Network configuration and application traffic management¶
Dynamic routing with ZebOS¶
BNK supports dynamic routing through ZebOS. You configure ZebOS routing features such as BGP, OSPF, and static routes by creating a ConfigMap. TMM loads the routing configuration from this file.
Create a ZebOS ConfigMap.
apiVersion: v1 kind: ConfigMap metadata: name: zebos-config namespace: <cneInstanceNamespace> data: zebos.conf: | router bgp 65001 neighbor 10.19.1.1 remote-as 65000 address-family ipv4 unicast redistribute connected exit-address-family
kubectl apply -f zebos-config.yaml --namespace <cneInstanceNamespace>
Verify the configuration.
kubectl get configmap zebos-config --namespace <cneInstanceNamespace> -o yaml
Gateway API setup¶
BNK supports Gateway API v1.5.0. The CNE Controller manages Gateway API custom resources and F5 adapter resources, including SecPolicy and NetPolicy. These resources extend traffic, security, and network behavior.
CR |
Function |
GatewayClass |
Defines the Gateway class that BNK implements. |
Gateway |
Acts as the cluster entry point for external traffic. Manages listeners. |
HTTPRoute |
Routes HTTP traffic by path, header, or weight. |
GRPCRoute |
Routes gRPC traffic. |
ReferenceGrant |
Enables cross-namespace references. |
SecPolicy |
Attaches firewall or DDoS policies to a Gateway or GatewayClass. |
NetPolicy |
Attaches iRules, TCP settings, and HSL settings to a Gateway. |
BackendTLSPolicy |
Configures TLS from the Gateway to backend Services. See Secure connections to backends. |
Prerequisites¶
Client-side and server-side mutual TLS (mTLS) require Gateway API standard bundle version 1.5 or later.
The following table lists the minimum Gateway API bundle version for each capability:
Capability |
Minimum bundle version |
Client-side TLS |
1.0 |
Client-side mTLS |
1.5 |
Server-side TLS |
1.4 |
Server-side mTLS |
1.5 |
Upgrade the Gateway API bundle on IBM ROKS¶
IBM Red Hat OpenShift on IBM Cloud (ROKS) clusters include a pre-installed Gateway API bundle. If the installed version is older than 1.5, run the following commands to upgrade to version 1.5.0.
Note
You might need to repeat these steps if the validation webhook blocks the operation.
oc delete validatingadmissionpolicybinding openshift-ingress-operator-gatewayapi-crd-admission
oc delete validatingadmissionpolicy openshift-ingress-operator-gatewayapi-crd-admission
kubectl apply --server-side --force-conflicts -f https://github.com/kubernetes-sigs/gateway-api/releases/download/v1.5.0/standard-install.yaml
Server-side TLS¶
A Gateway sits between two separate TLS connections. Each TLS connection is configured independently.
Connection |
Gateway’s role |
Configured with |
External client → Gateway |
Server |
Gateway → backend Service |
Client |
This section covers the connection between the gateway (TMM) and the server. Terminating TLS for incoming client traffic does not encrypt traffic onward to your backends — you configure that separately here.
Two resources are involved:
To do this |
Use |
Verify the backend’s certificate |
Present the Gateway’s certificate to the backend |
Each resource on its own gives you one-directional TLS. Use both together for mutual TLS (mTLS): the Gateway proves its identity to the server, and the server proves its identity to the Gateway.
