F5SPKGlobalOptions¶
The F5SPKGlobalOptions CR configures the Traffic Management Microkernel (TMM) to enable or disables crypto hardware acceleration on the BlueField-3 (BF3) Data Processing Unit (DPU) using Data Center Operations and Communications Acceleration (DOCA) APIs. These APIs provide secure, high-speed encryption and decryption. The BlueField-3 DPU employs the Advanced Encryption Standard-Galois/Counter Mode (AES-GCM) engine to enhance both performance and security for traffic management operations.
Parameters¶
The table below describes the F5SPKGlobalOptions CR spec parameters:
| Parameter | Description |
crypto.hwAccel |
Enables or disables crypto hardware acceleration on the BlueField-3 Data Processing Unit (DPU): true (default) or false. |
F5SPKGlobalOptions CR Example¶
apiVersion: k8s.f5net.com/v1
kind: F5SPKGlobalOptions
metadata:
namespace: default
spec:
crypto:
hwAccel: true
Disabling Crypto Hardware Acceleration on the BlueField-3 DPU¶
Follow the steps below to disable crypto hardware acceleration on the BlueField-3 DPU:
Copy the F5SPKGlobalOptions example CR below to a YAML file. Set the
crypto.hwAccelparameter to false and save:In this example, the CR installs to the spk-ingress Project:
apiVersion: k8s.f5net.com/v1 kind: F5SPKGlobalOptions metadata: name: global-options namespace: spk-ingress spec: crypto: hwAccel: false
Apply the F5SPKGlobalOptions CR that you have created:
kubectl apply -f f5-global-options.yaml
The crypto hardware acceleration is now disabled on the BlueField-3 DPU, and a software-based codec will be enabled.
Enabling Crypto Hardware Acceleration on the BlueField-3 DPU¶
Prerequisites:
To enable crypto hardware acceleration on the BlueField-3 Data Processing Unit (DPU), ensure you have the following:
- A BlueField-3 DPU must have a crypto-capable device.
- A Scalable Function (SF) must be created on the BlueField-3 DPU.
Follow the steps below to enable crypto hardware acceleration on the BlueField-3 DPU:
crypto.hwAccelparameter to true and save:In this example, the CR installs to the spk-ingress Project:
apiVersion: k8s.f5net.com/v1 kind: F5SPKGlobalOptions metadata: name: global-options namespace: default spec: crypto: hwAccel: true
The crypto hardware acceleration is now enabled on the BlueField-3 DPU, and a software-based codec will be disabled.
Feedback¶
Provide feedback to improve this document by emailing spkdocs@f5.com.
