F5BigCnePortlist
Overview
The F5BigCnePortlist Custom Resource (CR) is useful for defining larger, more complex sets of service ports, that can then be referenced by any of the Service Proxy Kubernetes (SPK) CRs:
  • F5BigFwPolicy - Granular packet filtering based on access control list (ACL) policies.
This document guides you through creating a simple F5BigCnePortlist.
Note: The F5BigCneAddresslist CR is useful for defining lists of IP addresses ports.
Parameters
The CR spec parameters used to configure the Service Proxy TMM static routing table are:
Parameter Description
ports The service ports included in the port list. Port 0 is not a valid value, and is not allowed.
portLists This is a string which refers to another portlist that consists of either ports or child portlists.
Sample
apiVersion: "k8s.f5net.com/v1"
kind: F5BigCnePortlist
metadata:
   namespace: "my-gateway"
spec:
   ports:
     - "5000-5500"
     - "80"
   portLists:
     -  “portList1”
     -  “portList2”
metadata:
spec:
   ports:
     - "4000-4100"
     - "8080"
   portLists:
     -  “portList3”
     -  “portList4”
Applying F5BigCnePortlist CR
To apply the CR in a namespace,
  1. Copy the sample CR into a YAML / file.
  2. Apply the F5BigCnePortlist CR:
kubectl apply -f bnk-port-list-cr.yaml
For example: This log indicates that the F5BigCnePortlist CR was added or updated.
I0607 12:00:00.12345   1 event.go:282] Event(v1.ObjectReference{Kind:"F5PortList",
F5PortList bnk-gateway/allow-5000-80 was added/updated
Feedback
Provide feedback to improve this document by emailing spkdocs@f5.com.
