ZebOS ConfigMaps¶
The BIG-IP Next for Kubernetes TMM pod’s f5-tmm-routing container uses the ZebOS.conf file as a ConfigMap for its BGP configuration. This allows dynamic routing to the BGP configuration through the Bidirectional Forwarding Detection (BFD) watcher without the need to restart the f5-tmm-routing container. The setup with seamless updates ensures efficient routing and robust fault detection in Kubernetes clusters.
Create ZebOS ConfigMap¶
The f5-tmm-routing container requires a ZebOS ConfigMap, which is used to store BGP configuration.
Follow the instructions below to create the ZebOS ConfigMap.
Create a file named
zebos-conf.yamlwith the below content.apiVersion: v1 data: ZebOS.conf: | router bgp 64522 ! bgp router-id 192.168.154.96 bgp log-neighbor-changes bgp graceful-restart restart-time 120 no bgp default ipv4-unicast redistribute kernel ! max-paths ebgp 5 ! neighbor spkv4 peer-group neighbor spkv4 remote-as 64521 neighbor spkv4 activate neighbor 10.4.1.246 remote-as 64521 neighbor 10.4.1.246 activate neighbor spkv6 peer-group neighbor spkv6 remote-as 64521 neighbor spkv6 activate neighbor fc04:1::254 remote-as 64521 neighbor fc04:1::254 activate ! ! address-family ipv6 unicast redistribute kernel neighbor fc04:1::254 activate exit-address-family ! address-family ipv4 redistribute kernel neighbor 10.4.1.246 activate exit-address-family ! bfd gtsm enable interface external bfd interval 100 minrx 100 multiplier 3 exit router bgp 64522 neighbor 10.4.1.246 fall-over bfd neighbor fc04:1::254 fall-over bfd kind: ConfigMap metadata: name: f5-tmm-dynamic-routing-template namespace: alpha
Install the ZebOS ConfigMap.
In this example, the ZebOS ConfigMap installs to the alpha Project.
kubectl apply -f zebos-conf.yaml -n alpha
Note: Ensure that the ZebOS ConfigMap is installed in the same namespace where the BNKGatewayClass CR is installed.
View the ZebOS ConfigMap¶
To view the ZebOS ConfigMap, run the following command.
kubectl get cm -n alpha
Sample Output
NAME DATA AGE
f5-tmm-dynamic-routing-template 1 7d22h
