F5SPKSnatpool
The F5SPKSnatpool Custom Resource (CR) configures the BIG-IP Next for Kubernetes Traffic Management Microkernel (TMM) to perform source network address translations (SNAT) on egress network traffic. When internal Pods connect to external resources, their internal cluster IP addresses is translated to one of the available IP address in the SNAT pool. For the full list of CRs, refer to the BIG-IP Next for Kubernetes CRs.
Note: In clusters with multiple BIG-IP Next for Kubernetes Controller instances, ensure the IP addresses defined in each F5SPKSnatpool CR do not overlap.
Parameters
The table below describes the F5SPKSnatpool parameters used in this document:
Parameter Description
metadata.name The name of the F5SPKSnatpool object in the Kubernetes configuration.
spec.name The name of the F5SPKSnatpool object referenced and used by other CRs such as the F5SPKEgress CR.
spec.addressList The list of IPv4 or IPv6 address used to translate source IP addresses as they egress TMM.
spec.sharedSnatAddressEnabled Enables the shared SNAT address for the TMM pods, configuring them to use a single IP address: true or false (default).
Scaling TMM
When scaling BIG-IP Next for Kubernetes TMM beyond a single instance in the Project, the F5SPKSnatpool CR must be configured to provide a SNAT pool to each TMM replica. The first SNAT pool is applied to the first TMM replica, the second snatpool to the second TMM replica, continuing through the list.
Important: When configuring SNAT pools with multiple IP subnets, ensure all TMM replicas receive the same IP subnets.
Example CR:
 apiVersion: "k8s.f5net.com/v1"
 kind: F5SPKSnatpool
 metadata:
   namespace: default
 spec:
   addressList:
     - - 10.244.10.1
       - 10.244.20.1
     - - 10.244.10.2
       - 10.244.20.2
     - - 10.244.10.3
       - 10.244.20.3
Example deployment:
_images/spk_snatpool_cr.png
Referencing the SNAT Pool
Once the F5SPKSnatpool is configured, a virtual server is required to process the egress Pod connections, and apply the SNAT IP addresses. The F5SPKEgress CR creates the required virtual server, and is included in the Deployment procedure below:
Requirements
Ensure you have:
  • Created an external and internal F5SPKVlan.
  • A Linux based workstation.
Deployment
Use the following steps to deploy the example F5SPKSnatpool CR, the required F5SPKEgress CR, and to verify the configurations.
  1. Configure SNAT Pools using the example CR, and deploy to the same Project as the Ingress Controller. For example:
    In this example, the CR installs to the default Project:
    kind: F5SPKSnatpool
    metadata:
      namespace: default
    spec:
      addressList:
        - - 10.244.10.1
          - 10.244.20.1
          - 2002::10:244:10:1
          - 2002::10:244:20:1
        - - 10.244.10.2
          - 10.244.20.2
          - 2002::10:244:10:2
          - 2002::10:244:20:2
  2. Install the F5SPKSnatpool CR:
    kubectl apply -f spk-snatpool-cr.yaml
  3. To verify the SNAT pool IP address mappings on the TMMs, use any one of the following methods:
    • Method 1: For individual TMMs, login to the debug sidecar and run the following command to view the SNAT pool members:
      tmctl -w 120 -d blade pool_member_stat -s pool_name,addr
      The addresses will be displayed as IPv6 address in hexadecimal format. For example, 10.200.3.4 address is displayed as 00:00:00:00:00:00:00:00:00:00:FF:FF:0A:C8:03:04:00:00:00:00.
    • Method 2: If dynamicRouting is enabled during startup, in override file of the TMM section, then the following method can be used to verify the SNAT pool membership.
      1. Execute into f5-tmm-routing container:
        $ k exec -it f5-tmm-67d54df997-p7ntl -c f5-tmm-routing – bash
      2. Run the Integrated Management Interface Shell (IMISH) command:
        I have no name!@f5-tmm-67d54df997-p7ntl:/cod    e$ imish
      3. Run show ip route command:
        5-tmm-67d54df997-p7ntl[0]>show ip route
        Codes: K - kernel, C - connected, S - static, R - RIP, B - BGP
            O - OSPF, IA - OSPF inter area
            N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
            E1 - OSPF external type 1, E2 - OSPF external type 2
            i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
            * - candidate default
        IP Route Table for VRF "default"
        K       10.9.77.25/32 [0/0] is directly connected, tmm
        C       10.244.99.91/32 is directly connected, eth0
        C       11.11.11.0/24 is directly connected, tmm-client
        C       22.22.22.0/24 is directly connected, tmm-server
        C       127.20.0.0/16 is directly connected, tmm_bp
        C       169.254.0.0/24 is directly connected, tmm
        Gateway of last resort is not set
      4. Run show ipv6 route command:
        f5-tmm-67d54df997-p7ntl[0]>show ipv6 route
        IPv6 Routing Table
        Codes: K - kernel route, C - connected, S - static, R - RIP, O - OSPF,
           IA - OSPF inter area, E1 - OSPF external type 1,
           E2 - OSPF external type 2, N1 - OSPF NSSA
           external type 1,
           N2 - OSPF NSSA external type 2, I - IS-IS, B - BGP
        Timers: Uptime
        C      2002::11:11:11:0/112 via ::, tmm-client, 00:04:52
        C      2002::22:22:22:0/112 via ::, tmm-server, 00:04:52
        K      2021::77:25/128 [0/0] via ::, tmm, 00:04:50
        C      fd00:10:244:25:4aa:40cb:5dc6:8b9a/128 via ::, eth0, 00:05:20
        C      fe80::/64 via ::, tmm-server, 00:04:52
  4. Configure the F5SPKEgress CR, and install to the same Project as the Ingress Controller. For example:
    kind: F5SPKEgress
    metadata:
      namespace: default
    spec:
      egressSnatpool: "egress_snatpool"
  5. Install the F5SPKEgress CR:
    In this example, the CR file is named spk-egress-cr.yaml:
    kubectl apply -f spk-egress-cr.yaml
  6. Verify the status of the installed CR:
    kubectl get f5-spk-vlan -n default
    In this example, the CR has installed successfully.
    NAME              STATUS    MESSAGE
    staticroute-ipv4  SUCCESS   CR config sent to all grpc endpoints
  7. To verify connectivity statistics, log in to the Debug Sidecar:
    kubectl exec -it deploy/f5-tmm -c debug -n <project>
    In this example, the debug sidecar is in the default Project:
    kubectl exec -it deploy/f5-tmm -c debug -n default
  8. Verify the internal virtual servers have been configured:
    tmctl -f /var/tmstat/blade/tmm0 virtual_server_stat -s name,serverside.tot_conns
    In this example, 3 IPv4 connections, and 2 IPv6 connections have been initiated by internal Pods:
    name              serverside.tot_conns
    egress-ipv6                          2
    egress-ipv4                          3
Feedback
Provide feedback to improve this document by emailing spkdocs@f5.com.
