Distributed Toda for Stats Aggregation
Overview
BIG-IP Next for Kubernetes generates a large amount of data, at a rate of terabytes per second. To efficiently manage this high-volume of statistics, the Distributed Toda for Stats Aggregation system has been enhanced with three primary pods: Receiver, Observer, and Coordinator (Operator).
Distributed Toda Pods Roles
In this section, you will find details about the responsibilities of every Distributed Toda pod.
  • Receiver: The receiver runs in a StatefulSet. It collects metrics from the files and then sends them to the Observer using gRPC (Remote Procedure Call) with mutual TLS (mTLS) for aggregation.
  • Observer: The observer also runs in a StatefulSet. It aggregates the metrics across multiple TMMs, which it receives from the receivers, and sends the metrics to the (OTEL) collector over gRPC with mTLS for aggregation and standardization.
  • Coordinator (Operator): The operator is responsible for overseeing the entire process. It coordinates the collection and aggregation of resources with corresponding requests over gRPC with mTLS, ensuring fast and safe metrics flow.
  • TMM Scraper: TMM Scraper is an observer container that runs inside each TMM pod, replacing the tmstatsd tool. It directly serves metrics from tmctl over a gRPC response stream upon receiving requests from the Receiver. This approach eliminates the need for TMM to mount persistent storage or write metrics directly to CSV files.
Metrics Flow Architecture
V2 Metrics
The following image depicts the V2 metrics flow architecture:
Example:
Following is an example of v2 Metrics of the virtual server clientside.received.bytes metric example collected from OTEL.
V1 Metrics
In V1 metric flow architecture, the metrics are streamed directly from TMM by tmstatsd to OTEL, without aggregation.
The following image depicts the V1 metrics flow architecture:
CSV Files
The tmstatsd process creates CSV files to ensure that metrics from various tmctl tables are saved in a consistent format. The TMMs save the metrics to CSV files periodically, with each TMM creating its separate files for each table. These files are then stored in specific folders, one for each TMM.
Distributed Toda Pods Installation
For the installation of the Receiver, Observer and Coordiator (Operator), refer to the FLO section.
Metrics Export Intervals
Note: By default, the metrics export interval from the Receiver and Observer to OTEL is fixed at 2 minutes in the Coordinator (Operator) ConfigMap and cannot be changed.
OTEL Statistics
The full list of OTEL statistics can be reviewed here.
Prometheus and Grafana
Note: Prometheus and Grafana are not yet integrated with the FLO installation. However, they can be installed manually to view metrics.
The examples below show how the metrics can be used in Prometheus and Grafana.
Prometheus
For the metric f5.virtual_server.clientside.received.bytes, you can view the metrics in Prometheus using the following query:
f5_tmm_f5_virtual_server_clientside_received_bytes_total
Note: f5_tmm is a prefix applied to all metrics by OTEL.
Example
Prometheus
Prometheus Integration for BNK Metrics
This section describes the procedure to expose BNK Metrics to Prometheus. The commands and Custom Resources (CRs) provided in this section are for the BNK OpenTelemetry (OTEL) running in the default namespace. If OTEL is running in a different namespace, modify the commands and CRs accordingly.
Note: Do not skip steps 1 to 3, even if OpenTelemetry is already running. You may skip them only if you have completed these steps earlier.
  1. Create a valid certificate using cert-manager. Copy the following data into otel-certs.yaml file, and replace arm-ca-cluster-issuer with your CA issuer’s name. You may adjust other fields as needed, and ensure to keep the name and secretName unchanged.
    apiVersion: cert-manager.io/v1
    kind: Certificate
    metadata:
    spec:
      subject:
        countries:
          - US
        provinces:
          - Washington
        localities:
          - Seattle
        organizations:
          - F5 Networks
        organizationalUnits:
          - PD
      emailAddresses:
        - clientcert@f5net.com
      commonName: f5net.com
      dnsNames:
        - otel-collector-svc.default.svc.cluster.local
      secretName: external-otelsvr-secret
      issuerRef:
        group: cert-manager.io
        kind: ClusterIssuer
      duration: 2160h
      privateKey:
        rotationPolicy: Always
        encoding: PKCS1
        algorithm: RSA
  2. Apply the certificate manifest using kubectl command.
    kubectl apply -f otel-certs.yaml
  3. Delete the existing pod(s) and restart the OpenTelemetry collector for the new certificates to apply.
    kubectl get pods --no-headers -o custom-columns=":metadata.name" | grep otel-collector | xargs -r kubectl delete pod
  4. Create a dedicated namespace for Prometheus.
    kubectl create namespace prometheus
  5. Create a valid certificate for Prometheus using cert-manager.
    a. Copy the following data into prom-certs.yaml file and replace arm-ca-cluster-issuer with the name of your CA issuer. You can modify other fields as needed.
    kind: Certificate
    metadata:
      namespace: prometheus
    spec:
      subject:
        countries:
          - US
        provinces:
          - Washington
        localities:
          - Seattle
        organizations:
          - F5 Networks
          - PD
      emailAddresses:
      secretName: prometheus-client-secret
      issuerRef:
        kind: ClusterIssuer
      # Lifetime of the Certificate is 1 hour, not configurable
      duration: 2160h
      privateKey:
        encoding: PKCS1
        algorithm: RSA
    b. Apply the certificate manifest using kubectl command.
    kubectl apply -f prom-certs.yaml
  6. Create a custom values.yaml file to configure and customize the Prometheus installation using Helm. Copy the following data into the file created.
    prometheus-pushgateway:
      enabled: false
    prometheus-node-exporter:
      enabled: false
    kube-state-metrics:
      enabled: false
    alertmanager:
      enabled: false
    configmapReload:
      prometheus:
        enabled: false
    serverFiles:
      prometheus.yml:
        scrape_configs:
          - job_name: bnk-otel
            scheme: https
            static_configs:
              - targets:
                  - otel-collector-svc.default.svc.cluster.local:9090
            tls_config:
              cert_file: /etc/prometheus/certs/tls.crt
              key_file: /etc/prometheus/certs/tls.key
              ca_file: /etc/prometheus/certs/ca.crt
              insecure_skip_verify: false
    server:
      extraVolumes:
        - name: prometheus-tls
          secret:
      extraVolumeMounts:
          mountPath: /etc/prometheus/certs
          readOnly: true
      global:
        scrape_interval: 10s
      service:
        type: "NodePort"
        nodePort: 31929
      configmapReload:
        enabled: false
      persistentVolume:
        enabled: false
  7. Deploy Prometheus with Helm.
    helm install prometheus oci://ghcr.io/prometheus-community/charts/prometheus -n prometheus --atomic -f values.yaml
  8. Ensure the BNK scrape configuration is active, status is healthy, and there are no errors.
    curl http://172.18.0.4:31929/api/v1/targets | jq
    Note: Replace 172.18.0.4 with the IP address of the node where Prometheus is running.
  9. Run the following command to list all BNK metrics currently ingested by Prometheus.
    curl http://172.18.0.4:31929/api/v1/label/__name__/values | jq
  10. Get total server-side connections for all pool members.
    curl "http://172.18.0.4:31929/api/v1/query?query=f5_tmm_f5_pool_member_serverside_connections_count_total" | jq
Grafana
Grafana can be connected to Prometheus to display dashboards based on the metrics sent to Prometheus. Here is an example of a Grafana dashboard for Virtual Server metrics.
Grafana
