F5SPKIngressHTTP2¶
The F5SPKIngressHTTP2 CR configures the Traffic Management Microkernel (TMM) to proxy and load balance low-latency 5G Service Based Interface (SBI) messages using an HTTP/2 protocol virtual server, and a load balancing pool consisting of 5G Network Function endpoints. The F5SPKIngressHTTP2 CR fully supports SSL/TLS termination, bi-directional traffic flow, and connection persistence based on network packet headers, footers, and JSON contents. For the full list of CRs, refer to the BIG-IP Next for Kubernetes CRs overview.
CR parameters¶
The table below describes the CR parameters. Each heading below represents the top-level parameter element. For example, to set the Kubernetes services.name list, use spec.services.name.
| Parameter | Description |
sslFileWatchMode |
The type of file watching for any changes in the keys and certs used by client and server profiles in TMM: SSL_FILE_WATCH_MODE_NONE, SSL_FILE_WATCH_MODE_KUBERNETES_SECRET_STORE, or SSL_FILE_WATCH_MODE_FILES_IN_SHARED_VOLUME (default). |
clientssl
Note: Refer to the Managing SSL/TLS certs and keys section prior to configuring the clientssl parameters.
keyCertPairs.cert |
References SSL/TLS certificates and intermediate CA certificates used to terminate secure ingress connections. Certificate names must be appended to the path file://etc/ssl/tls-keys-certs/<name>.crt. |
keyCertPairs.key |
References SSL/TLS private keys. Key names must be appended to the path file://etc/ssl/tls-keys-certs/<name>.key. |
serverNames |
Specifies a list of hostnames, or a fully qualified domain name used to select the profile by server name indication (SNI) matching. |
ciphers |
Specifies the OpenSSL style cipher string: DEFAULT (default) or ALL. |
enableClientAuthentication |
Enables client certificate verification: true or false (default). |
trustedCa |
Specifies list of Root CAs in PEM format used for client certificate verification. |
serverssl¶
Note: Refer to the Managing SSL/TLS certs and keys section prior to configuring the serverssl parameters.
offload |
Specifies if the TMM does TLS offloading: true or false (default). |
keyCertPairs.cert |
References SSL/TLS certificates and intermediate CA certificates used when TMM behaves as an SSL client. Certificate names must be appended to the path file://etc/ssl/tls-keys-certs/<name>.crt. |
keyCertPairs.key |
References the SSL/TLS private keys matching the keyCertPairs.key certificates. Key names must be appended to the path file://etc/ssl/tls-keys-certs/<name>.key. |
ciphers |
enableServerAuthentication |
Enables server certificate verification: true or false (default). |
trustedCa |
Specifies the list of Root CAs used for server certificate verification. |
spec¶
services.name |
A list of Service object names for the internal applications (Pods). The Controller creates a load balancing pool using the discovered Service Endpoints. |
services.port |
The exposed port for the service. |
destinationAddress |
Creates an IPv4 virtual server address to receive ingress connections. |
destinationPort |
Creates a service port to receive ingress connections. When the Kubernetes service being load balanced has multiple ports, install one CR per service, or use port 0 for all ports. |
v6destinationAddress |
Creates an IPv6 virtual server address to receive ingress connections. |
loadBalancingMethod |
Specifies the load balancing method used to distribute traffic across pool members: ROUND_ROBIN distributes connections evenly across all pool members (default), and RATIO_LEAST_CONN_MEMBER distributes connections first to members with the least number of active connections. |
ingressVlans.vlanList |
Specifies a list of F5SPKVlan CRs to listen for ingress traffic, using the CR's metadata.name. The list can also be disabled using disableListedVlans. |
ingressVlans.category |
Specifies an F5SPKVlan CR category to listen for ingress traffic. The category can also be disabled using disableListedVlans. |
ingressVlans.disableListedVlans |
Disables the VLANs specified with the vlanList parameter: true (default) or false. Excluding one VLAN may simplify having to enable many VLANS. |
egressVlans.vlanList |
Specifies a list of F5SPKVlan CRs to listen for egress traffic, using the CR's metadata.name. The list can also be disabled using disableListedVlans. |
egressVlans.category |
Specifies an F5SPKVlan CR category to listen for egress traffic. The category can also be disabled using disableListedVlans. |
egressVlans.disableListedVlans |
idleTimeout |
Specifies the time in seconds that a client connection may remain open without activity before closing. The default is 300. |
ipfamilies |
Specifies the IP version capabilities of the application: IPv4 (default), IPv6, or IPv4andIPv6. |
jsonMaxBytes |
The maximum number of bytes for a JSON payload. The default is 65536. |
jsonMaxEntries |
The maximum number of entries in the JSON payload. The default is 2048. |
irule |
The iRule proc (procedure) called by the staticRoutes.customIruleProc parameter that will apply to matching connections. |
spec.staticRoutes¶
The spec.staticRoutes parameter defines packet matching conditions that steer traffic to the configured service endpoints. The conditions are applied in the order defined.
