BIG-IP Next for Kubernetes CRDs¶
The BIG-IP Next for Kubernetes Custom Resource Definitions (CRDs) extend the Kubernetes API, allowing the Traffic Management Microkernel (TMM) to be setup using SPK’s Custom Resources (CRs) from BIG-IP Next for Kubernetes. These CRs enable TMM to handle low-latency application traffic, and implement networking configurations such as interface IP addresses and static routes. For information on the specific CRs and complete list of parameters available for creating a CR, refer the corresponding CRD. Users can now install all F5 Use Case Custom Resource Definitions (CRDs) by following the instructions in the Install F5 Use Case Custom Resource Definitions section.
Networking CRs¶
Networking CRs configure the networking components of TMM, such as network interfaces and static routes.
Available network management CRs:
F5SPKVLAN - TMM interface configuration: VLANs, Self IP addresses, MTU sizes, and so on.
F5SPKStaticRoute - TMM static routing table management.
Application traffic CRs¶
When an application traffic CR is applied, the TMM is configured to act as a proxy and distribute application traffic through protocols like TCP, UDP, SCTP, and NGAP. This results in the TMM receiving various objects related to managing application traffic. The BIG-IP Next for Kubernetes supports the Gateway API open source standards and utilize its route resources such as HTTPRoute and GRPCRoute to configure BIG-IP Next for Kubernetes to route Ingress traffic. For more information, see Gateway API.
| Object | Description |
| Virtual Server | An IP address and service port that receives and processes ingress application traffic. |
| Network Virtual Server | An IP address subnet representing a range of destination IP addresses to receive and process ingress application traffic. |
| Wildcard Virtual Server | Receive and process all destination application traffic. Specified using IPv4 address 0.0.0.0/0 or IPv6 address ::/0. |
| Protocol Profile | Provide application traffic intelligence, and options to adapt how connections are handled. |
| Load Balancing Pool | The Service object Endpoints that TMM distributes traffic to using round robin load balancing. |
Available traffic management CRs:
Ingress Load Balancing
F5 CRs:
The F5 L4Route CR is applied to act as an application developer.
Gateway API Community CRs:
BIG-IP Next for Kubernetes supports these community-based CRs,
GatewayClass: GatewayClass CR is applied in the cluster. This takes on the role of the infrastructure provider.
Gateway: Gateway CR is applied to act as an entry point to manage internal and external traffic. This takes on the role of the cluster operator.
HTTPRoute: HTTPRoute CR is used to define and manage routing rules for HTTP traffic within a Kubernetes cluster. This takes on the role of the application developer.
GRPCRoute: GRPCRoute CR is used to handle GRPC traffic within a Kubernetes cluster. This takes on the role of the application developer.
ReferenceGrant: RefernceGrant CR is used to enable cross namespace reference within Gateway API.
Egress Load Balancing
F5SPKEgress - Egress application traffic for pods using SNAT, Shared SNAT with Flow Forwarding, Security Protection, PseudoCNI and VXLAN creation.
F5SPKSnatpool - Allocate IP addresses for egress Pod connections.
Protection and NAT CRs¶
Traffic Management CRs can utilize Protection and NAT CRs to safeguard applications against unauthorized and malicious network traffic.
F5SPKGlobalOptions - Includes configurable options to enable or disable crypto hardware acceleration on the BlueField-3 Data Processing Unit (DPU).
Firewall CRs¶
The following CR is used to define the Firewall policy logic to secure BIG-IP Next for Kubernetes, and can be often modified by operations:
F5BigFwPolicy - Granular stateful-flow filtering based on access control list (ACL) policies. To understand the Firewall policy support in Gateway API, see Firewall policy in Gateway API
The following CRs are used for BIG-IP Next for Kubernetes Firewall Logging:
F5BigLogProfile - Specifies subscriber connection information sent to remote logging servers.
F5BigLogHslpub - Defines remote logging server endpoints for the F5BigLogProfile.
Finalizers¶
The finalizers prevent the deletion of Custom Resources (CRs) until backend configurations are safely removed, ensuring reliable cleanup and consistency.
Finalizers are namespaced keys that instruct Kubernetes to wait until specific conditions are met before completely deleting resources marked for deletion. The BIG-IP Next for Kubernetes Controller utilizes Kubernetes finalizers to ensure consistency between CRs and backend configurations.
The BIG-IP Next for Kubernetes Controller adds a finalizer to any newly created CR.
Upon CR deletion, the BIG-IP Next for Kubernetes Controller first removes the respective configuration from the backends and then eliminates the finalizer, permitting Kubernetes to complete the deletion process. As long as the finalizer is present in the CR, it will not be completely deleted.
When a CR is deleted, finalizers prevent it from being deleted if the BIG-IP Next for Kubernetes Controller is offline. When the controller comes back online, it takes out the configuration from the backend and then removes the finalizer. This makes sure that CRs are only deleted after the configuration is removed from the backends.
