| Info |
Application |
validation_handler: Starting HTTPS server with Port%s, cert: %s ,key: %s |
| Error |
Application |
validation_handler: WARNING!! Validation of CRs will fail - Failed to start HTTPS server: %v |
| Error |
Application |
validation_handler: WARNING!! Validation of CRs will fail - Failed to get certificates and keys: %v |
| Info |
Application |
validation_handler: Starting HTTPS server with Address%s |
| Info |
Application |
Validation-webhook called for ContextGlobal CR:- %s |
| Info |
Application |
Validation-webhook called for Egress CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for GslbPool CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for GslbWideip CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for IngressHTTP2 CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for IngressTCP CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for IngressUDP CR:- %s (op: %s) |
| Info |
Application |
F5BigiRule CR: %s cannot be deleted as it is referenced in CR: %s |
| Info |
Application |
The iRule CR %s is not referenced in any other CR. |
| Info |
Application |
Validation-webhook called for FastL4 CR:- %s |
| Info |
Application |
%s is a default CR of fastL4 |
| Info |
Application |
FastL4 CR: %s cannot be deleted as it is referenced in Secure Context CR: %s |
| Info |
Application |
The FastL4 CR %s is not referenced in any other CR. |
| Info |
Application |
Validation-webhook called for TCP CR:- %s |
| Info |
Application |
%s is a default CR of TCP |
| Info |
Application |
TCP CR: %s cannot be deleted as it is referenced in FTP CR: %s |
| Info |
Application |
TCP CR: %s cannot be deleted as it is referenced in Secure Context CR: %s |
| Info |
Application |
TCP CR: %s cannot be deleted as it is referenced in DNS CR: %s |
| Info |
Application |
The TCP CR %s is not referenced in any other CR. |
| Info |
Application |
Validation-webhook called for UDP CR:- %s |
| Info |
Application |
%s is a default CR of UDP |
| Info |
Application |
UDP CR: %s cannot be deleted as it is referenced in Secure Context CR: %s |
| Info |
Application |
UDP CR: %s cannot be deleted as it is referenced in DNS CR: %s |
| Info |
Application |
The UDP CR %s is not referenced in any other CR. |
| Info |
Application |
Unexpected object in F5Snatpool lister. |
| Info |
Application |
Validation-webhook called for Snatpool CR:- %s (op: %s) |
| Info |
Application |
Warning: StaticRoute CR is not of type gateway, but Gateway field is populated. |
| Info |
Application |
Warning: StaticRoute CR is not of type gateway, but IPv6Gateway field is populated. |
| Info |
Application |
Warning: StaticRoute CR is not of type interface, but Interface field is populated. |
| Info |
Application |
Validation-webhook called for SPK VLAN CR:- %s |
| Info |
Application |
No IngressTCP points to trafficDistribution: %s |
| Info |
Application |
Validation-webhook called for Traffic Distribution CR:- %s (op: %s) |
| Info |
Application |
Validation-webhook called for SPK VLAN CR:- %s Operation = %v |
| Info |
Application |
Validation-webhook error Unmarshal VLAN CR |
| Info |
Application |
Validation-webhook Unmarshal VLAN CR:- %v |
| Info |
Application |
ipv4Ips :%v ipv6Ips:%v |
| Info |
Application |
Validation-webhook called for Zero rating CR:- %s |
| Info |
Application |
F5BigZeroratingPolicy CR: %s cannot be deleted as it is referenced in CR: %s |
| Info |
Application |
The Zero rating CR %s is not referenced in any other CR. |
| Warning |
Application |
Error while sending a response for the '/' path: %v |
| Info |
Application |
Starting Prometheus listener on: %v%v |
| Emergency |
Application |
Error in Prometheus listener server: %s |
| Info |
Application |
Creating PersistenceManager for application namespace: %s - writing ConfigMap to %s |
| Info |
Application |
Added TMM: %v |
| Info |
Application |
Updating Active TMM: %v |
| Info |
Application |
Empty podName detected when deleting TMM pod from persistence manager. |
| Info |
Application |
Deleting TMM Pod: %v |
| Info |
Application |
Serializing... |
| Info |
Application |
Mapping Serialization: PodName: %s |
| Info |
Application |
Mapping Serialization failed, name doesn't exist. |
| Info |
Application |
Deserializing data: %v |
| Info |
Application |
Checking API call to get PersistenceManager pm.configMapName: %v |
| Error |