apiVersion: gateway.networking.k8s.io/v1alpha2
kind: BackendTLSPolicy
metadata:
namespace: default
spec:
targetRefs:
- group: ""
kind: Service
port: 8443
validation:
caCertificateRefs:
- name: ca-cert-secret
group: ""
kind: ConfigMap
hostname: backend.example.com
status:
ancestors:
- ancestorRef:
group: gateway.networking.k8s.io
kind: Gateway
namespace: default
port: 443
controllerName: f5.com/bnk-ns-cne-controller
conditions:
- lastTransitionTime: "2026-06-09T10:30:00Z"
message: "Policy accepted by controller"
observedGeneration: 1
reason: Accepted
status: "True"
type: Accepted
- lastTransitionTime: "2026-06-09T10:30:05Z"
message: "Policy programmed to gateway"
reason: Programmed
status: "True"
type: Programmed
conditions:
message: "BackendTLSPolicy has been accepted"
reason: Accepted
status: "True"
type: Accepted
message: "CA certificate resolved successfully"
reason: ResolvedRefs
status: "True"
type: ResolvedRefs
Note
The Certificate Authority (CA) bundle cannot be sent directly with SSL profile objects via the TMM async API because of its size; it must be stored in the TMM container. Use an inline CA bundle to achieve this. The bundle is transferred inline within the async API object, which removes the need for a separate file transfer mechanism.
Client-side TLS¶
Connections between the gateway (TMM) and the client are configured using listeners at the Gateway level.
Listeners and TLS¶
Listeners expose the TLS setting on a per-domain or subdomain basis. TLS settings of a listener are applied to all domains that satisfy the hostname criteria.
In the following example, the Gateway serves the TLS certificate defined in the default-cert Secret resource for all requests.
listeners:
- protocol: HTTPS # Other possible value is `TLS`
port: 443
tls:
mode: Terminate # If protocol is `TLS`, `Passthrough` is another possible mode
certificateRefs:
- kind: Secret
group: ""
Listeners with different certificates¶
In this example, the Gateway is configured to serve the foo.example.com and bar.example.com domains. The certificate for these domains is specified in the Gateway.
kind: Gateway
metadata:
spec:
gatewayClassName: example
listeners:
- name: foo-https
protocol: HTTPS
port: 443
hostname: foo.example.com
tls:
certificateRefs:
- kind: Secret
group: ""
- name: bar-https
protocol: HTTPS
port: 443
hostname: bar.example.com
tls:
certificateRefs:
- kind: Secret
group: ""
Wildcard TLS listeners¶
In this example, the Gateway is configured with a wildcard certificate for *.example.com and a different certificate for foo.example.com. Since a specific match takes priority, the Gateway will serve foo-example-com-cert for requests to foo.example.com and wildcard-example-com-cert for all other requests.
kind: Gateway
metadata:
spec:
listeners:
- name: foo-https
protocol: HTTPS
port: 443
tls:
certificateRefs:
- kind: Secret
group: ""
- name: wildcard-https
protocol: HTTPS
port: 443
hostname: "*.example.com"
tls:
certificateRefs:
- kind: Secret
group: ""
Caution
Don’t create a listener without a hostname for client-side TLS. A listener without a hostname accepts all Server Name Indication (SNI) values, but the certificates might not match. This can cause the wrong certificate to be served to clients, which creates a security risk.
Trust a specific CA¶
metadata:
namespace: f5-alpha
spec:
targetRefs:
- group: ""
kind: Service
sectionName: https # optional: target a specific port by name
validation:
caCertificateRefs:
- group: ""
kind: ConfigMap
name: ca-configmap # must contain key 'ca.crt'
hostname: my-backend.example.com # SNI hostname used on the backend connection
subjectAltNames: # optional: enforce SAN validation
- type: Hostname
hostname: backend-tls.example.com
- type: URI
uri: <uri>
options: {} # implementation-specific TLS options
Trust the well-known CA set¶
metadata:
namespace: f5-alpha
spec:
targetRefs:
- group: ""
kind: Service
validation:
wellKnownCACertificates: System
Set a minimum TLS version and cipher suites¶
spec.options accepts implementation-specific settings for the backend connection.
