F5 Application Delivery Controller Solutions > Troubleshoot with tcpdump and Wireshark Source | Edit on
Appendix¶
The Appendix is reference material for other ways to accomplish SSL decryption.
Decrypt SSL with iRule¶
In the lab we have already configured the iRule and applied it to the Virtual Server. If you want to validate you can login to the BIG-IP from the jumpbox by launching the Chrome browser and clicking on the BIG-IP01 shortcut. Login as:
user: 'admin' password: 'admin'
Configure an iRule as follows (ours is named 'ssl-decrypt.ir'):
1 2 3 4 5 6 7 8 9 10 11 12 13
when CLIENTSSL_HANDSHAKE { log local0. "CLIENT_RANDOM [SSL::clientrandom] [SSL::sessionsecret]" log local0. "RSA Session-ID:[SSL::sessionid] Master-Key:[SSL::sessionsecret]" log local0. "SERVER_HANDSHAKE_TRAFFIC_SECRET [SSL::clientrandom] [SSL::tls13_secret server hs]" log local0. "CLIENT_HANDSHAKE_TRAFFIC_SECRET [SSL::clientrandom] [SSL::tls13_secret client hs]" log local0. "CLIENT_TRAFFIC_SECRET_0 [SSL::clientrandom] [SSL::tls13_secret client app]" log local0. "SERVER_TRAFFIC_SECRET_0 [SSL::clientrandom] [SSL::tls13_secret server app]" } when SERVERSSL_HANDSHAKE { log local0. "SERVER_Side_IP:TCP source port:[IP::local_addr]: [TCP::local_port]" log local0. "CLIENT_RANDOM [SSL::clientrandom] [SSL::sessionsecret]" log local0. "RSA Session-ID:[SSL::sessionid] Master-Key:[SSL::sessionsecret]" }
Apply this new iRule to the virtual server. In our lab environment the iRule has already been created and applied to the Virtual Server.
You can now start a tcpdump and surf the website.
After you have stopped the tcpdump, you will now need to SSH to the F5 and run the following command:
grep Session-ID /var/log/ltm | sed 's/.*\(RSA.*\)/\1/' > /var/tmp/session.pms grep -h -o 'CLIENT_RANDOM.*' /var/log/ltm >> /var/tmp/session.pms grep -h -o 'CLIENT_TRAFFIC.*' /var/log/ltm >> /var/tmp/session.pms grep -h -o 'SERVER_TRAFFIC.*' /var/log/ltm >> /var/tmp/session.pms grep -h -o 'CLIENT_HANDSHAKE.*' /var/log/ltm >> /var/tmp/session.pms grep -h -o 'SERVER_HANDSHAKE.*' /var/log/ltm >> /var/tmp/session.pms
Now the session.pms file can be pulled from the F5 and put into Wireshark as indicated on the next page.
Decrypt traffic using Client¶
If you have access to the client you can use the following modifications for Windows or Ubuntu:
SSL Decrypt from Windows Client¶
To use the client to decrypt you must add a System Variable to log the session key data for decryption. On a windows client you would go into the Environment Variables and add a SSLKEYLOGFILE value to a text file on the machine as in the following image.
In our lab environment there is a shortcut on the desktop to connect to the environment variables.
Now start the tcpdump on the F5 box similar to: 'tcpdump -nni 0.0:nnnp -s0 -w /var/tmp/ssl.pcap host 10.1.20.103'
Once the system variable has been put in place you can then launch a web browser and start the traffic that you want to analyze.
Once the traffic has been captured you will import the capture file into Wireshark and configre the SSL options to use the pre-master key file defined in the system variables.
SSL Decrypt from Linux Client¶
On an Ubuntu client open a terminal window and run the following commands:
1 2 3
touch session-key.log export SSLKEYLOGFILE=/home/f5student/session-key.log chromium-browser
This will launch the Chrome browser and once you close the browser it will stop logging the SSL Session key data.
Once the traffic has been captured you will import the capture file into Wireshark and configure the SSL options to use the session-key.log file.
