GRPCRoute¶
The GRPCRoute resource in the Kubernetes Gateway API is designed to handle and route gRPC traffic within a Kubernetes cluster. GRPCRoute is determined by the Gateway API community. It extends the capabilities of routing beyond traditional HTTP traffic to support gRPC, a modern and high-performance protocol for remote procedure calls.
Key aspects of the GRPCRoute include:¶
Routing gRPC Traffic: GRPCRoute is a Gateway API type for specifying routing behavior of gRPC requests from a Gateway listener to an API object, i.e. Service.
Integration: Integrates with the Gateway and other related resources to manage and configure gRPC traffic efficiently.
By using GRPCRoute, Kubernetes users can effectively manage gRPC traffic, ensuring that requests are routed correctly and efficiently within their cluster.
Update service¶
When a backend service is edited, the configuration of the dataplane does not get automatically updated. You must perform these steps in sequence.
Delete the service.
Modify the yaml file of the service.
Reapply the service.
CR Parameters¶
The table below describes the GRPCRoute spec parameters:
| Parameter | Description | Implementation Details |
parentRefs.name |
Specifies the name of the parent resources that are associated with GRPCRoute. For example, grpc-gateway |
As per the Gateway API community standard. |
parentRefs.namespace |
Specifies the namespace of the parent resource that is associated with GRPCRoute. When unspecified, this refers to the local namespace of the Route. | As per the Gateway API community standard. |
parentRefs.port |
Specifies the network port that this GRPCRoute targets. For example, Targets all listeners on the specified port of a Gateway resource - 8080 | As per the Gateway API community standard. |
parentRefs.sectionName |
Specifies the section name or category of the parent that is associated with GRPCRoute. For example, listener name of Gateway resource - grpc | As per the Gateway API community standard. |
rules.backendRefs.name |
Specifies the name of the backend service to which the traffic must be sent. For example, go-grpc-greeter-server |
Each GRPCRoute CR supports only one rule. |
rules.backendRefs.port |
Specifies the port on which the backend service is listening. For example, 80 | As per the Gateway API community standard. |
rules.backendRefs.weight |
Specifies the weight for load balancing the traffic between multiple backends. For example, 30 | As per the Gateway API community standard. |
rules.backendRefs.namespace |
Specifies the namespace in which the backend service is deployed. When unspecified, this refers to the local namespace of the Route. |
Note:
You can refer to GRPCRoute for more details.
Hostnames, Matches, Filters, SessionPersistence parameters in GRPCRoute CR are not supported.
Multiple rules per GRPCRoute route CR is not supported.
GRPCRoute CR Status¶
GRPCRoute condition - Accepted
| conditions.status | conditions.reason | description |
| Unknown | Pending | Initial state. Waiting for controller |
| True | Accepted | Accepted |
| False | - NoMatchingParent - NotAllowedByListeners - NoMatchingListenerHostname |
- No matching Parents by either Name, Port, or SectionName - Route not allowed by listeners - Route has no matching listener hostname |
GRPCRoute condition - ResolvedRef
| True | ResolvedRefs | References Resolved |
| False | - InvalidKind - BackendNotFound - RefNotPermitted - UnsupportedProtocol |
- BackendRef has invalid kind - BackendRef not found - Referenced resource protocol is not supported |
GRPCRoute condition - PartiallyInvalid
| True | UnsupportedValue | Found both valid and invalid rules |
Note: Description from above tables may not reflect exactly same under the status section of CR.
Sample CRs¶
This section lists the sample CRs of use cases available to apply GRPCRoute. You must apply GatewayClass CR in the cluster and F5BnkGateway in the namespace, only once.
apiVersion: gateway.networking.k8s.io/v1
kind: GatewayClass
metadata:
spec:
controllerName: "f5.com/default-f5-cne-controller"
description: "F5 BIG-IP Kubernetes Gateway"
apiVersion: k8s.f5net.com/v1
kind: F5BnkGateway
metadata:
namespace: default #same namespace in which f5-cne-controller is deployed
spec:
ingressConfig:
defaultListenerNetworks:
- name: "default_ipv4"
ipv4BaseCidr: "11.11.11.0/24"
startAddress: "11.11.11.1"
endAddress: "11.11.11.10"
- name: "default_ipv6"
ipv6BaseCidr: "2002::11:11:11:100/112"
startAddress: "2002::11:11:11:101"
endAddress: "2002::11:11:11:110"
Basic GRPCRoute and Gateway API CRs¶
kind: Gateway
metadata:
namespace: gateway-infra
spec:
infrastructure:
parametersRef:
group: k8s.f5net.com
kind: F5BnkGateway
gatewayClassName: f5-gateway-class
listeners:
- name: grpc
protocol: HTTP
port: 50051
allowedRoutes:
namespaces:
kinds:
- kind: GRPCRoute
kind: GRPCRoute
metadata:
namespace: app-ns
spec:
parentRefs:
- name: f5-grpc-gateway
sectionName: grpc
rules:
- backendRefs:
- name: go-grpc-greeter-server
port: 80
namespace: app-ns
Client-side SSL configs¶
kind: Gateway
metadata:
spec:
infrastructure:
parametersRef:
kind: F5BnkGateway
listeners:
- name: grpc
protocol: HTTPS
port: 443
tls:
certificateRefs:
- kind: Secret
group: ""
allowedRoutes:
namespaces:
kinds:
- kind: GRPCRoute
kind: GRPCRoute
metadata:
spec:
parentRefs:
sectionName: grpc
namespace: app-ns
rules:
- backendRefs:
port: 80
namespace: app-ns
GRPCRoute with weighted traffic distribution¶
kind: GRPCRoute
metadata:
spec:
parentRefs:
sectionName: grpc
rules:
- backendRefs:
port: 80
namespace: app-ns
weight: 70
- name: go-grpc-greeter-server-2
port: 80
namespace: app-ns
weight: 30