metadata:
namespace: default
spec:
targetRefs:
- group: ""
kind: Service
validation:
options:
f5.com/ciphers: "ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:!aNULL:!eNULL"
f5.com/minTLSVersion: "1.2"
BackendTLSPolicy parameters¶
Parameter |
Description |
Implementation details |
Additional TLS settings for the backend connection. Use |
As per the Gateway API community standard. |
CR status codes
The controller writes the following conditions back to .status.ancestors[].conditions:
Condition |
Reason |
Meaning |
Accepted |
Accepted |
Policy accepted and programmed. |
Accepted |
Invalid |
Policy spec is invalid (e.g., unsupported |
Accepted |
NoValidCACertificate |
All |
Accepted |
Conflicted |
Another BackendTLSPolicy takes precedence for this target. |
ResolvedRefs |
ResolvedRefs |
All references resolved successfully. |
ResolvedRefs |
InvalidCACertificateRef |
A |
ResolvedRefs |
InvalidKind |
A referenced resource kind is unknown or unsupported. |
CR Parameters
The table below provides the description and implementation details of Gateway CR spec parameters.
Parameters |
Description |
Provides additional TLS settings. Specify |
Sample CRs
This section lists the sample CRs of use cases available to apply Gateway CR. In each sample, necessary parameters for applying a CR is added.
Gateway CR with minimum TLS version and cipher suites
Gateway TLS configurations provide an options map to add additional TLS settings for server-side implementation-specific features.
metadata:
namespace: default
spec:
targetRefs:
- group: ""
kind: Service
validation:
wellKnownCACertificates: system
# Implementation-specific TLS options with OpenSSL cipher format
options:
# OpenSSL cipher list for backend connection
Client-side mTLS¶
Gateway API supports validating the Transport Layer Security (TLS) certificate that a frontend client presents during the TLS handshake.
Why validation is configured at the Gateway level¶
Server certificate configuration is defined per listener. Client certificate validation is different—it’s configured at the Gateway level in the spec.tls field.
This design prevents a security risk caused by HTTP/2 and TLS connection coalescing. Without Gateway-level validation, a connection established for one listener could be reused by another listener on the same port. This could bypass listener-specific validation settings.
Note
This feature is part of extended support. For more information on support levels, refer to the conformance guide.
Frontend validation settings¶
Client validation uses the frontendValidation struct to define how the Gateway verifies a client’s identity. The struct includes two fields:
caCertificateRefs: A list of references to Kubernetes objects (typically ConfigMaps) that contain Privacy-Enhanced Mail (PEM)-encoded Certificate Authority (CA) certificate bundles. The Gateway uses these bundles as trust anchors to validate the client’s certificate.
mode: Defines the validation behavior:
AllowValidOnly(default): The Gateway accepts connections only when the client presents a valid certificate that passes validation against the CA bundle.AllowInsecureFallback: The Gateway accepts connections even when the client certificate is missing or fails verification. This mode delegates authorization to the backend.
Caution
Use AllowInsecureFallback with care. Connections that skip certificate validation rely entirely on the backend for authorization.
Gateway-level scoping¶
You can apply validation globally to the Gateway or override it for specific ports:
Default configuration: Applies to all HTTPS listeners on the Gateway unless a per-port override exists.
Per-port configuration: Overrides the default configuration for all listeners that handle traffic on a specific port. Use this option for fine-grained control.
The following example shows how to configure client certificate validation with a default configuration and a per-port override.
kind: Gateway
metadata:
spec:
gatewayClassName: acme-lb
tls:
frontend:
default:
validation:
caCertificateRefs
- kind: ConfigMap
group: ""
perPort:
- port: 8443
tls:
validation:
caCertificateRefs:
- kind: ConfigMap
group: ""
listeners:
- name: foo-https
protocol: HTTPS
port: 443
tls:
certificateRefs:
- kind: Secret
group: ""
- name: bar-https
protocol: HTTPS
port: 8443
tls:
certificateRefs:
- kind: Secret
group: ""
Ingress traffic with HTTPRoute and GRPCRoute¶
Apply a Gateway CR.
