Configure CoreDump Limit on DPU¶
Coredumps are a disk files containing an image of the process’s memory at the time of termination. This image can be used in a debugger to examine the state of the program at the time that it terminated. F5 recommends modifying the default values of ProcessSizeMax and ExternalSizeMax parameters to 50GB to avoid capturing incorrect or incomplete core created by TMM crashes.
Install the install systemd-coredump file.
sudo apt install systemd-coredump
Check the systemd-coredump file.
cat /etc/systemd/coredump.conf
Sample Response:
# This file is part of systemd. # # systemd is free software; you can redistribute it and/or modify it under the # terms of the GNU Lesser General Public License as published by the Free # Software Foundation; either version 2.1 of the License, or (at your option) # any later version. # # Entries in this file show the compile time defaults. Local configuration # should be created by either modifying this file, or by creating "drop-ins" in # the coredump.conf.d/ subdirectory. The latter is generally recommended. # Defaults can be restored by simply deleting this file and all drop-ins. # # Use 'systemd-analyze cat-config systemd/coredump.conf' to display the full config. # # See coredump.conf(5) for details. [Coredump] #Storage=external #Compress=yes #ProcessSizeMax=2G #ExternalSizeMax=2G #JournalSizeMax=767M #MaxUse= #KeepFree=
Edit the coredump.conf file and set the
ProcessSizeMaxandExternalSizeMaxparameters to 50GB.nano /etc/systemd/coredump.conf
Verify the changes.
Response:
# /etc/systemd/coredump.conf # This file is part of systemd. # # systemd is free software; you can redistribute it and/or modify it under the # terms of the GNU Lesser General Public License as published by the Free # Software Foundation; either version 2.1 of the License, or (at your option) # any later version. # # Entries in this file show the compile time defaults. Local configuration # should be created by either modifying this file, or by creating "drop-ins" in # the coredump.conf.d/ subdirectory. The latter is generally recommended. # Defaults can be restored by simply deleting this file and all drop-ins. # # Use 'systemd-analyze cat-config systemd/coredump.conf' to display the full config. # # See coredump.conf(5) for details. [Coredump] #Storage=external #Compress=yes ProcessSizeMax=50G ExternalSizeMax=50G
