Create Storage Class
F5 recommends creating a Kubernetes Storage Class using Network File System (NFS) with ReadWriteMany (RWX) access mode. This recommendation exists because TMMs and Observer pods, which collect and aggregate metrics across all TMM pods, always run on separate nodes. Due to this distributed architecture, using local storage is not practical.
The F5 Lifecycle Operator (FLO) automatically defines the Persistent Volume Claim (PVC) with RWX access and its associated naming, after which Kubernetes dynamically creates the Persistent Volume (PV) using the available storage classes. These persistent volumes ensure important data such as core dumps, stats, and other essential files are consistently available—even across pod reboots or node restarts.For more information on Storage Class, see Storage Classes.
To create the Storage Class, follow the instructions below:
  1. Install CSI Driver for NFS.
    helm repo add csi-driver-nfs https://raw.githubusercontent.com/kubernetes-csi/csi-driver-nfs/master/charts
    helm install csi-driver-nfs csi-driver-nfs/csi-driver-nfs     --namespace kube-system     --set kubeletDir=/var/lib/kubelet
    • List the available CSI drivers in your Kubernetes cluster.
      kubectl get pods --selector app.kubernetes.io/name=csi-driver-nfs --namespace kube-system
      Sample Output
      NAME                                  READY   STATUS    RESTARTS   AGE
      csi-nfs-controller-7dfdf8bb86-h6b2q   5/5     Running   0          32h
      csi-nfs-node-9s784                    3/3     Running   0          32h
      csi-nfs-node-ccld9                    3/3     Running   0          32h
      kubectl get csidrivers
      Sample Output
      NAME             ATTACHREQUIRED   PODINFOONMOUNT   STORAGECAPACITY   TOKENREQUESTS   REQUIRESREPUBLISH   MODES        AGE
      nfs.csi.k8s.io   false            false            false             <unset>         false               Persistent   32h
  2. Create a storageclass.yaml file with the example content below.
    allowVolumeExpansion: true
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    metadata:
      annotations:
        kubectl.kubernetes.io/last-applied-configuration: |
          {"allowVolumeExpansion":true,"apiVersion":"storage.k8s.io/v1","kind":"StorageClass","metadata":{"annotations":{},"name":"nfs"},"parameters":{"server":"10.144.73.141","share":"/titan"},"provisioner":"nfs.csi.k8s.io","reclaimPolicy":"Delete","volumeBindingMode":"Immediate"}
        storageclass.kubernetes.io/is-default-class: "true"
    parameters:
      share:
      server:
    provisioner: nfs.csi.k8s.io
    reclaimPolicy: Delete
    volumeBindingMode: Immediate
    mountOptions:
      - hard
      - nfsvers=4.0
  3. Before you apply the storageclass.yaml, make sure to update the file with actual values for the below parameters.
    • Update parameters.share with path where PVCs are to be created.
    • Update parameters.server with external NFS server.
  4. Apply the storageclass.yaml.
    kubectl apply -f storageclass.yaml
  5. Check the created Storage Class.
    kubectl get storageclass
    Sample Output
    NAME            PROVISIONER      RECLAIMPOLICY   VOLUMEBINDINGMODE   ALLOWVOLUMEEXPANSION   AGE
    nfs (default)   nfs.csi.k8s.io   Delete          Immediate           true                   31h
  6. Patch the NFS Storage Class to make it default to ensure that the NFS storage class is used by default for all storage-related operations.
    kubectl patch storageclass nfs -p '{"metadata": {"annotations":{"storageclass.kubernetes.io/is-default-class":"true"}}}'
  7. Verify the NFS Storage Class.
    Sample Output
    local-path      rancher.io/local-path   Delete          WaitForFirstConsumer   false                  12d
    nfs (default)   nfs.csi.k8s.io          Delete          Immediate              true                   12d