conditions |
Specifies an array of up to 4 conditions that must be met for the staticRoute to be selected and applied. |
conditions.fieldName |
Specifies a string representing the name of a field in the message, such as an HTTP header or pseudo header. For example, ':m', or JSON path. For example, ':JSON:some:path:in:json:payload'. |
conditions.comparisonOp |
Specifies a comparison operation to perform against the fieldName value to determine whether the condition is met: SR_COMPARE_NONE, SR_COMPARE_EQUALS (default), SR_COMPARE_NOT_EQUALS, SR_COMPARE_STARTS_WITH, SR_COMPARE_ENDS_WITH, SR_COMPARE_CONTAINS, SR_COMPARE_EXISTS, or SR_COMPARE_NOT_EXISTS. |
conditions.values |
Specifies a list of constant values to compare against a fieldName value. When multiple are provided, the condition will be met when any value is matched. |
conditions.caseSensitive |
Enables evaluating conditions using case-sensitivity: true (default) or false. |
customIruleProc |
The name of the spec.irule to call when the condition match occurs. |
persistBidirectional |
Specifies whether persistence should be bidirectional when a packet match occurs: true (default) or false. |
persistField |
Specifies a custom field that matching requests use as a persistence key. The field specifies the name of an HTTP header or pseudo-header such as :m (method), or :u (uri). Paths to values in the JSON payload may also be specified such as :JSON:key1:key2, with each :key in the path navigating one level deeper into the JSON object tree. |
persistTimeout |
Specifies the persistence timeout for matching conditions. This value overrides any global timeout values. The default value 0 indicates this static route applies the global timeout value. |
service |
Specifies the name of the Kubernetes service that matching requests will be routed to. The service is selected from the list defined in the CR's spec.services.name parameter. |
snatType |
Specifies the type of SNAT to use when forwarding requests that match this static route: SRC_TRANS_NONE, SRC_TRANS_SNATPOOL, or SRC_TRANS_AUTOMAP (default). Note: Currently the Ingress usecase with SRC_TRANS_NONE type is not supported for LA. |
snatPool |
If snatType is SRC_TRANS_SNATPOOL, this value is the name of the snatpool to use when forwarding requests that match this static route. |
CR example¶
apiVersion: "k8s.f5net.com/v1"
kind: F5SPKIngressHTTP2
metadata:
namespace: spk-app
clientssl:
keyCertPairs:
- key: file://etc/ssl/tls-keys-certs/client.key
cert: file://etc/ssl/tls-keys-certs/client.crt
ciphers: "DEFAULT"
spec:
destinationAddress: 10.20.2.206
destinationPort: 80
v6destinationAddress: 2002::10:20:2:206
irule: |
proc insert_http_header_a {} {
log local0. "insert a new HTTP header"
HTTP::header insert "x-custom-proc" "sbi-A"
set acctVal [MESSAGE::field value ":JSON:account"]
log local0. "######### acctValB = $acctVal"
proc insert_http_header_b {} {
HTTP::header insert "x-custom-proc" "sbi-B"
ipfamilies: IPv4andIPv6
loadBalancingMethod: "ROUND_ROBIN"
services:
- name: web-a
port: 443
services:
- name: web-b
port: 443
staticRoutes:
- customIruleProc: "insert_http_header_a"
persistBidirectional: false
persistField: "${:JSON:account}"
persistTimeout: 60
service: "web-a"
conditions:
- fieldName: ":JSON:account"
comparisonOp: "SR_COMPARE_EQUALS"
values:
- "account1"
caseSensitive: true
- customIruleProc: "insert_http_header_b"
persistTimeout: 60
service: "web-b"
conditions:
values:
- "account2"
caseSensitive: true
Dual-Stack environments¶
