Configure Cert ManagerΒΆ
Cert Manager generates certificates and keys to enable Zero-trust encrypted communication between pod workloads in Kubernetes. For this setup, we recommend an open-source version of Cert Manager optimized for the ARM architecture.
To successfully configure Cert-Manager, follow these steps:
Note: After installing the cert-manager, make sure that you wait for a minute for cert-manager to be ready. For more information, see (optional) Wait for cert-manager webhook to be ready.
Create Clusterissuer or Issuer: To start the process of issuing certificates, it is necessary to establish a ClusterIssuer or Issuer resource.
Note: F5 tested BIG-IP Next for Kubernetes with Jetstack Cert Manager v1.16.1. Ensure that the
global.certmgr.clusterIssuerparameter inflo-value.yamlis properly updated with themetadata.namevalue of the cluster issuer. In the example below, themetadata.namevalue isarm-ca-cluster-issuer. Ensure that thecertificate.clusterIssuerparameter inbnkgatewayclass-cr.yamlis properly updated with themetadata.namevalue of the cluster issuer. In the example below, themetadata.namevalue isarm-ca-cluster-issuer.Sample Cluster Issuer:
apiVersion: cert-manager.io/v1 kind: ClusterIssuer metadata: name: selfsigned-cluster-issuer spec: selfSigned: {} --- apiVersion: cert-manager.io/v1 kind: Certificate metadata: name: arm-ca namespace: cert-manager spec: isCA: true commonName: arm-ca secretName: arm-ca issuerRef: name: selfsigned-cluster-issuer kind: ClusterIssuer group: cert-manager.io --- apiVersion: cert-manager.io/v1 kind: ClusterIssuer metadata: name: arm-ca-cluster-issuer spec: ca: secretName: arm-ca
Apply the
ClusterIssuer.kubectl apply -f cluster-issuer.yamlSample Output:
clusterissuer.cert-manager.io/selfsigned-cluster-issuer created certificate.cert-manager.io/arm-ca created clusterissuer.cert-manager.io/arm-ca-cluster-issuer created
Verify the created
ClusterIssuer.kubectl get clusterissuer
Sample Output:
arm-ca-cluster-issuer True 83s selfsigned-cluster-issuer True 83s
For more information on how to use cert-manager to automatically provision Certificates for Ingress resources, see Annotated Ingress resource.