Application |
Error deleting snatpool persistence ConfigMap, post-reconciliation: %v |
| Info |
Application |
Found %d matching configmaps |
| Info |
Application |
Found no matching persistence configmaps. |
| Info |
Application |
Error when getting %v/%v: %v |
| Debug |
Application |
Tmm container resources limits CPU: %v |
| Info |
Application |
Report published every %d sec |
| Warning |
Application |
Writing main config |
| Warning |
Application |
Writing temp config |
| Warning |
Application |
Writing config version |
| Warning |
Application |
SetTMMStaticConfig updates TMM config map with static config |
| Warning |
Application |
Update license report |
| Info |
Application |
Writing TMM config to configmap tmm-init |
| Warning |
Application |
when getting configmap : %v/%v : %v skipping |
| Error |
Application |
Error when updating configmap: %v/%v: %v |
| Info |
Application |
namespace: %v, data: %v |
| Info |
Application |
Done writing TMM config to configmap tmm-init |
| Info |
Application |
Writing TMM static config to configmap tmm-init |
| Info |
Application |
Done writing TMM static config to configmap tmm-init |
| Debug |
Application |
Updating %s config map |
| Info |
Application |
%s configmap does not exist, create it. |
| Warning |
Application |
when getting configmap %s: %v skipping |
| Error |
Application |
Error when updating %s configmap: %s: %v |
| Debug |
Application |
%s configmap updated. |
| Error |
Application |
Invalid port %s found, ignoring the port entry |
| Error |
Application |
Unable to parse CIDR string: %s. CIDR is invalid. |
| Error |
Application |
Not enough IPs, too many TMMs for address space. Allocated_IPs:%v Max Configured TMMs: %v |
| Error |
Application |
Not enough IPs, oversubscribed reserved IP addresses. Allocated_IPs:%v Reserved_IPs: %v |
| Info |
Application |
%s took %s |
| Error |
Application |
Invalid Address %s |
| Error |
Application |
Invalid Address Range %s\n |
| Error |
Application |
Invalid Address %s\n |
| Info |
Application |
IP Range to CIDR conversion list : %s\n |
| Error |
Application |
Could not parse %s as subnet: err %v |
| Error |
Application |
Unmap%s, missing node.\n |
| Error |
Application |
Unsupported path element type: %T. |
| Error |
Application |
CountChildren%s, missing node.\n |
| Info |
Application |
cfgMap: %v, path: %v |
| Error |
Application |
GetAddressAndPorts%s, missing node.\n |
| Error |
Application |
Config file path %s has improper type.\n |
| Error |
Application |
Could not parse %s: %v |
| Error |
Application |
Port range (%s) must contain only two elements.\n |
| Error |
Application |
Port range invalid [%d-%d].\n |
| Error |
Application |
Missing fqdn field from grpc.addr tree.\n |
| Error |
Application |
GetAddressAndPortString%v, missing node.\n |
| Error |
Application |
GetAddressAndPortString%v, addr wrong type.\n |
| Error |
Application |
GetAddressAndPortString%v, port wrong type.\n |
| Error |
Application |
Bad port range '%v' - %v.\n |
| Info |
Application |
gRPC - gRPC dial (%s). |
| Error |
Application |
Did not make gRPC connection to gRPC dial: %s |
| Info |
Application |
gRPC - gRPC dial succeeded. |
| Error |
Application |
gRPC - No heartbeat from TMM.: %s, Closing the grpc connection |
| Error |
Application |
gRPC - Can't get name of Any object. |
| Error |
Application |
gRPC - Unknown type in Any (%s). |
| Error |
Application |
Error decoding/unmarshalling JSON - Protobuf %d - %v. %v |
| Error |
Application |
gRPC - Unable to decipher error code in grpccfg writeConfig: %v |
| Error |
Application |
gRPC - Protobuf %d - %v. |
| Error |
Application |
gRPC - Could not configure TMM: %v |
| Info |
Application |
gRPC - 2 - (%d) TMM Expects next sequence start to be %d. |
| Info |
Application |
gRPC - 2 - (%d) F5ingress says next sequence start to be %d. |
| Info |
Application |
gRPC - Port %v |
| Error |
Application |
message content is empty |
| Info |
Application |
gRPC - Send GRPC Message: %s |
| Error |
Application |
gRPC connection failed - %s:%d |
| Error |
Application |
Error closing gRPC client connection with err: %v |
| Error |
Application |
all %d TMM gRPC connections failed for %v |
| Info |
Application |
gRPC - Start State - TMM generation: %d, sequence start: %d. |
| Info |
Application |
gRPC - End State - TMM generation: %d, sequence start: %d. |