TMM’s load balancing pool is created by discovering the Kubernetes Service Endpoints in the Project. In IPv4/IPv6 dual-stack environments, to populate the load balancing pool with IPv6 members, set the Service PreferDualStack parameter to IPv6. For example:
kind: Service
metadata:
namespace: spk-app
labels:
app: http2-web-app
spec:
ipFamilyPolicy: PreferDualStack
ipFamilies:
- IPv6
- IPv4
Important: When enabling PreferDualStack, ensure TMM’s internal F5SPKVlan interface configuration includes both IPv4 and IPv6 addresses.
Ingress traffic¶
To enable ingress network traffic, TMM must be configured to advertise virtual server IP addresses to external networks using the Border Gateway Protocol (BGP) dynamic routing protocol. Alternatively, you can configure appropriate routes on upstream devices. To configure BGP, see ZebOS ConfigMaps
Managing certs and keys¶
Read this section carefully to ensure the SSL/TLS certificates and keys referenced by the F5SPKIngressHTTP2 CR are encoded and installed into the cluster properly. These bullet points are essential:
- When installing the BIG-IP Next for Kubernetes you must set
tmm.tlsStore.enabledparamter to true. See SPKInstance CR Parameters. - The SSL/TLS certificates and keys must be Base64 encoded, and stored in a Secret named tls-keys-certs-secret.
- TMM mounts the Secret named tls-keys-certs-secret to the file path file://etc/ssl/tls-keys-certs/.
Important: The tls-keys-certs-secret Secret must be created before the BIG-IP Next for Kubernetes is installed, otherwise the mount will fail and cause the TMM to enter a restart loop.
Use the steps below to generate a new SSL/TLS certficate and key, Base64 encode them, and then create the tls-keys-certs-secret Secret to store them in the cluster. F5 recommends using SSL/TLS certificates signed by a well-known certificate authority (CA) for production application traffic.
Note: Use steps 4 - 6 if you already have an existing SSL/TLS certificate and key pair.
Generate the CA signing certificate and key:
openssl genrsa -out ca.key 4096
openssl req -x509 -new -nodes -key ca.key -sha256 -days 365 -out ca.crt \ -subj "/C=US/ST=WA/L=Seattle/O=F5/OU=Dev/CN=ca"
Generate the clientssl profile SSL/TLS certificate signing request (CSR):
openssl genrsa -out client.key 4096
openssl req -new -key client.key -out client.csr \ -subj "/C=US/ST=WA/L=Seattle/O=F5/OU=PD/CN=client.com"
Sign the clientssl profile CSR with the CA:
openssl x509 -req -in client.csr -CA ca.crt -CAkey ca.key \ -set_serial 101 -outform PEM -out client.crt -extensions req_ext -days 365 -sha256
Base64 encode the SSL/TLS certificate and key:
openssl base64 -A -in client.crt -out client-encode.crt openssl base64 -A -in client.key -out client-encode.key
Create the tls-keys-certs-secret Secret that stores the SSL/TLS certificate and key:
echo "apiVersion: v1" > tls-keys-certs-secret.yaml echo "kind: Secret" >> tls-keys-certs-secret.yaml echo "metadata:" >> tls-keys-certs-secret.yaml echo " name: tls-keys-certs-secret" >> tls-keys-certs-secret.yaml echo "data:" >> tls-keys-certs-secret.yaml echo -n " client.crt: " >> tls-keys-certs-secret.yaml cat client-encode.crt >> tls-keys-certs-secret.yaml echo " " >> tls-keys-certs-secret.yaml echo -n " client.key: " >> tls-keys-certs-secret.yaml cat client-encode.key >> tls-keys-certs-secret.yaml
Install the Secret into the BIG-IP Next for Kubernetes Controller Project:
kubectl apply -f tls-keys-certs-secret.yaml -n default
Requirements¶
Ensure you have:
- Installed a K8S Service object and application.