Create the entry point for external traffic.
apiVersion: gateway.networking.k8s.io/v1 kind: Gateway metadata: name: my-gateway namespace: <applicationNamespace> spec: gatewayClassName: f5-bnk-gateway-class listeners: - name: http port: 80 protocol: HTTP - name: https port: 443 protocol: HTTPS tls: mode: Terminate certificateRefs: - name: my-tls-secret
kubectl apply -f gateway.yaml
Create an HTTPRoute.
apiVersion: gateway.networking.k8s.io/v1 kind: HTTPRoute metadata: name: app-route namespace: <applicationNamespace> spec: parentRefs: - name: my-gateway rules: - matches: - path: type: PathPrefix value: /api backendRefs: - name: api-service port: 8080
kubectl apply -f httproute.yaml
iRules integration (NetPolicy)¶
apiVersion: k8s.f5.com/v1
kind: L4Route
metadata:
spec:
host: 11.19.1.100
port: 8050
protocol: TCP
pool:
service: backend-svc
servicePort: 8050
kubectl apply -f l4route.yaml
Egress traffic with SNAT¶
Create a SNAT pool.
apiVersion: k8s.f5net.com/v1 kind: F5SPKSnatpool metadata: name: egress-snat namespace: <applicationNamespace> spec: addresses: - 11.19.1.200 - 11.19.1.201
kubectl apply -f snatpool.yaml
Create an Egress CR.
apiVersion: k8s.f5net.com/v1 kind: F5SPKEgress metadata: name: app-egress namespace: <applicationNamespace> spec: snatpoolName: egress-snat
kubectl apply -f egress.yaml
Attach iRules to Gateway listeners with the NetPolicy resource. This allows custom traffic modification at the Gateway layer.
Create an iRule CR.
apiVersion: k8s.f5net.com/v1 kind: F5BigCneIrule metadata: name: my-irule namespace: <applicationNamespace> spec: irule: | when HTTP_REQUEST { HTTP::header insert X-Forwarded-By BNK }
kubectl apply -f irule.yaml
Create a NetPolicy that references the iRule.
apiVersion: k8s.f5.com/v1 kind: NetPolicy metadata: name: irule-policy namespace: <applicationNamespace> spec: targetRef: group: gateway.networking.k8s.io kind: Gateway name: my-gateway irules: - name: my-irule
kubectl apply -f netpolicy.yaml
F5 IPAM Controller¶
The F5 IPAM Controller (FIC) manages IP address allocation for Gateway CRs.
Use case |
When |
Behavior |
IP defined in Gateway |
Gateway sets the address |
FIC validates the IP and assigns it from the matching pool. |
IP not defined |
Gateway omits the address |
FIC auto-assigns an available IP from the pool. |
Firewall Policy (F5BigFwPolicy)¶
BNK provides a stateful firewall through the F5BigFwPolicy custom resource. You attach firewall policies to Gateway resources with SecPolicy.
Create an address list.
apiVersion: k8s.f5net.com/v1 kind: F5BigCneAddresslist metadata: name: allowed-ips namespace: <applicationNamespace> spec: addresses: - 10.0.0.0/8 - 192.168.0.0/16
kubectl apply -f addresslist.yaml
Create a firewall rule list.
apiVersion: k8s.f5net.com/v1 kind: F5BigFwRulelist metadata: name: allow-internal namespace: <applicationNamespace> spec: rules: - name: allow-internal-traffic action: accept source: addressLists: - allowed-ips
kubectl apply -f fw-rulelist.yaml
Create a firewall policy.
apiVersion: k8s.f5net.com/v1 kind: F5BigFwPolicy metadata: name: my-fw-policy namespace: <applicationNamespace> spec: rules: - rulelist: allow-internal
kubectl apply -f fw-policy.yaml
Attach the policy to a Gateway with SecPolicy.
apiVersion: k8s.f5.com/v1 kind: SecPolicy metadata: name: gw-security namespace: <cneInstanceNamespace> spec: targetRef: group: gateway.networking.k8s.io kind: Gateway name: my-gateway firewallPolicies: - name: my-fw-policy
kubectl apply -f secpolicy.yaml
DDoS protection¶
You can configure DDoS protection with the F5BigDdosGlobal custom resource. Use this resource to set up detection vectors, thresholds, event logging, and allow lists.
