Configure Node Label for TMM
During the installation of BIG-IP Next for Kubernetes, the data plane components will be installed on cluster nodes that carry the ‘f5-tmm’ label. To ensure the successful installation of data plane components on one or more NVIDIA BlueField-3 DPU cluster nodes, we need to identify the desired nodes and ensure that they have the ‘f5-tmm’ label applied.
Note: Execute all the instructions on the DPU node unless otherwise stated.
  1. Obtain the name of the DPU Node.
    kubectl get nodes
    Sample Response
    NAME                    STATUS   ROLES           AGE   VERSION
    arm64-sm-2              Ready    control-plane   33d   v1.29.7
    localhost.localdomain   Ready    <none>          10d   v1.29.9
  2. Add the label app=f5-tmm to the DPU Node.
    In the following command, localhost.localdomain refers to the DPU node name. Prior to executing the command, ensure that this is modified according to your specific configuration.
    kubectl label node localhost.localdomain app=f5-tmm
    Sample Response
    node/localhost.localdomain labeled
  3. To verify that the label has been applied correctly, run:
    kubectl get node localhost.localdomain --show-labels
    Sample Response
    NAME                    STATUS   ROLES    AGE   VERSION   LABELS
    localhost.localdomain   Ready    <none>   10d   v1.29.9   app=f5-tmm,beta.kubernetes.io/arch=arm64,beta.kubernetes.io/os=linux,kubernetes.io/arch=arm64,kubernetes.io/hostname=localhost.localdomain,kubernetes.io/os=linux
Apply a Taint on DPU Node(s)
A taint is a method used to designate that a node should not accept certain pods unless those pods specifically tolerate the taint. This method helps manage pod installation and enforces policies regarding where pods can be deployed, ensuring that workloads are placed on appropriate nodes based on predefined conditions.
Add a taint to the DPU nodes to restrict the DPU to running only the TMM and prevent Control Plane workloads to be scheduled on the DPU nodes. This taint will still permit other system-level daemonsets, like Flannel, to be executed.
Note: Users must apply the taint on all DPU nodes.
kubectl taint nodes localhost.localdomain dpu=true:NoSchedule