- A Linux based workstation.
- Installed the dSSM Database to support persistence records.
Installation¶
Use the following steps to obtain the application’s Service object information to configure and install the F5SPKIngressHTTP2 CR.
Switch to the application Project:
kubectl project <project>
In this example, the application is in the spk-app Project:
kubectl project spk-app
Use the Service object NAME and PORT to configure the CR
service.nameandservice.portparameters:kubectl get service
In this example, the Service object NAMEs are http2-web-a and http2-web-b and the PORT is 443:
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) http2-web-a NodePort 10.99.99.91 <none> 443:443/TCP http2-web-b NodePort 10.99.99.99 <none> 443:443/TCP
Copy the example F5SPKIngressHTTP2 CR into a YAML file:
apiVersion: "k8s.f5net.com/v1" kind: F5SPKIngressHTTP2 metadata: name: http2-app namespace: spk-app clientssl: keyCertPairs: - key: file://etc/ssl/tls-keys-certs/client.key cert: file://etc/ssl/tls-keys-certs/client.crt ciphers: "DEFAULT" spec: destinationAddress: 10.20.2.206 destinationPort: 80 v6destinationAddress: 2002::10:20:2:206 irule: | proc insert_http_header_a {} { log local0. "insert a new HTTP header" HTTP::header insert "x-custom-proc" "sbi-A" set acctVal [MESSAGE::field value ":JSON:account"] log local0. "######### acctValA = $acctVal" } proc insert_http_header_b {} { log local0. "insert a new HTTP header" HTTP::header insert "x-custom-proc" "sbi-B" set acctVal [MESSAGE::field value ":JSON:account"] log local0. "######### acctValB = $acctVal" } ipfamilies: IPv4andIPv6 loadBalancingMethod: "ROUND_ROBIN" services: - name: http-web-a port: 443 services: - name: http-web-b port: 443 staticRoutes: - customIruleProc: "insert_http_header_a" persistBidirectional: false persistField: "${:JSON:account}" persistTimeout: 60 service: "web-a" conditions: - fieldName: ":JSON:account" comparisonOp: "SR_COMPARE_EQUALS" values: - "account1" caseSensitive: true - customIruleProc: "insert_http_header_b" persistBidirectional: false persistField: "${:JSON:account}" persistTimeout: 60 service: "web-b" conditions: - fieldName: ":JSON:account" comparisonOp: "SR_COMPARE_EQUALS" values: - "account2" caseSensitive: true
Install the F5SPKIngressHTTP2 CR:
kubectl apply -f spk-ingress-http2.yaml
Web clients should now be able to connect to the application through the TMM.
Connection statistics¶
Connect to the Debug Sidecar in the TMM to view virtual server and pool member connectivity statistics.
Log in to the TMM Debug container:
kubectl exec -it f5-tmm-6cdbc6bb65-j2r7d -c debug -n default -- bash
View the virtual server connection statistics:
tmctl -d blade virtual_server_stat -s name,clientside.tot_conns
For example:
name serverside.tot_conns --------------------------------------- -------------------- spk-apps-nginx-http2-crd-virtual-server 31
View the load balancing pool connection statistics:
tmctl -d blade pool_member_stat -s pool_name,serverside.tot_conns
For example:
web-apps-http2-crd-pool 15 web-apps-http2-crd-pool 16
