F5BigCneAddresslist¶
Overview¶
The F5BigCneAddresslist Custom Resource (CR) is useful for creating larger, more complex lists of IP addresses. This can be used in the Denial of Service (DoS/DDoS) event detection and mitigation CR, F5BigDdosGlobal CR.
Parameters¶
The CR spec parameters used to configure the Service Proxy TMM static routing table are:
Parameter | Description |
addresses |
The IPv4 or IPv6 addresses included in the address list: host 2002::10:10:10:1, subnet 2002::10:10:0:0/96, or range 2002::10:10:10:1-2002::10:10:10:20. |
addressLists |
This is a string which refers to another addresslist that consists of either IP addresses or child addresslists. |
Sample CR¶
apiVersion: "k8s.f5net.com/v1"
kind: F5BigCneAddresslist
metadata:
namespace: "my-gateway"
spec:
addresses:
- "192.168.1.0-192.168.1.10"
- "10.10.10.0/24"
- "192.168.2.1"
addressLists:
- “addressList1”
- “addressList2”
metadata:
spec:
addresses:
- "3002::33:22-3002::33:52"
- "3004::/64"
addressLists:
- “addressList3”
- “addressList4”
Create and apply F5BigCneAddresslist CR¶
Copy the sample CR into a YAML
<bnk-address-list.yaml>
file.Apply the F5BigCneAddresslist CR:
kubectl apply -f bnk-address-list.yaml
The log message indicates that the F5BigCneAddresslist CR was added/updated:
I0607 12:00:00.12345
1
event.go:282] Event(v1.ObjectReference{Kind:"F5AddressList",
F5AddressListProfile cnf-gateway/outbound-nat was added/updated
