F5BigCnePortlist
Overview
The F5BigCnePortlist Custom Resource (CR) is useful for defining larger, more complex sets of service ports, that can then be referenced by any of the Service Proxy Kubernetes (SPK) CRs:
  • F5BigFwPolicy - Granulalar packet filtering based on access control list (ACL) policies.
This document guides you through creating a simple F5BigCnePortlist.
_images/spk_info.png Note: The F5BigCneAddresslist CR is useful for defining lists of IP addresses ports.
Parameters
The CR spec parameters used to configure the Service Proxy TMM static routing table are:
Parameter Description
ports The service ports included in the port list. Port 0 is not a valid value, and is not allowed.
portLists This is a string which refers to another portlist that consists of either ports or child portlists.
Requirements
Ensure you have:
  • Have a Linux based workstation.
Installation
Use the following steps to install the F5BigCnePortlist CR:
_images/spk_info.png Tip: Open a second shell to view the BIG-IP Next for Kubernetes Event Logs while installing.
  1. Copy the example CR into a YAML file:
    apiVersion: "k8s.f5net.com/v1"
    kind: F5BigCnePortlist
    metadata:
       namespace: "gateway"
    spec:
       ports:
         - "5000-5500"
         - "80"
       portLists:
         -	“portList1”
         -	“portList2”
    metadata:
    spec:
       ports:
         - "4000-4100"
         - "8080"
       portLists:
         -	“portList3”
         -	“portList4”
  2. Install the F5BigCnePortlist CR:
    kubectl apply -f spk-port-list.yaml
    In this example, the BIG-IP Controller logs indicate the F5BigCneAddresslist CR was added/updated:
    I0607 12:00:00.12345   1 event.go:282] Event(v1.ObjectReference{Kind:"F5PortList",
    F5PortList gateway/allow-5000-80 was added/updated
Feedback
Provide feedback to improve this document by emailing spkdocs@f5.com.