kind: F5BigDdosGlobal
metadata:
spec:
hslPublisher:
# Configure HSL publisher for DDoS event logging
vectors:
# Configure detection vectors and thresholds
allowList:
# IPs exempt from DDoS detection
HSL logging¶
High-Speed Logging (HSL) sends traffic and security logs to external log collectors. Configure HSL through NetPolicy.
Create an HSL publisher.
apiVersion: k8s.f5net.com/v1 kind: F5BigLogHslpub metadata: name: hsl-publisher namespace: <cneInstanceNamespace> spec: # Publisher configuration for remote log server
Create a log profile.
apiVersion: k8s.f5net.com/v1 kind: F5BigLogProfile metadata: name: my-log-profile namespace: <applicationNamespace> spec: # Log profile referencing HSL publisher
Security hardening best practices¶
Use the following practices to harden your BNK deployment:
Read-only root filesystems: BNK uses read-only root filesystems for containers. This helps prevent changes to binaries.
Minimum RBAC permissions: BNK includes minimal cluster-wide RBAC. Review the RBAC justification in Appendix A.
mTLS for inter-component traffic: All internal traffic uses mutual TLS. Certificates are managed by cert-manager.
Network policies: Use Kubernetes
NetworkPolicyto restrict pod communication.Secret management: Store JWT licenses, TLS certificates, and FAR credentials as Kubernetes Secrets. Apply least-privilege RBAC.
Image pull secrets: Use FAR service accounts with scoped permissions. Rotate keys regularly.
Audit logging: Enable Kubernetes audit logs to track access to BNK resources.
DPU isolation: Run only BNK on the DPU node. Do not install other software.
AI inferencing load balancing (early access)¶
Architecture¶
The AI Inferencing Load Balancing feature in BNK distributes traffic for Large Language Model (LLM) inference workloads. It uses the NVIDIA LLM Router blueprint and makes routing decisions based on real‑time GPU metrics, queue depth, and model‑specific signals from inference servers.
Core components
Component |
Description |
TMM with AI LB module |
Extends the TMM data plane with LLM‑aware load‑balancing logic. |
Metrics Collector |
Collects inference metrics such as GPU utilization, queue depth, and token throughput from backend LLM servers. |
Policy Engine |
Uses built‑in or custom policy scripts to decide how traffic is routed based on collected metrics. |
JSON Schema Interface |
Provides a standard structure for defining custom load‑balancing algorithms. |
Prerequisites¶
BNK installed and running on a DPU
NVIDIA GPU infrastructure with inference servers such as NVIDIA Triton, vLLM, or TGI
Gateway API routing configured with backends that point to inference endpoints
AI LB feature flag enabled (Early Access; contact your F5 account team)
Configuration¶
Configure the AI LB feature using custom resource parameters. These parameters define the metrics endpoint, collection interval, and load‑balancing behavior.
Important
This is an Early Access feature. Schemas, parameters, and supported algorithms may change in future releases. Contact your F5 account team for the latest EA configuration guide and supported platforms.
Configuration options
Option |
Description |
Built‑in Script |
Provides preset algorithms optimized for LLM traffic, such as GPU‑aware round‑robin or least‑tokens‑queued. |
Custom Script |
Lets you define custom logic using the JSON Schema Interface. You can use your own metrics and routing rules based on model behavior or platform needs. |
CR Parameters |
Sets metrics endpoint URLs, polling intervals, backend health thresholds, and failover options. |
Observability and monitoring¶
OTEL collector setup¶
FLO deploys the OTEL Collector. The Collector receives metrics from TMM through the Distributed TODA pipeline and exports them in Prometheus format on port 9090.
# Verify OTEL Collector is running
kubectl get pods --namespace <cneInstanceNamespace> | grep otel
# Check OTEL service
kubectl get svc otel-collector-svc --namespace <cneInstanceNamespace>
Expected ports
Port Name |
Port |
Purpose |
otlp-grpc |
4317/TCP |
Receives metrics from Observer |
otlp-prometheus |
9090/TCP |
Exports metrics to Prometheus |
Prometheus and Grafana integration¶
Prometheus is not installed by FLO and must be installed manually.
Install Prometheus.
helm repo add prometheus-community https://prometheus-community.github.io/helm-charts helm install prometheus prometheus-community/prometheus \ --namespace monitoring --create-namespace
Configure Prometheus to scrape OTEL metrics.
Add this block to your
prometheus.yamlscrape configuration:scrape_configs: - job_name: 'bnk-otel' static_configs: - targets: ['otel-collector-svc.<cneInstanceNamespace>:9090'] metric_relabel_configs: - source_labels: [__name__] regex: '(.*)\-(.*)' replacement: 'f5_$1_$2' target_label: __name__ action: replace
Query BNK metrics.
Example queries:
# Virtual server bytes received f5_tmm_f5_virtual_server_clientside_received_bytes_total # Virtual server connections f5_tmm_f5_virtual_server_clientside_connections_total # TMM CPU utilization f5_tmm_cpu_utilization
The OTEL exporter adds the
f5_tmm_prefix.Install Grafana and create dashboards.
helm install grafana grafana/grafana --namespace monitoring
Add Prometheus as a data source in Grafana. Then import BNK dashboards or create your own.
Note
Prometheus and Grafana are not deployed by FLO. Install and configure them manually.
Distributed TODA stats¶
Distributed TODA processes large volumes of telemetry data through four pod types:
Pod |
Role |
Receiver (StatefulSet) |
Collects metrics from the TMM Scraper and sends them to Observer using gRPC with mTLS. |
Observer (StatefulSet) |
Aggregates metrics from multiple TMMs and sends them to the OTEL Collector using gRPC with mTLS. |
Coordinator (Operator) |
Manages collection and aggregation workflows using gRPC with mTLS. |
TMM Scraper |
Runs inside each TMM pod. Replaces tmstatsd and exposes metrics from tmctl over gRPC. |
Note
The metrics export interval is fixed at two minutes in the Coordinator ConfigMap and cannot be changed.
Fluentd logging¶
Fluentd collects and forwards logs from BNK components. Logs use structured formats and are grouped by component (TMM, Controller, CWC).
QKView and iHealth¶
Use the CWC QKView API to collect diagnostic data.
# Generate QKView
curl --key cwc_api/client_key.pem \
--cert cwc_api/client_certificate.pem \
--cacert cwc_api/ca_certificate.pem \
https://f5-spk-cwc.f5-cne-core:30881/qkview \
-H "Authorization: Bearer $CWC_TOKEN"
Upload the resulting file to iHealth for analysis.
High-availability architecture considerations¶
BNK on DPU uses Kubernetes‑native patterns to provide high availability. The platform maintains traffic flow and control plane stability through the following mechanisms.
Mechanism |
Description |
TMM DaemonSet redundancy |
With multiple DPU nodes, the TMM DaemonSet runs one TMM pod on each node. If a DPU fails, traffic is routed to TMM pods on the remaining nodes. |
dSSM Redis Sentinel HA |
dSSM uses Redis Sentinel with three replicas. Sentinel promotes a replica if the master fails. Data is stored on persistent volumes. |
Control plane resilience |
The CNE Controller and CWC run on host nodes. Kubernetes restarts them if a failure occurs. |
FLO reconciliation |
FLO monitors all BNK components. If a component fails or is deleted, FLO detects the change and redeploys it. |
Certificate auto‑renewal |
cert‑manager renews TLS certificates before they expire to prevent mTLS issues. |
DPU failure handling¶
When a DPU node fails, BNK and Kubernetes handle recovery through the following sequence:
Kubernetes marks the DPU node as NotReady after the node‑monitor‑grace‑period (default: 40 seconds).
The TMM pod on the failed DPU moves to Terminating.
If your external load balancer or router uses health checks, it stops sending traffic to the failed DPU’s virtual IPs.
Other TMM pods on healthy DPU nodes continue processing traffic.
FLO detects the change in component status and updates the custom resource conditions.
When the DPU recovers, Kubernetes marks the node Ready, the TMM DaemonSet recreates the pod, and FLO reconciles configuration.
Note
BNK provides High Availability Upgrade Phase I capabilities. Full rolling upgrades with zero downtime are planned for future releases.
Appendix A: RBAC minimum privileges¶
BNK follows the principle of least privilege. The components below require cluster‑wide access and include justification for each permission.
Component |
Resource |
Privilege |
Justification |
CNE Controller |
nodes |
get, list |
Needed to create static routes to backend pods for in‑cluster services. Required only when |
CNE Controller |
CRDs |
get, list |
Determines which F5 CRDs are installed so the controller can start the right watchers. |
CNE Controller |
namespaces |
get, list, watch |
Adds or removes OVN annotations. Required only when |
CNE Controller |
webhookconfigs |
get, update |
Updates the CA bundle for the validation webhook, which is cluster‑scoped. |
CWC |
nodes |
get, list |
Gathers node details for telemetry reporting. |
CWC |
CRDs |
get, list |
Reads installed F5 CRDs for telemetry and QKView collection. |
CWC |
namespaces |
get, list |
Collects namespace details for QKView. |
Note
When wholeCluster is set to true (daemon-set mode) and watchNamespace is empty (default), the CNE Controller does not need permissions for nodes, namespaces, or adminpolicybasedexternalroutes.
Appendix B: Migration from SPK to BNK¶
The following guidance applies when migrating from F5 SPK (Service Proxy for Kubernetes) to BNK (BIG‑IP Next for Kubernetes).
Key differences¶
Aspect |
SPK (Previous) |
BNK |
Product Name |
Service Proxy for Kubernetes (SPK) |
BIG‑IP Next for Kubernetes (BNK) |
Target Platform |
Kubernetes on standard servers |
Kubernetes on NVIDIA BlueField‑3 DPU |
Lifecycle Management |
Manual Helm‑based workflows |
Automated lifecycle management through FLO |
CRD Management |
Manual installs |
FLO installs CRDs and validates versions |
Environment Detection |
Manual node labels |
Env‑Discovery auto‑detects DPUs and configuration |
Licensing |
Connected or Disconnected |
Connected or FLP (License Proxy) |
Gateway API |
v1.0 (limited) |
v1.2.0 with SecPolicy and NetPolicy |
Observability |
OTEL + tmstatsd |
Distributed TODA + OTEL (replaces tmstatsd) |
Security Extensions |
Basic firewall CRs |
SecPolicy for Gateway‑level firewall and DDoS |
iRules |
Not supported in Gateway API |
NetPolicy adds iRules support in Gateway API |
Migration steps¶
Export all SPK CRs (
F5SPKVlan,F5SPKEgress,F5SPKSnatpool,L4Route, and others) from the current cluster.SPK networking CRs (
F5SPKVlan,F5SPKStaticRoute, and others) are compatible with BNK and do not need format changes.Uninstall SPK following the SPK documentation.
Prepare the DPU infrastructure. See Infrastructure Preparation.
Install BNK using FLO. See BNK Installation.
Reapply exported CRs. Networking CRs should apply without changes.
Convert any Ingress‑based configuration to Gateway API resources such as
HTTPRouteorGRPCRoute.Configure new BNK capabilities such as FLP licensing, SecPolicy, NetPolicy, and Distributed TODA.
Validate all traffic paths and services after migration.
Important
SPK and BNK cannot run in the same cluster. Schedule downtime and plan a maintenance window for migration.
